TPS Problem - BazzazThis is a discussion on TPS Problem - Bazzaz within the The ZX6R forums, part of the ZX6R Forum category; Just installed the Bazzaz unit and it reads 43% TPS at idle. Any ideas?
EDIT: Went out and test rode the bike. Seems to be ...  |
08-31-2009, 07:17 PM
#1 | | Pro Racer
Joined: Jun 2007 From: Kearney, Nebraska Posts: 806 I Ride: 2007 Ninja ZX-6R | TPS Problem - Bazzaz
EDIT: Went out and test rode the bike. Seems to be a big power improvement over the PC3 but why does the Bazzaz read 43%-45% at idle? Do you think this is a TPS problem or Bazzaz?
09-01-2009, 09:21 AM
#2 | | Pro Racer
I called them and they said it is probally plugged into the upper TPS sensor instead of lower. I wasn't aware there are two. Can anyone confirm before I pull it back apart again?
09-05-2009, 06:21 PM
#3 | | Squid
Joined: Jun 2009 From: VA Beach, VA Posts: 32 I Ride: 2006 Kawasaki ZX636 |
I had to replace my throttle body because of the TPS, there are two. if its giving you issues, plug it into the lower one and give it a test. Worst case, it gives you the same problem letting you know its the box or something else, or it dosent work and you just plug it into the top one.
09-05-2009, 10:39 PM
#4 | | Pro Racer
It was just plugged into the wrong one lol
09-06-2009, 03:13 AM
#5 | | Team Green
Joined: Feb 2009 From: LONDON Posts: 225 I Ride: ZX6 09 |
So it the Bazzaz unit better than PC 3/5? Which unit do you buy, as on their website there is quite a few different things... Z-FI??
| | | Search tags for this page | | '06 zx6 tps, 07 zx6r throttle psotion sensor, 2006 zx6 tps, 2006 zx6r tps, 2009 zx6r bazzaz, 2009 zx6r tps, bazzaz idling problem, bazzaz starting problems, bazzaz zfi poblems, can you read the bazzaz zfi with a home computer, how to install bazzaz afm on a 2006 zx6r, how to install bazzaz zfi on a 2006 zx6r, install the throttle bodies on a 2006 kawasaki zx6r, location of main throttle sensor for 2009 kawasaki zx6r, tps bazzaz, tps sensor, zx6r, baxxaz, zx6r tps problem
