GAS CAP PROBLEMS! Dammit.... - ZX6R Forum
post #1 of 38 Old 08-06-2011, 04:47 PM Thread Starter
USMCBumbleBe's Avatar
I Ride: 2008 Kawasaki ZX-6R
Ok, friends... in need of some:
2008 kawi zx6r, went to fill her up at the gas station today and the key won't open up the lock. With fuel light on, made it home and tried everything I could think of; twisting, pulling, lubing(wd40), flipping key, wiggling key, key-fucking the lock, hitting the key (with my hand) into the lock, and I even tried taking the allen bolts out, but as you all probably already knew you can't take the assembly off with out it being unlocked. I'm so pissed about this...its such a small stupid problem, yet it fucks the whole bike over since you can't get gas in it. All they had to do was was make some sort of button that only works when the key is in the ignition but not started....this problem could be totally avoidable. But anyways, to me it feels like there is something physically obstructing the key from getting down into the lock, I'd say the last 1/16" or less.... It's ridiculous.
Any help would be appreciated.
2008 Vivid Yellow ZX-R
-Debadged, OES Frame Sliders and Rear Spool Sliders, LED Fender Eliminator w/ Brake Light and Turn Signals, Zentech 35w HID Conversion Kit, Global Motorsport 'Racing' Mirrors, Spiked Bar Ends, Blacked-Out Windshield, Color-Matched Rimstripes.
-Mods to come: Jumper Mod, Brake Reservoir Under-Seat Relocation, Remove Passenger Pegs, Solo Seat Cowl (en route), Shorty Levers, 12v USB Power Supply (en route).
"...The ashtray's full and I'm spillin' my guts. She wanna know, am I still a slut. I gotta take it on the otherside." -Red Hot Chilli Peppers
USMCBumbleBe is offline
post #2 of 38 Old 08-06-2011, 04:59 PM
hellonearth's Avatar
I Ride: 2007 zx6r :D
sounds bad but that happened to a firends honda and he had to drill out the lock and get a new cap
Flat Earth Bruh for life.
P model spark plug change! http://www.instructables.com/id/2008...k-Plug-Change/
hellonearth is online now
post #3 of 38 Old 08-06-2011, 05:01 PM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
Wow.. Lucky you got home dude.. Try getting a air gun and spraying high psi into the lock to see if some of the crap will come out? Does your bike live outside and have you got a spare key to try?
still lovin forever!
arron is offline
post #4 of 38 Old 08-06-2011, 05:02 PM
I Ride: 05 zx6r, 09 250r
hmmmm
Maybe try using an air compressor (if ya got one) or one of those keyboard air dusters (if ya don't) to see if its something small that will just blow out? I used my air compressor on the inside vent on the cap to clear it out and it worked perfectly- no more pressure build-up. Hopefully it isn't jammed too much in there from the key- wish I had better advice
NinjaRyder is offline
post #5 of 38 Old 08-06-2011, 05:02 PM Thread Starter
After this, I want nothing else but to get a new keyless cap, but I can't get it off and I don't know how to effectively drill out a lock
post #6 of 38 Old 08-06-2011, 05:08 PM Thread Starter
Unfortunately, it does live outside :/ I'm planning on trying to use an air compressor like yall havr suggested, however I have my doubts as to how that will work... That wd40 went in, and out, of thaf lock with a good amount of pressure and it didn't take anything out. I do have a spare key, good thing I do because I ended bending the original and it didn't want to go back into the ignition at the gas station! Lol thank god I didn't break it, I just bent it back and went on my way.
post #7 of 38 Old 08-06-2011, 05:12 PM Thread Starter
What could it be, and how could it be fixed, if there isn't some sort of debris down inside?
post #8 of 38 Old 08-06-2011, 05:18 PM
a very large drill bit right in the center on the lock and just be prepaired to drain the gas tank
post #9 of 38 Old 08-06-2011, 05:20 PM
hmmm
Well if it isn't debris (I would also try like a paperclip or something skinny to see if you can pick it out) then I would guess that the cap would have to get drilled out and replaced as already mentioned. Probably not the answer ya want to hear, but I can't think of another way
post #10 of 38 Old 08-06-2011, 05:23 PM Thread Starter
Are we talking 'large' as in it needs to remove the whole cylinder, or 'large' just to get inside the keyhole? What do you do once you've drilled it? How do you make the locking mechansim release? And finally, when you say drain, should I just syphon what fuel is left in there, or are you talking removing tank from bike and completely emptying?
post #11 of 38 Old 08-06-2011, 05:32 PM
large as in the size of the entire key hole or about 1/2 inch, drill it all the way through that and the locking mechenism should release, notice i said should cus i have no idea, then remove the entire gas cap, take the tank off the bike, and flush it to get all the metal shavings out. ive only heard of friends telling me how to do this so id definitly do more research on it.
post #12 of 38 Old 08-06-2011, 05:57 PM
raiders21911's Avatar
I Ride: 2000 zx6r
Try pushing down on the cap and turning the key. Worked for me once.
Iantee likes this.
raiders21911 is offline
post #13 of 38 Old 08-06-2011, 07:21 PM
mach6's Avatar
I Ride: 2006 zx636
That used to happen with my old bike. But it got totaled before I could figure out why or how to fix it, so I don't think i can offer much help. I have a vortex gas cap on my tank now. It doesn't use a key, just unscrews.
mach6 is offline
post #14 of 38 Old 08-06-2011, 10:22 PM Thread Starter
I have tried pushing down on it, in fact it was the first think I did. It's always been a little stiff, so that was something I've always had to do anyways. Thanks for the posts, guys. Anymore ideas, keep em comin!
post #15 of 38 Old 08-06-2011, 10:28 PM
arron's Avatar
Have you tried tapping the lock while turning? Drilling it out would be my last chance for it.. Graphite power works on locks too.
arron is offline
06 zx6r stuck gas cap
2004 636 kawasaki gas cap
98 ninja zx6r how to open gas cap
gas cap won't open on 05 kawasaki 500r
gas cap wont open on zx6r
how do you open a gas cap on a zx6r
how to fix a stuck gas cap on a 2002 kawasaki 1200 r motorcycle
kawasaki ninja gas cap problems
need gas cap 2005 kawasaki ninja 636 gas cap with lock
remove gas cap 07 ninja lost key
why is my zx6r gas cap raised up
zx6r gas cap stuck
06 Aftermarket gas cap oKayH The ZX6R 16 08-20-2011 11:12 AM
FS: 09 zx6r brand new twist off gas cap, 2 fuel pumps bperau Classifieds 3 06-13-2011 10:19 AM
Help! 2001 ZX6R dripping from fuel overflow and gas cap msa The ZX6R 13 07-18-2009 08:41 AM
Help! Need a 05-06 black gas cap!! TylerB42 Classifieds 3 04-05-2009 03:59 AM
can't get gas cap open! kellen The ZX6R 9 03-31-2009 02:03 PM
