this is a reply to self and to maybe enlighten some of you on here who might want to know for various reasons:O any one one with a 2007-08 zx6r can put the 09-10-11 zx6r motor in your frame its a straight bolt in cporrectly done you would need matching harness im not sure about the ecu:coocoo i think its same but carbs are slightly different and two sensors on the 07 08 motor are deleted or relocated in the 09 and up so if you pop your motor any 09 10 11 zx6r will fit making the choices many for us and i know cause i have a 98 zx6r which i cut and fabricated new motor mounts to accept the 07 zx6r motor and airbox ecu wire harness ect blew it up and swapped as of tonight over to a 2010 motor with complete harness ecu and all new matching componetes pc5 speedo healer tre block off plates full k&n full yosh r77 carbon system jumper mod still doing some wiring but it started and ran fine ,,hope that might help someone :idea:
Good stuff man. I have a 07 and would love to drop in a 09 and up. I wonder if the wireharness from a newer model would work. I don't see why it wouldn't. Just swap the dash with a fabricated bracket. Yay!!!!
the dash is the same same mounts exactly from 07-2011 and is just a plug you can put 2011 gauges on a 07 no problems even if you just like the new look of the gauges and the harness you can get very easy for 100 on ebay they relocated some many more things on the 09 like someone actually sat down with a college degree and figured out where to put the fuse box and rectifer its wiring is laid out much better you can use the 07 gauge on the 2011 motor too and if your sick of the undertail mount exhaust (((ANY))) exhust side mout that fits a 09 too 2011 zx6r will bolt right up not any problems the motors are the same so you can do away with undertail; and use any exhaust you find or like for an 09 and up if you do a full system its 100 %brainless easy if you do a slip on only you will need to use the 09 or newer header with any slip on for instance atwo brothers vale slip on would need a 09 header on the 07 -08 zx6r but if purchasing any full system it bolts up 100 no problems
the cluster is 100 % universal from 07 to 2011 i know i had both and plugs are the same your good even mounts the same and its a nice looking upgrade and when your done you can get atleast 125 for yours when you sell it under 5000 miles you should fetch close to 200
yes sir i even have a video of start up but going to dinner with girlfriend for her birthday so icant post today ill try buut i have some pics under my profile or atleast one of my bikes in the tehcnical section you can see whats going on but ill get them up here asap
yeah the 07 header will work on the o9 motor deff 100%so you can keep the undertail exhaust but if you want a side mount then you gota use a 09-2011 model header i have a header for it if you decide
so heres som pics of the vasrious stages the ones in the first post with silver tail are of when i had the 07 motor in the 98 zx6r now the mones with the 03-04-636 tail and carbon tail are of the 09 and i still got some things to work on i had the tank changed a little to fit better and i now gotta paint it tha subframe i welded plates to and im polishing them now as some pics show befor i send it to chrome i wanna majke sure its a s nice as it can be keep in mind this is a 98 frame everything else is 05-08 zzr fairings 08 rims 636 swing arm and complete 06 636 front end forks 07 zx6r tank modded to frame and me and my machinist are working on fitting the new 2010 zx6r swing arm to my bike but it'll be a good month befor i do that and hopefully befor christmas im doing a complete front end from the 2011 zx10r forks and tripples but i leave for aruba in 3 days and will be gone for 7 days so i might not have any progress pics till i get back middle of june or by the 20th but i promise you if i say it is done will be or has been done already ,been ring and working on bikes for like 16 yrs so ik a good fabricator and what i cant do my metal machinist can he builds one off harleys and does stuff on the side and some of my special requests of mine ,, but keep up as this goes its gonna be fucking sick when done
so officially my 98 is a 08 zzr 600 look alike as fairings go but after that its all woop ass
