03 636 vs. 07 ZX-6R
This is a discussion on 03 636 vs. 07 ZX-6R within the The ZX6R forums, part of the ZX6R Forum category; Ok, so some of you know that I totaled the 636 and bought an 07, the 636 was only cosmetically damaged so I kept it ...
Old 12-11-2010, 10:44 AM   #1
EvilTwin's Avatar
I Ride: 07 ZX-6R street, 03 636 track
03 636 vs. 07 ZX-6R
Ok, so some of you know that I totaled the 636 and bought an 07, the 636 was only cosmetically damaged so I kept it as my track bike. My kawasaki instructor absolutely raves about the the P model 6Rs (07-08) says they're lighter more powerful, turn quicker blah blah blah. Well I will say the the 07 is a nice ride and feels more rigid and solid than my 636, BUT I'm not convinced it's the better bike, so I decided to the compare numbers in the manuals and heres what I found.
07 does have more HP stock: 125 vs 118
Dry weight has the 636 lighter by 13lbs: 355 vs 368
But to be fair it takes .26 more gallons of gas and .2 more qts of oil, and who knows about the cooling system, so they may be pretty close there.
Now here's where it starts to get interesting:
636 dimensions:
Wheel Base - 1,400mm
Road Clearance - 130mm
Rake Angle - 24.5
Trail - 95mm
07 dimensions:
Wheel Base - 1,405mm
Road Clearance - 125mm
Rake Angle - 25
Trail - 110mm
This means that the 07 sits lower, has a longer wheel base, and has a rake and trail that will make it a little slower to turn in; by the numbers at least. Now I havent ridden the 636 since I got the new bike, so I can't give an completely accurate side by side comparison... but I can say that I miss riding the 636 b/c I remember it being easier to put into a corner and go through the really tight twisties that are my roads of choice. However if you were to decrease the trail on the 07 by 13mm and bring it to 97mm (wich is the ideal number according to my Suzuki instructor who used to be lead R&D at RaceTech) that would make the 07 lower, shorter, and have a much better trail which could make it turn faster than the 636. I might have to play with this. Also I realize there are factors that I am not taking into account such as center of gravity, perhaps the 07's is lower, idk; I really just need to get back on the 636 and see if I still feel the same way.
Oh and one more thing, the 07 destroys the 636 in compression ratio with 13.3:1 vs 12.8:1
And lets face it, the B model 636's are just way prettier than the P model Zx-6Rs
EvilTwin is offline
Old 12-11-2010, 01:42 PM   #2
lil_shane84's Avatar
I Ride: 08 ZX-6R SE
where did you get your HP numbers from cause they definantly aren't right
lil_shane84 is offline
Old 12-11-2010, 01:59 PM   #3
kawasakifreak77's Avatar
I Ride: as fast & far as I can.
All I know is I rode a '07 right when they came out & instantly felt better about getting my 636. The '07 felt less powerful, less nimble, ect. Just sayin'...
kawasakifreak77 is offline
Old 12-11-2010, 02:01 PM   #4
Huslnuracing's Avatar
I Ride: DIRTY!!!!!
the hp numbers dont seem right to me
Huslnuracing is offline
Old 12-11-2010, 02:17 PM   #5
zx racer's Avatar
I Ride: 04 ZX-636
you must got the hp numbers switch around bc the 636 makes more power than the 07-08 zx6r did, i had a 07 zx6r and it was down on power and felt heavier than my 04 636 did but i will say it handeled better and had way better brakes.
zx racer is online now
Old 12-11-2010, 02:28 PM   #6
I Ride: DIRTY!!!!!
maybe one hp reference is at the crank? the other at the wheel? im just saying you have to watch out were u get your hp numbers from, i looked at a site that said the 03 only had 96 hp, and another said the bike 135hp so the only real way to know is to dyno both bike on the same dyno imo
Old 12-11-2010, 03:21 PM   #7
I Ride: 2007 ZX6R
Kawasaki ZX-6R 2003: technical specifications
this says the 03 has 125hp...
I thought the 07 was underpowered compared to the 636's too.
NZX6r is offline
Old 12-11-2010, 04:28 PM   #8
I Ride: 03 zx6r 636
636 ftw...
carlmatthew is offline
Old 12-11-2010, 04:48 PM   #9
EvilTwin's Avatar
Like I said in the OP these numbers are form the Service Manuals. The head kawi instructor insists that the 07 has more hp but it's way smoother than the 636s so some people feel like they aren't as powerful, I tend to agree with them, doesn't always feel like the 07 is pulling as hard. That being said, the motor in the 07 is a completely re-design, so it seems like it should be a better motor, smaller more powerful; it does rev higher and have better compression.
EvilTwin is offline
Old 12-11-2010, 05:02 PM   #10
gogoKawi's Avatar
I Ride: 08 ZX6, 08 250
Check out the sites below. They have the specs. Power wise, the 636 crushes the 07-08. It's the only thing I dislike about my bike. Compared to other 600's, the low/mid range sucks. Handling, the 07-08 has the edge. Weight, I'm actually surprised by this. To me, all of the zx6's pre 07 felt heavier. Maybe it's the center of gravity on the bike.
2008 Kawasaki Ninja ZX-6R specifications and pictures
2003 Kawasaki ZX 6 R specifications and pictures
gogoKawi is offline
Old 12-11-2010, 05:45 PM   #11
I Ride: DIRTY!!!!!
that all makes sense
Old 12-11-2010, 08:23 PM   #12
twilliams83's Avatar
I Ride: 2007 ZX-6R Trackbike
I am posting some HP and stock spec info for you guys on most of the ZX-6Rs inculing the ones above and we as we all know the 636 is supreme still I have ridden plenty of 07s and even 08 zx6rs and they feel great to ride but they really dont compare when you ride them one after another (07-08 after 636) or when you race the two against each other. Here is the spec charts, use it for whatever:
These charts are from Kawasaki, remember these are hp ratings at the wheel, not sure what Kawi says about the engine hp ratings themselves, but power at the wheel is really what matters and weight.
twilliams83 is offline
Old 12-12-2010, 11:47 PM   #13
EvilTwin's Avatar
Idk why you guys are getting all bent out of shape about the HP, when theres such a small gap the handling capabilities of the bike are more than capable of making up for a 10hp diff.
That and there is no F-ing way the 07 zx6r is running a 13.9:1 compression ratio, I would have to be running something a little nicer than premium pump gas to keep it from detonating if that were the case.
EvilTwin is offline
Old 12-13-2010, 01:52 PM   #14
I Ride: DIRTY!!!!!
im not getting bent out of shape, i was just sating they a seemed a little off to me
Old 12-13-2010, 02:12 PM   #15
kone35's Avatar
I Ride: 2001 j2
Fuck it! It's a ninja so the numbers don't matter anyway.
kone35 is offline
03 zx6r 636 specs
03 zx6r specs
03 zx6r vs.
07 zx6r compression
07 zx6r hp
07 zx6r vs 636
2003 zx6r 636 tires
2003 zx6r vs
2008 kawasaki zx6r vs a 636
2008 zx6r p model specs
how much horsepower does a kawasiki 636 has
how to make the most power out of 07 zx6r
hp power kawasaki zx6r 2001
is a 05 636 faster then a 07 zx6r
is a zx-6 faster than 636
is an 07 zx 6 faster than a 636
wheel base on a kawasaki 636
zx6r vs 636
zx6r vs 636 hp
FS: ZX-6R parts, ZX-6R 636 parts, and gear. ZX6RJosh636 Classifieds 4 03-21-2012 11:06 PM
05 zx10 front end on 03-04 636 jeremyRockit The ZX6R 5 02-06-2012 04:56 PM
Serious drool factor 636 parts. kawasakifreak77 Classifieds 9 12-12-2011 09:24 AM
636 mile on my 636 lucky110 The ZX6R 30 09-21-2011 06:53 AM
Remembering the Ninja ZX-6R 636 twilliams83 The ZX6R 5 08-18-2011 05:31 PM
