Paddock Stand / Headstock - ZX6R Forum
  • 1 Post By Felixthecat
  • 1 Post By scoot33
  • 1 Post By Gimpy
post #1 of 6 Old 10-06-2016, 08:03 AM Thread Starter
Rab
Rab's Avatar
I Ride: ZX6-R 636 A1P
Question Paddock Stand / Headstock
Not sure if this is in the correct section but I am after UK company / distributor.
I have a 2002 ZX6R 636 A1P and I'm after some paddock stands or a head-stock stand for the bike to get it off the wheels over the winter and make normal maintenance a lot easier.
just want to see what you guys are using or you have any recommendations? I'm still torn over whether to get front and rear paddocks or a head stock for the front instead?
I've got swing arm bobbins on the rear so i know what i need there but its the front I'm struggling with, whats the big advantages of a head stock?
ive seen these if anyone has any experience of these?
Black Pro Range Height Adjustable Front Head And Rear Paddock Motorcycle Stand | eBay
Black Pro Range Evo Front & Rear Paddock Stand Set Maitenance Lift Service Kit | eBay
Rab is offline
post #2 of 6 Old 10-06-2016, 08:16 AM
Felixthecat's Avatar
I Ride: 2012 ZX6R
If I could I'd go for more reputable stands(but that's not your question), go for the head stand. You'll end up being able to do more jobs on the bike with a that due to the fact that you can take the forks off and still have the bike off the ground. A fork stand you can do that with.
Rab likes this.
2012 Ninja ZX6R
Felixthecat is offline
post #3 of 6 Old 10-06-2016, 10:35 AM Thread Starter
Rab
Rab's Avatar
Cool,
Yeah a better brand would be preferable but the mrs is getting me then for our anniversary and tbh I can't justify more expensive stands at the moment but will upgrade eventually. Just need these so I can do some pre winter maintenance before the bikes locked up for a few months.
Hopefully one of my UK compatriots has used these for a zx6r
Rab is offline
post #4 of 6 Old 10-06-2016, 01:26 PM
scoot33's Avatar
I Ride: zx6 j2
i got 2 types,i got the casual one that goes under fork legs witch i use on track days ect but not great when you need to drop the forks out ,the headstock one i think i paid £80 that was from a sealey catalogue,ebay most likely have them,but cover the front mudguard as it can scratch it if your not carefull
Rab likes this.
zx6r j2 mods done ,,
scoot33 is offline
post #5 of 6 Old 10-06-2016, 08:21 PM
Gimpy's Avatar
I Ride: '14 ZX6r, '05 R6
In my opinion, definitely go for the headstock stand for the reasons Felix stated. When you do upgrade I would steer you toward a frame lift like a 1jac which is a UK product. The frame lift is amazing, you can move the bike around while on the stand and perform just about any repair/maintenance with it. It was money well spent for me. Check out 1jac.com
Rab likes this.
Gimpy is offline
post #6 of 6 Old 10-07-2016, 03:51 AM
PitBull,, combo stand..
Understand the money, how much will it cost it the stand fails or slips holding your bike.
Paddock stands KawaCrazy Racing 14 06-08-2016 04:46 PM
Paddock Stand Issue - ZX6R 09 P8F NinjaMan83 Mechanical and Technical 34 12-01-2015 11:23 AM
2013 636 Cotton Reels for Rear Paddock Stand? Rodija The ZX6R 9 08-26-2013 03:22 PM
FS: Front Paddock Stand gmanb1h636 Classifieds 0 08-29-2012 03:11 AM
Harris paddock stand/bobbin question? aaronb Mechanical and Technical 2 04-11-2012 10:52 AM
