Free/Cheap mods for the 03-06 636's
This is a discussion on Free/Cheap mods for the 03-06 636's within the The ZX6R forums, part of the ZX6R Forum category; hey guys here is a list of mods i put together that i have done to my 04 636 that will improve the performance and ...
Old 11-21-2010, 06:47 PM   #1
zx racer's Avatar
I Ride: 04 ZX-636
hey guys here is a list of mods i put together that i have done to my 04 636 that will improve the performance and power for all the 03-06 636's. if anybody has any questions feel free to ask and i will try and answer them the best way possible.
1. KLEEN Air mod - where you reroute the pair valve breather located on top of the valve cover to the crankcase breather, plug all vacum ports on the airbox so it will let you pressurize the airbox, also gets rid of the popping & backfireing you hear thats most common with a aftermarket exhaust system & helps smooth out the throttle through out the entire rpm range
2. Ram Air mod - consist of removeing the resonator located underneath the ram air tube, you want to plug the hole back, this allows for the air to enter through a straight path without disturbing the airflow
3. Airbox mod - consist of removeing the dirvertor thats locate inside the airbox in the middle, you will need to drill out the 2 holes that holds the dirvertor inside, plug both holes back up, this "unrestricts" the air flow path to the throttle bodies given it a more staright flow, good for more top end power
4. Velocity Stacks - remove the 2 "tall" oem stacks in the middle for 2 "short" oem v stacks, this way you will be runnin all 4 short, good for more mid-top end power & thats where our motors like to be
5. Secondary flies removed - this consist of you takin the top airbox lid off when you look down inside the throttle bodies the 1st set of flies you see you want to remove them, make sure you dont let the lil screws fall down off inside the throttle bodies/motor best to use a magnetic screwdriver when removeing it prevents this of happen, this mod is good for more mid-top end power & better throttle responce
zx racer is online now
Old 11-21-2010, 09:17 PM   #2
I Ride: '07 zzr600--'97 ZX6R--'89 &'97 250 Ninjas--2009 ZX6R
I'll play devils advocate here;
Did you do baseline dyno runs and then do a mod and verify that it actually did improve performance on your changes, or is this just your thoughts?
Say before and after of your airbox mod?
Before and after of your velocity stack hieght change?
Before and after of removing the resonator in the airbox inlet?
Also-Kawasaki does sell solid dowel pins to replace the hollow ones that fit under the valve cover and allow air to pass from the "KLEEN" into the exhuast port-you can find the part number in their race parts-they will fit almost any kawi.
Old 11-21-2010, 09:30 PM   #3
knerona's Avatar
I Ride: 2007 ZX-6R
The best mod evar?
A good rider at the controls, do a learning track day if you haven't already. If you have, do some moar!
knerona is offline
Old 11-22-2010, 01:05 AM   #4
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
they all will do something but each on there own will have little but all will make a nice change.. just try some and see if you can tell the difference
arron is offline
Old 11-22-2010, 07:58 AM   #5
zx racer's Avatar
I Ride: 04 ZX-636
dude to dyno before and after each mod would be really expensive but i did have the bike dyno tune with all these mods along with a full exhaust done to my 04 636 and it put down 120rwhp.
Old 11-22-2010, 07:59 AM   #6
^ placebo effect?
The only true way to verify if anything has actually made an improvement is with a baseline and then an after run under controlled conditions.
I have a dyno and have done thorough testing on hundreds of bikes- I just want to know what the OP did to verify if anything he is suggesting actually made a real repeatable and verifiable improvement.
"i did have the bike dyno tune with all these mods along with a full exhaust done to my 04 636 and it put down 120rwhp." So what was your baseline number?-120 means nothing without a comparitive figure. What are other bikes making on that same dyno?
Old 11-22-2010, 08:16 AM   #7
zx racer's Avatar
I Ride: 04 ZX-636
^ placebo effect?
i have access to a dyno also but like i said before dyno time cost money but ive did enough testing on this bike to no wat works and wat doesnt, if you have a 03-06 zx6r and would like to try any of these mods feel free too and let us know wat you think.
Old 11-22-2010, 05:26 PM   #8
Gn6hami's Avatar
I Ride: 05' 636 / 97' ktm 360SX / 96 ktm 300 mxc
I did the jumper mod. Works great
I removed the sec flies. Works great
I didnt do the same as u for the velocity stacks, but i did put aftermarket ones on. Works great.
Gn6hami is offline
Old 11-23-2010, 08:21 AM   #9
zx racer's Avatar
I Ride: 04 ZX-636
x2 on the flies. loved the throttle responce it gave with them out and changing the v stacks to all 4 short is a very good mod to do. alot cheaper than buying the ones from factory pro and do just the same.
Old 11-23-2010, 05:12 PM   #10
Gn6hami's Avatar
yeah about 200 dollars cheaper at that. i had a gift card to use up at the time
Gn6hami is offline
Old 11-23-2010, 08:04 PM   #11
zx racer's Avatar
I Ride: 04 ZX-636
yea the FP v stacks are high and just couldnt justify myself paying that kinda money for 2-3 hp there claiming out of em.
Old 11-24-2010, 10:27 AM   #12
Knerona-has the best answer here.
AAron and ZXRACER, my point was and still is, where is the proof of what these changes will actually do for improvements. I am not saying they don't work-I am playing devils advocate because it is so easy for anyone to say "I fealt a big difference" when all too often there really isn't one, quite often the mods people do make there bikes even less powerful where you use it in everyday riding-but.....( a prime example is loosing midrange performance and then feeling a "hit" at say 10,000 rpm's that wasn't there before and thinking wow look at the performance improvement....when in actuality it was a performance loss)
ZX I actually own a dyno-so other than time costs and actual electrical usage it is free to me, and since you have access, I assume you work somewhere who has one, so dyno time for you should be free/cheap...unless you just mean someplace close to you will run your bike for you? And most dyno facilities have some day where they run bikes for $20 a run or some such "promotional bullshit". I do as does nearly ever place with a dyno near me.
I have done testing of many "mods" on many different bikes and some of these mods actually don't help, they actaully loose performance (much like the example I gave above), while others actaully do make improvements-some more noticeable than others.
The ZX6 jumper mod is certainly one of those that actually gives the most noticeable of gains without sacrificing performance in the midrange-that would be tops on the list for an actual "free" mod that actually works and benefits you.
ZX-what was your dyno numbeer before any of those mods??
Old 01-17-2011, 08:44 AM   #13
nexia201's Avatar
I Ride: zx6r 636 04
from where you get to buy the short stacks to change the middle ones?
nexia201 is offline
Old 01-17-2011, 08:49 AM   #14
nexia201's Avatar
I Ride: zx6r 636 04
Riverzzr is right you need to have a point of reference . i did the secondry flies removal and im sure that if i didnt have the advancer on the bike it woulod suffer too much coming out of slow bends so where that would maybe be a good mod for the 1/4 mile it wouldnt be so great for the cucuit in my opinion as its exactly as riverzzr said what happens is the bike power comes like a switch low end you have no power then when power comes on you feel that its a lot
nexia201 is offline
Old 01-17-2011, 10:04 AM   #15
zx racer's Avatar
I Ride: 04 ZX-636
any kawi dealership can order them for you or you could just pick up a airbox off ebay and just use the short stacks out of it.
03 636 mods
03 zx6r mods
04 636 mods
04 zx6r 636 mods
05 636 mods
05 zx6r mods
06 636 air mod
06 636 mods
06 zx6r mods
636 mods
636 power mods
best mods for a 636
cheap zx6r mods
mods for 03 636
power mods 06 zx6r
zx636 mods
zx6r 09-11 mods
zx6r 636 mods
zx6r cheap mods
zx6r mods 06
2011 mileage/ mods kninja Motorcycle Talk 14 02-11-2012 01:26 AM
04 zx636 mods d1andonlyant Motorcycle Talk 12 01-11-2012 11:42 AM
hp/performance mods wrathin The ZX6R 3 12-24-2010 07:23 PM
Just installed new mods for my 05 ZX6R woop! PHo The ZX6R 11 07-30-2009 01:23 PM
