Need opinions regarding HID's?This is a discussion on Need opinions regarding HID's? within the The ZX6R forums, part of the ZX6R Forum category; Originally Posted by naked6
CTninja, or anyone else in the know. Can you please elaborate more on the H9 upgrade? So, if I run H9 ...  |
01-21-2012, 08:08 AM
#16 | | Squid
Originally Posted by naked6 CTninja, or anyone else in the know. Can you please elaborate more on the H9 upgrade? So, if I run H9 bulbs on both sides, will it be like having two high beams? | Sure, this is the H9 upgrade: how to: increase lumen on your headlight
Yes, it will be like having two high-beams. You'll be going from 1350 lumens to 2100+ lumens in your low-beam just from doing this five minute mod. Don't worry, the low-beam still remains properly angled so even though you're running the H9 bulb you won't blind other drivers. Real simple to do. I used a set of needle files and a small flush cutter.
01-21-2012, 08:20 AM
#17 | | Squid
Joined: Oct 2011 From: Orlando, FL Posts: 80 I Ride: 2011 zx6r lime green | Quote:
Originally Posted by endeavor H9 and H11 are NOT the same thing. There's a few differences. The halogen H9 is a 65w bulb, where the halogen H11 is a 55w bulb. Also the tabs that seat the bulb in the headlight housing and the plugs are different for the H9 and H11.
To do the HID swap for a 09+ model 6r, you will need to get two single bulb HID kits. You can get either 35w or 55w. You will need a H9 and a H11 HID kit to make things plug and play. Otherwise, you will have to do a lot of wire cutting and bulb/housing modification to make things work. | Thanks! Exactly the info I needed.
02-20-2012, 05:49 PM
#18 | | Squid
can i run 2 h11 hid bulbs in my 2012 zx6r   ?
02-20-2012, 06:41 PM
#19 | | Squid
Originally Posted by 2012 zx6r can i run 2 h11 hid bulbs in my 2012 zx6r   ? | See my post regarding your question in the other thread. And, contrary to what the above poster mentioned... NO YOU DON'T need to buy two seperate kits, one for H9 and one for H11. Order one H11 kit.
02-20-2012, 07:12 PM
#20 | | Superbike Champion
Joined: Sep 2011 From: Milton, Ontario, Canada Posts: 1,052 I Ride: 09 ME ZX6R |
Good thread guys!
ok, so why would someone get a HID kit, when you can just run 2 H11s? (like the xenon ones?) I looked at the HID kit mentioned in previous posts, and it come as a dual kit, but doesn't our bikes have 2 different bulbs?
and someone mentioned that you can't flick HIDs off and on? Are they that delicate?
Thanks!
02-20-2012, 10:18 PM
#21 | | Squid
Thanks! | The whole reason behind upgrading to HID's is for looks and the superior visibility they provide. I think you mean H9 instead of H11, because H9 is what is used in the high beam side on the stock halogen setup. Even if you were to run 2 H9's, you still wouldn't get the looks and quality of lighting that you'd get with HID's.
| | | Search tags for this page | | 09 zx6r highbeam bulb, 2009 zx6r parking light hids?, 2011 zx6r bulb type, 2011 zx6r low beam hid, can you put 55w 8000k hid lights in a 2008 zx6r, can you use h11 bulbs for both sides?, does zx6r have different headlights, h11 bulbs for 05 zx636?, is 8000k too blue from ddm tuning, is there a difference between hid's and hi/low hid with light output?, low beam 2009 zx6r stock bulb h9, reviews for 8000k hid for 09 zx6r, speedmetal hid, speedmetal hid h7 vs h9, speedmetal hid h9/h11 not working, speedmetal hid light kit, speedmetal hid light kit review, speedmetal hid light kit reviews, speedmetal hid light kit zx636, what hid kit does the 2008 zx6r take
