valve adjustment - ZX6R Forum
  • 2 Post By riverszzr
  • 1 Post By PowerGroove
post #1 of 11 Old 10-05-2009, 08:27 PM Thread Starter
valve adjustment
I just got my zx6r. its got about 11.5k miles on it and its pretty noisy. I was thinking of doing a valve adjustment on it. any one have a write up on how to do it? thanks
cyclewerkes is offline
post #2 of 11 Old 10-05-2009, 10:23 PM
GIGM08GT's Avatar
I Ride: 03 ZX-6R
Seems a little early on the milage to be requiring it but none the less here is a link to a thread that answered all of my questions... thanks again detrafi
http://www.ninja6zone.com/forums/sho...ght=valve+shim
GIGM08GT is offline
post #3 of 11 Old 10-07-2009, 10:17 AM
ZX6R_C1H's Avatar
I Ride: ZX6R 636 C1H
I agree.. a little early. You sure it will solve your noise?
ZX6R_C1H is offline
post #4 of 11 Old 10-09-2009, 12:31 PM
I Ride: 2003 636
I doubt the noise has anything to do with your valves. Sounds like typical Kawasaki ticking. When was your last oil change?
636Noob is offline
post #5 of 11 Old 10-09-2009, 08:31 PM
AZ Ninja's Avatar
I Ride: 08 Zx6R
it also could be your cct getting a little loose causing excess noise. i would really check to see if it is the cct first before you go pulling the top end apart prematurely. a way you can check to see if it's your cc makeing the noise is to find out which side your cct is on and see if that side is producing a louder ticking noise compared to the other side. for example my 08's cct is on the right side and when it gets loose the ticking noise is the loudest on the right side compared to the left side. keep us updated and good luck mate.
AZ Ninja is offline
post #6 of 11 Old 10-13-2009, 05:54 AM
nexia201's Avatar
I Ride: zx6r 636 04
so they are all a bit noisy like (when rocker arms are noisy ) i was thinking there was something wrong with mine as it is a bit tappety
nexia201 is offline
post #7 of 11 Old 10-13-2009, 11:47 AM
It is not too early to be adjusting the valves. As a matter a fact it is a very good idea to do them early, since this is when they move the most. ( I have done about 10,000 bikes over the 30+ years I've been working on bikes and they all, always need adjustments, no such thing as too often or too early!)
As far as the write up that was linked, I would add this.
-You can use ziptie's to ziptie the cam chain to the cam sprockets before you remove the cam chain tensioner (this will mean you can only move one cam at a time, but makes reassembly super easy and fast) **don't drop any shims down the cam slot, or into the engine
-Take really good measurements and even better notes
- Have a clean bench to work off!!
-Make sure to retract the cam chain tensioner before you try to remove or reinstall
-The torque specs, on the cam caps only use 92 in lbs, the 104 recommended is too much and after a few times on and off, they will pull threads
-Use a micrometer, not a verneer caliper, way more accurate.
-Have the service manual and follow it pretty closely- if you havent done it before it will help
-Take digital pics, of the process if you feel it will help you remember how everything was routed and ziptied up
-When you finally actually get to the adjusting part of the valve adjustment- don't just do the "go-no go" with the feeler guages and say "they are within spec" .0043"-.0075"///.0087"-.0122" (speculating because I dont know what year you have). Go the extra step and adjust all 8 intakes so they have the same desired clearance (as example above--set the intakes at .0055" and the exhuasts at .010"--your bike will love you) Kawasaki shims come in .5mm jumps, but honda shims (same 7.5mm shim) come in .25mm increments- thus you can be way more precise with your adjustments. While some of the aftermarket shim kits will fit and work okay, they too have the .5mm increments and are only surface hardened about .0008" so they dont last as long, or give you as much adjustability.
( Almost every current model sportbike or shim under bucket bike made today takes the same 7.5mm diameter shims. Just Honda's are the least expensive and biggest selection, kaw and suz being the highest cost and least size choices available...you can look up a 600RR, F4I or 1000rr etc and find what you need- if you take my advice and use honda shims)
There is alot more to the valve adjustment than just adjusting the valves, and 9 hours time for a first timer is pretty quick.
You still need to adjust TPS, synchronize the throttle bodies, lube the cables and adjust (clean the throttle bodies- but dont spray carb cleaner in them, it will remove the coatings from the factory) check the rest of your sensors and make adjustments, plus all those other pesky maintainance items you routinely need, air filter, plugs, oil/filter change, check/adjust the steering head bearings, adjust/lube the chain etc...etc...
- Put a little anti sieze on the spark plug threads (but not the 1st 2), and torque them to 9 ft lbs--even if yours are iridiums and good enough to re-use.
Good luck and take your time, this is not a process to go through as fast as you can ( I've done thousands and thousands of them and it still takes me about 7-8 hours per bike to go through the entire "tune-up" procedure I follow).
Rickyyp and Jimmy85 like this.
post #8 of 11 Old 05-09-2013, 01:55 PM
I Ride: 2003 zx6r 636
I am having what seems to be the same problem here and im thinking its the cct but how the hell do i get to or locate the cct bolt to adjust it? heres a vid below of what it sounds like right now its a 2003 Zx6r 636
03 zx6r 636 annoying noise? - YouTube
Firecell33 is offline
post #9 of 11 Old 05-09-2013, 02:31 PM
Burnt toast's Avatar
I Ride: eye candy
Burnt toast is offline
post #10 of 11 Old 05-09-2013, 03:40 PM
Holy epic 4 year old thread revival Bat man!
BrandonBates likes this.
PowerGroove is offline
post #11 of 11 Old 05-09-2013, 05:52 PM
Ebster1085's Avatar
I believe the recommended mileage for the first valve adjustment is 18K, so I wouldnt worry about it for a bit. Just get out and ride!
Ebster1085 is offline
03 zx6r valve adjustment
03 zx6r valve clearances
07 zx6r valve cover recall and valve adjustment
2001 zx6r valve clearance
2006 kawasaki 636 valve lash
2007 zx6r valve adjustment
2013 zx6r valve adjustment
how do u dajust valves in a 2004 ninja 636
how do u set the valves on a kawasaki ninja 636
ninja zx6r valve adjustment
price to get valve adjustment on zx6r
Valve Adjustment 714reyesj Mechanical and Technical 35 02-23-2012 12:40 PM
valve adjustment how come....? TexMex Mechanical and Technical 15 02-17-2012 07:50 PM
how important is valve adjustment? TexMex Mechanical and Technical 1 11-13-2011 09:03 PM
Valve adjustment sethg1981 Mechanical and Technical 15 10-23-2011 08:24 PM
time for a valve adjustment.... 07zeeexxeer Motorcycle Talk 11 05-01-2011 05:21 AM
