Free/Cheap mods for the 03-06 636'sThis is a discussion on Free/Cheap mods for the 03-06 636's within the The ZX6R forums, part of the ZX6R Forum category; I just modified the exhaust a little, i plan on getting a power commander soon but i didnt want to take it to a dyno ...  |
02-21-2012, 08:55 AM
#106 | | Squid
Joined: Feb 2012 From: alabama Posts: 18 I Ride: 05 636 |
I just modified the exhaust a little, i plan on getting a power commander soon but i didnt want to take it to a dyno until i could get an ignition module too
02-21-2012, 09:06 AM
#107 | | MotoGP Champion
Joined: Jul 2007 From: Scottsboro,AL Posts: 2,685 I Ride: 04 ZX-636 |
if modifying your exhaust is all you did then removing the sec flies want cause the bike to run that much leaner bc these bikes come from the factory rich to avoid warranty issues.
02-21-2012, 09:21 AM
#108 | | Pro Racer
Joined: Jan 2012 From: Texas Posts: 699 I Ride: 2003 SixDirtySix, 2006 SixDirtySix |
Bumpity Bump |
02-24-2012, 04:27 PM
#109 | | MotoGP Champion
Joined: Jul 2007 From: Scottsboro,AL Posts: 2,685 I Ride: 04 ZX-636 | Quote:
Originally Posted by Aeon87 Bumpity Bump  | thx for the free bump  its gettin about that time guys so let the moding begin |
03-13-2012, 12:38 PM
#110 | | MotoGP Champion
bump
03-14-2012, 01:36 PM
#111 | | Squid
Joined: Mar 2012 From: Vista, CA Posts: 3 I Ride: Aprilias, Hondas, Kawis, Suzukli etc |
Bump!
Just did the jumper mod, minor improvement at peak rpm with lots of tank slapper happiness on uneven roads at full throttle.
I also cut the plugs off of my stock exhaust servo, $4 worth of resistors and a capacitor and wired up a servo eliminator dongle. No more FI light and a small weight savings by removing the servo/cables... which was immediately countered by adding a GPR steering stabilizer... net gain = Zero!
03-16-2012, 03:38 AM
#112 | | Track Star
Joined: Oct 2011 From: Surrey UK Posts: 437 I Ride: 2003 ZX6R |
Very very interesting read, but i would like pics stage by stage as im not to familiar with these bikes?
I'll do all the mods but not sure how to do them?
03-16-2012, 04:13 AM
#113 | | Track Star
Are these the flies |
03-16-2012, 04:49 AM
#114 | | Pro Racer
Joined: Dec 2008 From: bedford Posts: 761 I Ride: zx6 09, B1h, tdr250 |
and the pics shows the splitter in the airbox to remove. I did all the mods on my 03, along with full race zorst, MWR air filter and power commander and got nearly 122hp at the rear wheel with a screaming top end.
03-16-2012, 05:00 AM
#115 | | Track Star
Joined: Oct 2011 From: Surrey UK Posts: 437 I Ride: 2003 ZX6R | Quote:
Originally Posted by rattyzx6 and the pics shows the splitter in the airbox to remove. I did all the mods on my 03, along with full race zorst, MWR air filter and power commander and got nearly 122hp at the rear wheel with a screaming top end. | Splitter? I've taken off the flies done the ram air mod.
I'm just on putting it back together.
03-16-2012, 05:19 AM
#116 | | Team Green
Joined: Jan 2012 From: Buffalo Posts: 220 I Ride: '05 ZX6R racebike, "04 Multistrada street | Quote:
Originally Posted by Fletch Are these the flies  | Quote:
Originally Posted by rattyzx6 and the pics shows the splitter in the airbox to remove. I did all the mods on my 03, along with full race zorst, MWR air filter and power commander and got nearly 122hp at the rear wheel with a screaming top end. | Something to consider:
Not everything that Kawi puts on a bike is a 'restriction'. Getting horspower numbers on a dyno while the bike is not moving through the air is different than the horsepower a bike will make while moving. Those splitters are designed to work with the ram air system. Kawasaki has the resources to test that in ways us regular folks have a more difficult time doing, so removing them is more a gamble than you might think. Kawi doesn't put things in the bike for no reason, in fact they most likely balanced the cost of more intricately designed splitters with the horsepower gain they would provide. You could likely gain more horsepower by extending the splitters to guide the airflow more efficiently to each intake.
03-16-2012, 05:44 AM
#117 | | Track Star
Where is the splitter?
03-16-2012, 06:05 AM
#118 | | Pro Racer
the splitter did not feature in the race manual. It was one of the first tthings to remove. In my experience my bike didnt suffer from not having the splitter. Fletch, the splitter is in the top half of your pic of the airbox and divides the air into 4. It is held in place by 2 rivets. To get the screaming top end also change the 2 longer velocity stacks for 2 shorter ones.
03-16-2012, 06:08 AM
#119 | | Pro Racer
btw TGOLD, i do agree with your comment above and everything i did could be reversed if it didnt work or appear to work.
03-16-2012, 06:11 AM
#120 | | Track Star
Originally Posted by rattyzx6 the splitter did not feature in the race manual. It was one of the first tthings to remove. In my experience my bike didnt suffer from not having the splitter. Fletch, the splitter is in the top half of your pic of the airbox and divides the air into 4. It is held in place by 2 rivets. To get the screaming top end also change the 2 longer velocity stacks for 2 shorter ones. | Yeah I thought it was that, but thought I'd make sure first before I go diving in!
As for the stacks I'll do this once I get two small ones, any suggestions where I could get a pair from?
Have you noticed much difference since doing this?
| | | Search tags for this page | | 03 636 mods, 03 zx6r mods, 04 636 mods, 04 zx6r 636 mods, 05 636 mods, 05 zx6r mods, 06 636 air mod, 06 636 mods, 06 zx6r mods, 636 mods, 636 power mods, best mods for a 636, cheap zx6r mods, mods for 03 636, power mods 06 zx6r, zx636 mods, zx6r 09-11 mods, zx6r 636 mods, zx6r cheap mods, zx6r mods 06
