Lights are in!!This is a discussion on Lights are in!! within the The ZX6R forums, part of the ZX6R Forum category; Originally Posted by dash8
ahhh that makes sense....
so the kit from DDM is PNP?, pull out old bulbs, put in new bulbs (PLEASE tell ...  |
02-20-2012, 10:33 PM
#46 | | Squid
Joined: Oct 2011 From: Orlando, FL Posts: 80 I Ride: 2011 zx6r lime green | Quote:
Originally Posted by dash8 ahhh that makes sense....
so the kit from DDM is PNP?, pull out old bulbs, put in new bulbs (PLEASE tell me I don't have to remove front fairing lol) and secure the ballasts in? any wiring to do, or does it plug into existing connectors? So it is better to get the 9's or 11's for simplicity on a 2009?
thanks for the help! | Yes everything if plug n play. Only one way for the connectors to go in. You don't have to remove the front fairing, but it would be easiest if you remove the black plastic panels just below the handlebars to mount your ballasts underneath those areas. Also, if you order from DDM, I would recommend that you ask if they can send you a kit that comes with male H11 connectors. The kit I received from them just came with two spade terminals for each bulb that plugs into the pins of the OEM harness leaving it all exposed. They say to wrap it in electrical tape, but I don't like that idea. I'd much rather have the appropriate connector. Just specify either an H9 or H11kit when ordering and you'll be golden. Doesn't matter which one.
02-20-2012, 10:40 PM
#47 | | Superbike Champion
Joined: Sep 2011 From: Milton, Ontario, Canada Posts: 1,052 I Ride: 09 ME ZX6R | Quote:
Originally Posted by naked6 Yes everything if plug n play. Only one way for the connectors to go in. You don't have to remove the front fairing, but it would be easiest if you remove the black plastic panels just below the handlebars to mount your ballasts underneath those areas. Also, if you order from DDM, I would recommend that you ask if they can send you a kit that comes with male H11 connectors. The kit I received from them just came with two spade terminals for each bulb that plugs into the pins of the OEM harness leaving it all exposed. They say to wrap it in electrical tape, but I don't like that idea. I'd much rather have the appropriate connector. Just specify either an H9 or H11kit when ordering and you'll be golden. Doesn't matter which one. | outstanding, thanks for leading me thru this... if I can get them to drop the shipping charges a bit, I'm going to order tomorrow!
02-21-2012, 08:57 AM
#48 | | Superbike Champion
Oh another question, is it possible to angle the high beam Down enough so that when running both lights they are burning someone's eyeballs out?
And, I can still run lights on low beam with only one light one, right?
Ya, I may seem dense, I blame it on lack of sleep with a newborn boy |
| | | Search tags for this page | | 03 zx6rr bulb size, 07 zx6r bright light adjustment, 07 zx6r bulb size, 07 zx6r high beam adjustment, 07 zx6r led nose, 08 zx6r running light bulb, 2007 zx6r city light lens, 2007 zx6r city light problem, 2009 2010 2011 zx6r ballast mount, 2009 zx6r high-beam replacement bulb, 2009 zx6r how to mount tail light, light bulb brachet on 03 zx6r, removing city lights from zx6r, running lights bulb zx6r 09, what bulb is for the hi beam on 2006 zx6r, what is a zx636 right city light, zx636 lights, zx6r 09 bulb sizes, zx6r city lights, zx6r ufo tail light
