Installing a Switched 12v Power Supply on a G2? - ZX6R Forum
  • 1 Post By 29650
post #1 of 11 Old 05-24-2016, 02:03 AM Thread Starter
Hi All,
Off to the TT in a couple of weeks and really want to have some way to charge my phone and run a USB powered SatNav.
Most of the products seem to just clip onto your battery, but I don't want to do that, I'd like something a bit more sophisticated and have it only come on with the ignition, and be fused.
Anyone done this to a G2 or other ZX6R with the same wiring loom? Not quite sure where to start...
OdgeUK is offline
post #2 of 11 Old 05-24-2016, 03:35 AM
BrandonZX6r's Avatar
I Ride: 06 ZX6r 636
What I did on another bike was install a two 12v outlet with a switch and fuse. I did it directly to the battery. I am not a big fan of splicing into factory wire loom, I would rather go directly to the battery. This way if I need to charge my phone I do not have to have the ignition on , I can plug in and walk away while it changes under my seat.
BrandonZX6r is offline
post #3 of 11 Old 05-24-2016, 06:54 AM Thread Starter
That does make a lot of sense. In terms of not cocking up the existing wiring.
Something like this?
https://www.amazon.co.uk/Cliff-Top%C.../dp/B00QTA1G7Q
OdgeUK is offline
post #4 of 11 Old 05-24-2016, 07:05 AM
I Ride: 06 ZX6r 636
Yes that will work. I used one that had two cigarette style lighter outlet. I had a GPS and phone charger plugged into it. I think I got it at Meijer or Walmart for $10.
post #5 of 11 Old 06-10-2016, 12:20 PM
staningrimsb's Avatar
I Ride: Kawasaki ZX6-R (2000)
On my last bike I spliced into the main beam wiring loom that way it was on when the headlights were and turned itself off when the ignition went off really simple to do and causes no major draw on the circuit so is protected by the headlight fuse.
staningrimsb is offline
post #6 of 11 Old 07-07-2016, 02:52 AM
Still using a connection straight to the Battery, you could integrate a nice Rocker Switch.
With the Switch in a convenient (discreet or practical) location, it can be switched on or off, to provide power to all the attached USB devices, when you require.
Remember to switch it to the Off position when leaving your bike, or anything attached will become a drain on the battery (although while parked, you'd unlikely leave a mobile phone connected on the bike!)?.
Plus remember to add an inline Fuse on your Positive lead (close to the battery), for added protection for your electronic equipment.
As has been said below, your other option is to Tap in to a switched live feed, such as your dipped beam or ignition. Can be crimped in place, but positively identifying a switched live feed will require a volt meter.
Let us know how you get on with this.
29650 is offline
post #7 of 11 Old 07-07-2016, 04:35 AM
OP,
If you don't want to damage the wiring harness, you can simply tuck a fine wire into the fuse holder for the headlamp circuit..... that will give you a power condition only when the headlights come on.
Use that light wire to provide the juice to a relay coil, so that relay only completes its circuit when the headlight comes on. The common pin of the relay should be fused, and go to the positive battery terminal. If you are using this 12V port to support USB devices, the fuse should be quite small in Amperage. I would recommend the smallest you can find -- probably 1 A, which is far more power than any USB device can accept.
Wire the positive lead of your outlet into the normally open side of the relay, and leave the normally closed side without anything attached. Negative side should be tied back to the battery; but that can be done anywhere that the harness is connected to the negative pole of the battery.
post #8 of 11 Old 07-07-2016, 02:55 PM
d1andonlyant's Avatar
I Ride: 04' ZX636
I just done the simple: battery + > fuse > switch > usb port > battery -. Can charge anything I need via USB and like Brandon said, walk away and leave stuff charging without leaving my keys in the ignition
04' ZX636
Ram Air Mod - Kleen Air Mod
Short Stacks Mod - MWR Filter
SP Quickshifter - 2012 Shock
__________________
d1andonlyant is offline
post #9 of 11 Old 07-07-2016, 03:02 PM
insan3guy's Avatar
I Ride: 2015 zx6r (30th annie ed.)
I like to use the license plate light to power my farkle relays. No chance of frying anything important that way
You have the right to remain silent. Anything you say can and will be misquoted and used against you in an internet fight
Originally Posted by insan3guy
I'd rather be a smartass than a dumbass
insan3guy is offline
post #10 of 11 Old 07-08-2016, 02:16 AM
On the "older" ZX6R's, no lights come on automatically - as you get with modern bikes, as a safety feature. You have to use the manual switch to put them on.
Another method I've used before, clean method of obtaining a positive feed, is an "Add-a-circuit" / "piggyback fuse". A conventional fuse with additional Live wire installed to the top of it, for a reliable new circuit to be added.
29650 is offline
post #11 of 11 Old 07-08-2016, 03:35 AM
Thanks for sharing. Good to know.
The kill switch only gets power with the ignition on, right?
power commander Emanuel2b Mechanical and Technical 24 08-21-2012 12:38 PM
How To: DIY 12v Power Source Chaos Guides 6 06-26-2012 12:43 AM
Thug - wheelie videos (2nd day practicing power wheelies) THUG The ZX6R 69 05-01-2012 04:28 PM
Installed my 12V power supply today. ponie1992 Motorcycle Talk 18 09-02-2011 04:53 PM
???pilot power or pilot power pure pizzot Motorcycle Talk 5 08-21-2011 01:35 PM
