Header Honeycomb Removal - ZX6R Forum
post #1 of 23 Old 10-08-2010, 09:54 AM Thread Starter
endeavor's Avatar
Has anyone removed the honeycomb inside their stock header? Would it be the same process as removing the honeycomb from a car cat? Beat the bejesus out of it, busting it up into pieces and powder. I have an 09 that I'm looking to dive into. I'm not sure if the other year models have this?
endeavor is offline
post #2 of 23 Old 10-08-2010, 12:19 PM
wiffy's Avatar
I Ride: mountain bike
get a cat back.remove cat and weld tube in then u still have cat for mot or rego what ever u call it.
dyslexia and adhd dont make for good spelling or gramer
wiffy is offline
post #3 of 23 Old 10-08-2010, 06:12 PM
ZoomSplat's Avatar
There are three ways to get rid of it:
1) smash it out of the stock header.
2) cut it out of the stock header, and weld in a patch piece to replace the section of pipe that you just removed.
3) buy an aftermarket exhaust system.
ZoomSplat is offline
post #4 of 23 Old 10-08-2010, 07:33 PM Thread Starter
endeavor's Avatar
I ended up just drilling and busting it out of the header. Took about 2 hours to do start to finish. Now to get the PC-V tuned.
endeavor is offline
post #5 of 23 Old 10-08-2010, 09:50 PM
Gn6hami's Avatar
I Ride: 05' 636 / 97' ktm 360SX / 96 ktm 300 mxc
probably would be quicker to cut it out and weld a new section eh?
Gn6hami is offline
post #6 of 23 Old 10-09-2010, 12:27 AM Thread Starter
endeavor's Avatar
I wouldn't think so. If I were going to cut/weld, I would remove the header. I did everything with the header still in place.
endeavor is offline
post #7 of 23 Old 10-09-2010, 03:10 AM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
How much crap comes out?
still lovin forever!
arron is offline
post #8 of 23 Old 10-09-2010, 09:01 AM Thread Starter
endeavor's Avatar
There was 2 honeycombs. Both were the diameter of the pipe(obviously lol) and about 2 inches deep. So I would guess it was a bit under 1 cup of powder and pieces.
endeavor is offline
post #9 of 23 Old 10-09-2010, 02:04 PM
arron's Avatar
Make any sound difference?
arron is offline
post #10 of 23 Old 10-09-2010, 10:01 PM Thread Starter
endeavor's Avatar
Not that I can really notice. Although as I was expecting, there is now an occasional "pop" when decelerating. Much like what happened before I did the Kleen mod. No big deal, I have to get my PC-V tuned anyway.
endeavor is offline
post #11 of 23 Old 10-09-2010, 11:26 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
you cant weld a patch or a section to the header unless u got lots of cash to blow. the header is made of titanium. you need a special environment to weld titanium. its not cheap. pinebox and i thought of it already and between the two of us together cant afford it. ive removed the cats from the header by drilling the center and using a chisle to remove the rest. works great. if u dont have a muffler on the end and u use a strait pipe then its alot louder and throws flames on decel. looks cool in pictures. performance wise its a good bit of difference over the stock setup. the PC-V will need to be tuned for sure.
09ZX-6R is offline
post #12 of 23 Old 10-10-2010, 12:43 AM
Gn6hami's Avatar
Before the site when down, there was an excellend write-up by a member on here (cant for the life of me remember their user id) about doing custom exhaust. 05-06 model I believe. He made the exhaust similar to the buel 1125cr. The pictures showed where he cut the cat right out of the headers, then welded another short section of pipe where the cut was made. He also welded on a small muffler and tip on it. Anyways, besides it looking absolutely KILLER, I dont recall anything being mentioned about special accomodations.
Have you tried it before or? I actually plan on doing it myself. I already ordered and recieved the used headers to cut on. I wish that thread was still here for me to reference. My emissions are due in January, so Ill make sure I take pics when I attempt it.
Gn6hami is offline
post #13 of 23 Old 10-10-2010, 04:20 AM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
G... it can be done if the header is made of something else. i remember the post ur talkin about too. he had aluminium headers and tail pipes. so welding that was a no brainer. if ur doing a titanium header tho theres alot to take into consideration. ive tried it before and it was too much moey to try as an experiment. if your doing it on ur bike and u dont have a titanium header then by all means do it up and post pics. in this post the original header in question was titanium and on a 09zx6r. same bike i own and race.
09ZX-6R is offline
post #14 of 23 Old 10-10-2010, 04:39 AM
Gn6hami's Avatar
i thought that he had used a stock header from another year that was a direct fit, or very close to a direct fit. Not aftermarket or aluminum ones. I could be wrong though it was a while ago and my memory isnt that great. maaaan, i wish i knew how to weld... or kawifreak77 lived closer so he could hook me up. shits expensive. The thread youre talking about... did he use a carbon fiber muffler? thats the one im talking about.
Gn6hami is offline
post #15 of 23 Old 10-10-2010, 04:42 AM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
it can be costly. yeah he did he also moddified it too.
09ZX-6R is offline
WTB 03-04 636 Header awdtsi Classifieds 0 11-15-2011 12:51 PM
03/04 636 Header fit 08 ZX6R? JesseZX6R Mechanical and Technical 22 05-06-2011 07:13 AM
Header material Cycleeric The ZX6R 10 01-27-2011 02:05 AM
Race header Azx6R The ZX6R 7 12-13-2010 10:44 AM
fairing removal dave palin The ZX6R 2 06-17-2009 04:36 AM
