Oh noooo! What happened? Were you at Chuckwalla for the CVMA races?
Hope you're ok dude! Unfortunately I don't have any spares for what you need, but since most of those parts are OEM, it'd start with ebay if I was you.
I have a Radiator that might work for you, has a lot of Miles and the mounts are a little bent but it still works. You can have it for free.
As for the master rebuild kit why do you need one? You can just clean it out and buy that small plastic part that broke. I've replaced just that once from one of my get offs.
Totally agree. Super thankful I was wearing a good helmet. I definitely won't be skimping in that department. After a little poking around, the RF1200 seems like a pretty good one?
Side note...has anyone here had swingarm damage after a crash? The left spool was bent up which dented the side of the swingarm pretty good. I spun the wheel and looked at it closely and it looks straight as far as I can tell but am thinking about replacing it to be on the safe side...
It is quite common for our bikes to bend the tab where the spool threads in. Mine is still bent but I had the bike laser measured and it is straight as an arrow. It is just a weak point in the design.
Thanks Cody, and thank you to everyone else for all of the very kind words.
Side note...I couldn't have asked for a more supportive lady. She's stayed up super late to be with me in the ER and has even helped me find parts I need.
If you need to replace your master cylinder doing what I did..figured out how much brake is recommended.. Get some clear tubing that fits over the top bleed valve.. Take the ID and multiply it by 3.14.. That will give you the length needed..
Looks like I also need a front wheel. Looking at it closely, the rotors are straight, but if you watch the edge of the rim while it spins it has an ever-so-slight wobble to it. I will probably try and get it straightened as a spare.
If anyone has an 05+ front wheel for sale, I'm interested.
If you needed a windscreen I have a stock OEM FOR 13+
You have insufficient privileges to reply here.
