Stock projector removalThis is a discussion on Stock projector removal within the The ZX6R forums, part of the ZX6R Forum category; I have a 09 and I recently put in a ddm 55 watt 5000k hid kit, I love it but I am not so in ...  |
03-09-2011, 06:14 PM
#1 | | Squid
Joined: Mar 2011 From: Montville, Nj Posts: 7 | Stock projector removal
I have a 09 and I recently put in a ddm 55 watt 5000k hid kit, I love it but I am not so in love with the stock projectors. I am looking to switch out the stock projectors and install true bi-xenon projectors so I can have two headlights with true low and high beam functionality. Has anyone opened up the stock headlights and removed the stock projectors or does anyone know if it is possible to remove the stock projectors. If anyone has done so and has pictures please share them.
This is the kit I am looking to install. Bi-xenon Morimoto Mini Stage III Kit (D2S) - Complete Retrofit Kits from The Retrofit Source Inc |
03-09-2011, 06:37 PM
#2 | | Superbike Champion
Joined: Sep 2009 From: Rancho Cucamonga CA Posts: 870 I Ride: 2004 kawasaki zx-6r |
i had put together a kit from various parts from that site, using those shrouds, came out to about 400 something, that looks like a lot better of a deal! let me know how that goes!
i never bought them, sorry i cant be of any help
03-10-2011, 08:00 AM
#3 | | Squid
Joined: Mar 2011 From: Montville, Nj Posts: 7 | Quote:
Originally Posted by bradlee08 i had put together a kit from various parts from that site, using those shrouds, came out to about 400 something, that looks like a lot better of a deal! let me know how that goes!
i never bought them, sorry i cant be of any help | Did you ever end up installing all the stuff. The thing that is holding me back from diving in to it right now is I absolutely do not want to have to do any cutting of the headlight. (I like to always have the ability to return to stock) Im simply just trying to find out if it is possible to remove the stock projector bowl and the lense. The cool part about this kit is that they say you will not have to do any cutting because of the way the new projectors are mounted.
03-10-2011, 08:08 AM
#4 | | World Superbike Champion
Joined: Dec 2010 From: Santa Maria, ca Posts: 2,419 I Ride: 2007 ZX-6R | |
03-10-2011, 08:38 AM
#5 | | Track Star
Joined: Oct 2010 From: Boston Posts: 310 I Ride: 04 zx6r |
I did a Retro Fit on my 04 but I used led's as my Low beams with Halo Rings and the Hi's were the HID pair. I have a set of Bi xenon projectors but would not want to install them to their full functunality. Seems there would be some hacking going on into the factory harness and relays in order to make the the Bi xenon's work properly with the Shrud Opening and Closing to make the output of the light change. My Advise is just leave it as is. I think the most time was spent in making the Projectors line up properly which you would probably have to do seeing the projectors are for universal applications and not speciffically for the bike. Just my .02
03-10-2011, 08:58 AM
#6 | | Squid
Originally Posted by joeyzx6 | I already have HIDS DDM tunning 55 watt slim ballast, I want to switch out the actual projectors and put in true bi xenon projectors.
I hear ya es617, just the stock projectors while not terrible are not the best and were not designed for use with hid bulbs. The focus pattern of the light now with the hids is kinda off there is alittle bit of a dark spot in the center of the light pattern just under the cuttoff line. (due to the hid bulbs being longer then the halogen oens) I think I just may have to open up the headlights and see if this is going to be a project that will be do able without cutting the headlight to pieces to remove the old projectors and install the new. And interms of hacking into the stock harness, I think that may be avoidable. I know I will need to find a power supply for the motor on the new projectors which opperates the shutter but I could always use a splice connector for that and avoid any cutting of the harness.
03-10-2011, 09:41 AM
#7 | | Track Star
Joined: Oct 2010 From: Boston Posts: 310 I Ride: 04 zx6r | Quote:
Originally Posted by thelaxman I already have HIDS DDM tunning 55 watt slim ballast, I want to switch out the actual projectors and put in true bi xenon projectors.
I hear ya es617, just the stock projectors while not terrible are not the best and were not designed for use with hid bulbs. The focus pattern of the light now with the hids is kinda off there is alittle bit of a dark spot in the center of the light pattern just under the cuttoff line. (due to the hid bulbs being longer then the halogen oens) I think I just may have to open up the headlights and see if this is going to be a project that will be do able without cutting the headlight to pieces to remove the old projectors and install the new. And interms of hacking into the stock harness, I think that may be avoidable. I know I will need to find a power supply for the motor on the new projectors which opperates the shutter but I could always use a splice connector for that and avoid any cutting of the harness. |  TRUUE.....I thought you wanted to use the Stock hi/low beam switch. Thats why i said the hacking would be done but you can easily do it this way with a external switch to the shrud motor. Best bet buy a set of headlights that way if you fuck up you can always just put the set thats untouched on. I sourced a extra set for my 04 when i had some people interested in me making them a retro fit but they never came through so now i have 3 oem head lights which im thinking going crazzy with one of the sets and even adding 4 Smaller sized projectors  but id have to be really bored to mingle with that project
03-10-2011, 12:04 PM
#8 | | Squid
Yea im going to begin my search for a used headlight housing I can begin work on.
03-10-2011, 12:10 PM
#9 | | Superbike Champion
used housing are super expensive! i also thought to do this, and no i didnt actually get into the housing, although that was the plan and what will happen when i do order them
03-11-2011, 05:51 AM
#10 | | Squid
Ive found some used headlight assemblies on ebay under 200 so I guess im going to just have to get one and give it a shot.
| | | Search tags for this page | | 07 zx6r hid morimoto, 2004 zx6r bi xenon install, 2007 zx-6r oem projectors, hid kit 2009 zx6r stock projectors, how to install morimoto hid kit install 2007 zx6r, how to put ptojectors in zx6r, zx6r halo ring size
