Slipper Clutch on a G1 - ZX6R Forum
post #1 of 15 Old 12-29-2011, 04:03 PM Thread Starter
2006foxx's Avatar
I Ride: '98 ZX6R (Street), '98 ZX6R (Track - Coming soon!), '08 CBR 600RR
Ok, before the world chimes in and gives me the business about there not being a slipper clutch on
a G1 - I'm looking at the potential ability for there to be one installed.
So here's what we know:
STM, Sigma & Yoyodyne all make a slipper clutch for the
ZX6R 2005-2006
Barnett says the following bikes need the following plates for their clutches
.........................Friction (Qty.)......Steel Plates (Qty.)....Spring Kits
1995-99 ZX6R......301-70-10035(9)...401-45-089011(8)....501-50-04116
2000-02 ZX6R......301-70-10035(9)...401-45-063011(8)....501-50-04116
2005-06 ZX6RR.....301-70-10035(8)..401-45-063011(*)....501-58-06121
.................................................. .401-45-078011(*)
.................................................. .401-45-089011(*)
*As Required **Re-use OEM Double Steel Plate
So if you're paying attention thus far these three generations have the same clutch with the only difference
being the number of plates and the springs (for 2005-2006 - Willing to bet this is due to the springs being shorter).
Sooooooo... does this mean the slipper clutch from the 2005-2006 ZX6RR can be installed on the G1 & J1
(brief pause while we wait for EvilTwin to respond)
Or is there also some difference in the tranny that makes it possible to use this clutch (I bet that answer is no)?
(Why do I want to do this you ask - easy, I'm bored )
No officer, I have no idea how fast I was going, but since I'm sitting here talking to you I guess it wasn't fast enough...
'98 ZX-6R: Yoshi RS-3 Full, K&N Air Filter, Zip-Tie Mod, Kleen Air Mod, Jet kit installed.
Coming Soon - ZX-12R Forks & Triple, Steel Braided brake lines, Adjustable Rearsets,
Cryo-treatment on Engine internals, Sick Vinyl Wrap.
2006foxx is offline
post #2 of 15 Old 12-29-2011, 04:11 PM
yoshi's Avatar
I Ride: a 2006 zx6r
they might use the same plates etc but im pretty sure the basket etc will be a different fit.
Formerly known as rotax81
My Facebook
Facebook
My Youtube Channel
yoshi is offline
post #3 of 15 Old 12-29-2011, 04:13 PM Thread Starter
2006foxx's Avatar
Yeah that just occured to me as well, but I don't know if that really matters actually. Reason being - the slipper clutch sits inside the clutch basket, and actually inside the the inner diameter of the clutch plates. So in theory it should fit since the plates are the same. I think then the real question is the size and thread of the drive shaft on the three generation bikes.
Last edited by 2006foxx; 12-29-2011 at 05:02 PM. Reason: greater understanding of how the slipper clutch works
2006foxx is offline
post #4 of 15 Old 12-30-2011, 09:58 AM
greenmeeny's Avatar
I'm putting one in an 03 636. I found the outer basket was the same for 03-06 rr & 636. The clutch/output shaft length is the limiting factor, so put a slipper one in and then the inner slipper basket+plates. I eyeballed (counted a lot of outer basket teeth) and compared part#'s.
greenmeeny is offline
post #5 of 15 Old 12-30-2011, 10:02 AM Thread Starter
2006foxx's Avatar
Sweet, so I'm right the question is the shaft not the basket. Thanks for the answer to that Green. Now I just need to determine if the shaft is different on the 99 from the 05-06 rr.
2006foxx is offline
post #6 of 15 Old 12-30-2011, 10:26 AM
scoobs's Avatar
I Ride: something naughty
can i just ask ....why do you feel like you want a slipper clutch for road use ?
scoobs is offline
post #7 of 15 Old 12-30-2011, 11:14 AM Thread Starter
2006foxx's Avatar
Fair question... lol
I actually have no real use for it on the road.
But until I rebuild this second zx6r sitting in my garage
this bike will be pulling double duty as a track & street bike.
2006foxx is offline
post #8 of 15 Old 12-30-2011, 11:16 AM
scoobs's Avatar
ok fair enough.....just thought it was an over kill for the street but for the track its the ticket
scoobs is offline
post #9 of 15 Old 12-30-2011, 11:24 AM Thread Starter
2006foxx's Avatar
2006foxx is offline
post #10 of 15 Old 12-30-2011, 12:34 PM
birddog0347's Avatar
I Ride: 04 ZX-10R, 03 ZX-636, 09 KX-450F
the 03/04 basket has a different number of teeth than the 05/06... they don't interchange.
FASTEST CHICKEN IN THE SOUTH!
birddog0347 is offline
post #11 of 15 Old 12-30-2011, 12:45 PM
greenmeeny's Avatar
That's why I've said above you count the outer basket teeth. They do mesh even if they are different, just not as well. I used the 03 rr baskets.
post #12 of 15 Old 12-30-2011, 02:49 PM Thread Starter
2006foxx's Avatar
************************** This Breaking News *******************************
Investigators have found that the Input shaft
(That thing your clutch basket and more important to this news cast, your Clutch Hub is secured to)
on the 98-98 G1 and the 05-06 RR are in fact...
(Wait for it)
DIFFERENT!!!!
However, our investigators are finding that the differences again potentially
don't affect the ability to mount the Clutch Hub from a 05-06RR to a 98-99 G1. Reason:
The portion of the shaft that the Clutch Hub attaches to just so happens to be 20mm on both generations.
So now the race is on to see if infact the clutch from a 05-06RR will work on a 98-99G1.
I'm your reporter Know-Nothing Doolittle signing off.
2006foxx is offline
post #13 of 15 Old 12-30-2011, 03:42 PM
zx6chris's Avatar
I Ride: whats left of a j1
Sounds like a good upgrade if ur going track and road I thought they were only best used on big v twins
its not what u know its who u know!!
zx6chris is offline
post #14 of 15 Old 05-23-2014, 04:21 AM
Yes, Holy Thread resurrection Batman!
Did you get any further with this mate? Looking for similar as my G1 is also doing double duty
Gaffa Tape is like The Force, it has a light side, a dark side and it binds the universe together
engybenjy is offline
post #15 of 15 Old 02-01-2015, 01:12 PM
Hi my bike has this mod fitted the only thing I've found as I have just put some more plates in is that the original clutch shaft what goes through the casing has been modified ie a slot cut in it which is not the best as it looks like it hasn't been catching properly so I'm thinking about putting the casing and shaft of a 05 bike would this work.
Webbozx6 is offline
Slipper Clutch Mike40r The ZX6R 30 01-22-2013 09:13 PM
2008 Zx6r Clutch Issues alfieferenzo Mechanical and Technical 2 01-18-2013 08:18 PM
Does my B1H 2005 have a slipper clutch Fletch Mechanical and Technical 38 12-10-2011 11:44 AM
2007ZX6R - Clutch Lever anderszx6r Mechanical and Technical 3 09-26-2011 11:13 PM
05/06 slipper clutch basket on 03/04 nexia201 Mechanical and Technical 4 04-08-2011 01:49 PM
