Engine swap - ZX6R Forum
post #1 of 13 Old 06-28-2007, 05:27 PM Thread Starter
beever03's Avatar
I Ride: 03 ZX636R
Engine swap
Does any one know if a 05-06 engine will swap into a 03-04 frame? Just made lunch of my 03/636 engine and cant find 1 anywhere, or how about a ZX10 engine. Now that would be nice wouldn't it
beever03 is offline
post #2 of 13 Old 06-28-2007, 08:34 PM
josh636's Avatar
I Ride: 2004 ZX636
if your've got the skillz, a welder and a large hammer, you can make it fit
I suspect the later model engines won't fit the 03/04 as kawa changed the frame in the 05/06 and 07 models
Just ride the dam thing!!!
josh636 is offline
post #3 of 13 Old 06-28-2007, 08:43 PM
Quarkz's Avatar
Regarding the 10R. I'd say no. The swingarm and chassis is built for a 600cc motor, not a 1000cc. It wouldn't handle the torque. You're going from a 110hp motor to a 160hp one, there's bound to be a little bit of flex. Of course, the tolerance it would have would probably be substantial but you'd probably be better off just buying a 10R and be safe.
Not sure about the 05 6R one. Of course, anything is possible with modification.
Originally Posted by crashtd View Post
oh and Quarkz got a puppy. PM me to get in on the pool for how much time passes before she eats it.
Quarkz is offline
post #4 of 13 Old 06-28-2007, 11:32 PM
bigbike-r's Avatar
I Ride: 1985 gsxr 1999 bandit 1200 zx6r
i say go for it,......... any thing will fit with a slight modification i wouldnt worry about the frame been built for a 600 the gsxr slabby can only just about handle its own 750 motor but plenty people shove 1100 in them to build 7/11's but then im new to the zx-r's and havent really any experience with them so i could be wrong but the frames are rather big and cudddly compared with the slabbys thin rigid frame?
HARLEY DAVIDSON :- the process of turning fuel into pure noise without the side effect of horsepower
bigbike-r is offline
post #5 of 13 Old 06-29-2007, 09:45 AM
caker_chris's Avatar
I Ride: 2006 Kawasaki ZX636R
I am with Quarkz on this one. The frame and swing are not made for a 1000 motor and i know they were having a hard time with some of the zx10r frames twisting a few years back, imagine what it would do to the 6.
If you were to try and put a 1000 motor in the 6 i would get a very good frame guy to look into it and strengthen the frame if needed before chancing it.
Yoshimura RS-5 Slip-On
K&N Air Filter
Afam Sprockets (-1 front)
D.I.D. X-Ring Racing Chain
Vortex Frame Sliders
Galfer Braider Lines
EBC HH Sintered Brake Pads
Dr. FX fender eliminator
Clear Alternatives Integrated Tail & Flush Signals
caker_chris is offline
post #6 of 13 Old 06-29-2007, 05:04 PM
alor14582's Avatar
I Ride: 2006 ZX-6r
frame will not take it
next track day july 28,29
alor14582 is offline
post #7 of 13 Old 07-01-2007, 03:10 AM
lee6r's Avatar
I Ride: 2003 Kawsaki ZX636R B1H - Blue, the fastest ones.
zx10r frame goes OVER the engine not ROUND it like on a zx6r!
Do all Horses have 1 horse power? Think about it.....
lee6r is offline
post #8 of 13 Old 07-01-2007, 06:12 PM
signal's Avatar
I Ride: 03 636
a guy on psychobike.com did a turbo 10 motor in his 03 636. he basically had to cut the frame in half and do alot of fabrication.
http://www.ninja6zone.com/forums/image.php?type=sigpic&userid=488&dateline=11792702  63
signal is offline
post #9 of 13 Old 07-01-2007, 08:58 PM
yeah but he probably also made plenty of braces to keep the frame's rigidity!!
m R g S r is offline
post #10 of 13 Old 07-04-2007, 07:42 PM
PIPES's Avatar
I Ride: 1999 ZX6-R
he could also be in ICU right now.
SKINNY LITTLE PUPPY AIN'T HE??
! I RIDE A LIME GREEN SNATCH MACHINE!
PIPES is offline
post #11 of 13 Old 07-04-2007, 11:33 PM
signal's Avatar
I Ride: 03 636
talked to another guy, everything bolts up on an 05-06 engine except one mount, so he left that one out and it was fine.
signal is offline
post #12 of 13 Old 08-12-2008, 09:28 PM
Hey all,
I have an 02 ZX6R, would an 03 636 fit?
PrinceK is offline
post #13 of 13 Old 11-11-2013, 09:23 AM
05 to 07 engine
I I am buying a 07 zx6r with 20k miles on it but I found a wrecked 05 with low miles for $600 parts and engine I was wondering if I could switch the engine and other parts from the 05 to the 07 thanks for your time
chuckbox is offline
02 zx6r engine swsp
03-04 zx6r engine
2000 zx7 engine swap zx9
does a 2006 zx636 engine fit in a 2004 zx636 frame?
how to make 05-06 zx6r engine fit an 03-04 frame
what all motors can fit in 03 zx6r
what size engine can fit into a 2003 kawasaki 636
will a 07 08 motor fit in a 05 06 frame for a kawi 636
will a kawasaki gpx250f engine fit in a zxr frame
would 06 zx6r motor fit 04 zx6r
zx6r engine swap
zx6r motor swap
engine swap 07pzx6r Motorcycle Talk 8 12-31-2011 08:09 AM
Engine swap neno The ZX6R 3 06-13-2009 05:56 PM
Engine swap 636freak The ZX6R 9 05-29-2009 08:17 PM
