What type of coolant should i use ??? - Page 2 - ZX6R Forum
 4Likes
post #16 of 44 Old 07-05-2012, 06:53 AM
escobar's Avatar
I Ride: 2006 zx636
Thumbs down
Originally Posted by Beard View Post
I run RedLine Water Wetter in the summertime.
It is hot as crap here and the humidity is close to 95% right now, bike barely ever gets over 200 in traffic. My average temps stay between 156 and 160 degrees F.
water wetter is a great additive. I know some who use only WW as coolant. They have no problems either but I wouldnt do that
escobar is offline
post #17 of 44 Old 07-05-2012, 07:00 AM
just use water...unless your running your bike in the winter season
06sixdirty6 is offline
post #18 of 44 Old 07-05-2012, 07:06 AM
DaddysNinja's Avatar
Distilled water. And I mix distilled water and water wetter and in the hottest of traffic my bike never goes over 205.
asteger1 likes this.
Nil conscire sibi
SOLD 2007 ZX6R 03/29/2013
Only once.
Originally Posted by SkyChimp
DaddysNinja is offline
post #19 of 44 Old 07-06-2012, 05:23 AM
MOTOcityride's Avatar
I Ride: 09 zx6r 06 cbr1k
i put W/W and distilled water in my system after doing a complete flush. i rode the bike this morning and it was actally kinda chilly. bike temp still reached 220?? why is it still running hot?
normally temp only reaches 180-190 during my morning ride to work. i want to switch to 50/50 prestone but im not sure if that will fix my overheating problem
Originally Posted by givuhcky22 View Post
ER is for pregnant chicks.
i've got a broken vertebrae. guess who's still lifting, riding, hip thrusting, party rocking, and more lifting.
MOTOcityride is offline
post #20 of 44 Old 07-06-2012, 07:49 AM
hulkmn069's Avatar
I Ride: 2007 ZX6R
don't do this, you need some kind of additive for lubrication and corrosion protection.
But to thug just get some 50/50 whatever antifreeze to top it off. Or just add a little water if you've not lost that much.
Originally Posted by filthy666 View Post
turned green,ripped clothes and tore a car in half
hulkmn069 is offline
post #21 of 44 Old 07-06-2012, 09:15 AM
zx6ixxer's Avatar
Do a flush mate,
1. Drain all the coolant (from all different drain holes)
2. Flush the system with distilled water
3. Refill with fresh coolant.
4. Run the bike with the radiator cap off and tap all hoses to free trapped air, (you should see some of the coolant bubble by the radiator filler neck (where the cap is)
5. And wallah! bike should run nicely.
If not....and this is where i had a problem, Pull your thermostat out and check if its operating under the right temps (i.e. opening and closing)
zx6ixxer is offline
post #22 of 44 Old 07-11-2012, 03:26 AM
ZX6Ray's Avatar
Distilled water and water wetter or running just distilled water isn't a long term solution. Just water alone doesn't negotiate any lubrication/anti-corrosive properties and hey it's your bike- do what you want to do...
Running water wetter and water is good but it is also not a long term solution. You will have to change it out at least once every 3 months. It is only designed for the racetrack in which you will have to change it out every other track day.
OK so you don't want to spend $50 on engine ice... You have to change it out every year anyway... Not your thing? I understand.
Toyota and Honda both sell high quality coolant that can be used for our bikes. Toyota has the red coolant which lasts 4-5 years at a 50/50 ratio. Honda has the type II blue coolant which also lasts about the same (don't quote me). It's $20 for a gallon of the toyota red which yields 2 gallons at 50/50. The honda type II sells for $15 for a gallon pre-mixed. Both are excellent coolants with top of the line anti-corrosive and lubrication properties.
And if you are really cheap... Like joe dirt cheap... You can always put that prestone or that no frills coolant from your friendly neighborhood parts store in your bike. Save that shit for the single moms with 5 kids or the redneck hillbillies. I treat my bike a lot better than that.
Throttle up, knee down and pray!
My monster decals make 20 ft-lbs of static pressure transducer horsepower to the vtec controller boost gauge!
Originally Posted by MistressOfMayhem View Post
Tell me, oh wise one of the Monster Regime, instead of putting NOS in your gas tank, is your bike powered by Monster?
Originally Posted by Starscream View Post
I'll stick to KNOWING my 09 makes 124.5whp with just a filter, full LV system and a tune.
Originally Posted by renzovc16 View Post
Waz up hommies i just got my led glow lights in da mail from ebay !
ZX6Ray is offline
post #23 of 44 Old 07-11-2012, 11:05 PM
Lawanda's Avatar
I Ride: 6thirty6 stretched and slammed babay
babay let miss jenkins tell you what you got ta do...
you got ta gitchoself some popeyes chickin... now you make sure you snick in the back door sos you kin gitchu a few cups o dat chickin grease....
make sure iss hot cos whin you put it in you radiator iss gonna conjeel. when yo bike giss hot it will keep dem hosses all nice and slickety slickety... and yo bike will run smoooooooooooooth...
Lawanda is offline
post #24 of 44 Old 07-11-2012, 11:30 PM
kone35's Avatar
I Ride: 2001 j2
kone35 is offline
post #25 of 44 Old 07-11-2012, 11:33 PM
lil636's Avatar
I Ride: 06' 636
Lawanda is back!!
Back on topic, thanks for the info ray, I need to do a flush here soon, might try some of the toyota stuff.
SD Pit Stop , FB group for SD area riders.
Originally Posted by 714reyesj View Post
i just plastidip my cock so i dont have to carry condoms around
Originally Posted by whippet264 View Post
and when i say budget i obviously mean wife....
lil636 is offline
post #26 of 44 Old 07-12-2012, 12:02 AM
Death1799's Avatar
I Ride: 07 zx6r
engine ice ftw
Death1799 is offline
post #27 of 44 Old 07-12-2012, 12:27 AM
emiller480's Avatar
I Ride: 2006 ZX6RR
I changed out the coolant in my bike today and used prestone 50/50 and the bike has been running fine in the brutal Phoenix heat. of course the ww and engine ice type stuff is better but I have to prioritize my expenditures.
emiller480 is offline
post #28 of 44 Old 07-12-2012, 06:55 AM
ZX6Ray's Avatar
So I see you are right there with the redneck hillbillies and single moms on a budget...
ZX6Ray is offline
post #29 of 44 Old 07-12-2012, 09:00 AM
zx6ixxer's Avatar
you know...i did the same thing as emiller480
And for some stupid reason my Bike has been running cooler with prestone 50/50 than when I did my first flush and used actual "motorcycle coolant" from the stealership
So call me a hillbilly too....but it worked
zx6ixxer is offline
post #30 of 44 Old 07-12-2012, 09:11 AM
really? i might have to use prestone on my next change. using w/w and distilled water right now, didnt know that it had to be changed so often.
1996 antifreeze kawasaki
2006 kawasaki ninja 636 coolant type
add coolant in kawasaki ninga zx6r
antifreeze for kawasaki ninja
coolant for zx6r
engine coolant does a kawasaki zx6r take
kawasaki coolant
kawasaki coolant type
prestone coolant kawasaki ninja
what kind of coolant for a 2008 kawasaki zx-6r ninja take
zx6r antifreeze
zx6r coolant type
brown liquid in coolant overflow? cupofjoe The ZX6R 18 11-20-2011 04:26 PM
06 zx6r coolant? brittany Mechanical and Technical 4 10-06-2011 10:46 AM
Glad I decided to change my coolant usdsk8er540 Mechanical and Technical 28 06-04-2011 01:24 AM
Coolant problem fixed Street Hawk Mechanical and Technical 6 05-16-2011 07:28 AM
The mystery coolant leak - now solved! Gary P The ZX6R 12 11-20-2009 05:07 PM
