Two problems !!!! - ZX6R Forum
 4Likes
  • 1 Post By PainfullySlo
  • 1 Post By RJ2112
  • 1 Post By rychsmail
  • 1 Post By scoot33
post #1 of 8 Old 05-31-2016, 04:56 AM Thread Starter
I Ride: 1998 G1 zx6r
Two problems !!!!
98 zx6r keeps leeking cold coolant from overflow pipe when bike is warm. Iv emptied old coolant and bled the system. Problem 2 is all my own fault .I put my front wheel in the wrong way round and now iv lost the bite from the brake pads.It feels like I've not bed them in . How can I put this right ? Or will I need new pad's. Any help or jokes will b appreciated . Thanks .
Ellie is offline
post #2 of 8 Old 05-31-2016, 05:25 AM
To start, fix your front wheel.
Brakecleaner and green scotchbrite on the rotors to help remove any glaze that has built up. Your brake pads should be fine (assuming there is more than 50% life left on them. If not, replace). You can scuff them up as well with the scotchbrite (no brake cleaner) to aid in that but you will need to re-bed them.
For the coolant...is the bike overheating? On a bike that old I would automatically start with replacing the thermostat and re-bleeding the cooling system and go from there.
Ellie likes this.
PainfullySlo is offline
post #3 of 8 Old 05-31-2016, 06:25 AM Thread Starter
Yeah I put sinted pads in about 200 mile and 2 track days ago. What is scotch bright? Is that like sand paper?
The bikes not over heating but I will try the thermostat do you think it could be the radiator cap?
Thank you so much for your reply.
Ellie is offline
post #4 of 8 Old 05-31-2016, 08:57 AM
Make sure you actually have a problem, with the coolant. Could be you are simply overfilling the catch tank. Coolant expands when heated, you have to have 'headroom' in the tank to account for that. It should dump excess coolant....
Ellie likes this.
post #5 of 8 Old 05-31-2016, 09:15 AM
rychsmail's Avatar
I Ride: 2013 zx6r
Scothc-Brite Pads are green (usually) and the are very abrasive pads. Can be found at most stores under cleaning section. Many go under other names.
http://www.amazon.com/Scotch-Brite-H.../dp/B00005NAVS
Ellie likes this.
2013 zx6r (white), bazzaz zfi/afm, leo vince w/pinebox link pipe, driven block-off plates, woodcraft clip-ons, k&n filter, woodcraft frame sliders, techspec tank pads, china levers and rearsets
rychsmail is offline
post #6 of 8 Old 05-31-2016, 09:16 AM
rychsmail's Avatar
I Ride: 2013 zx6r
Scotch-Brite Pads are green (usually) and the are very abrasive pads. Can be found at most stores under cleaning section. Many go under other names.
Amazon.com: Scotch-Brite Heavy Duty Scour Pads 223, 3-count (Pack of 24): Health & Personal Care
post #7 of 8 Old 05-31-2016, 02:46 PM
scoot33's Avatar
I Ride: zx6 j2
just keep working the brakes ,they eventually will bed in ,its always the same with new pads with any car/truck/bike they bed in to the tram lines caused wear and tear just give it time
Ellie likes this.
zx6r j2 mods done ,,
scoot33 is offline
post #8 of 8 Old 06-05-2016, 02:15 PM Thread Starter
Thanks
ID:	39956   Click image for larger version
ID:	39957   Click image for larger version
ID:	39958   Click image for larger version
Ellie is offline
95 zx6-r carb problems, jetting, bogging...new to forums, please help! Wunderlem Mechanical and Technical 15 07-11-2013 06:19 PM
Two problems with my 636 that might be related ch1ckenstrip The ZX6R 7 05-20-2013 06:28 PM
Having Problems greenskull Mechanical and Technical 1 03-17-2013 01:46 PM
new bike..need help with a few problems NEPAzx6r Mechanical and Technical 9 12-14-2012 03:52 AM
