Need opinions regarding HID's?
This is a discussion on Need opinions regarding HID's? within the The ZX6R forums, part of the ZX6R Forum category; I recently started another thread pertaining to HID's and I'm trying to decide whether just to change the bulbs out of my current setup to ...
Old 01-17-2012, 06:24 PM   #1
I Ride: 2011 zx6r lime green
I recently started another thread pertaining to HID's and I'm trying to decide whether just to change the bulbs out of my current setup to something with a lower kelvin rating (4300-5000k) or just get a whole new kit from DDMtuning. The lights that are on there now are too blue for my taste, hence the reason for me wanting to change to a whiter light with more light output. I have attached a picture of the ballast that is currently on the bike. I'm not sure if there is an identical one on the other side of the bike to power the other bulb or if the one powers both the low and high beam.
Seeing how it's rated for 35w, I'm considering ordering the whole 55w kit from DDM seeing how it's only $40, in the hopes of getting even better output that the 55w setup would offer. What are your opinions on this please? Should I just replace the bulbs, or should I just go ahead and opt for the whole entire 55w kit? Anyone know if the Hella ballasts are any better or worse than the ones supplied with DDM's kit?
naked6 is offline
Old 01-17-2012, 07:39 PM   #2
brar's Avatar
I Ride: 06 ninja zx6r
You should buy the 55w thats what i got they are SUPPERRR BRIGHT and i am running them at 8000k they are a little blue but not to much and DDM tuning are the best hids bulbs i live in canada and had to pay international shipping and customs was about 100 doollars but was so worth it the quality is great i would say go for the 6000k if u wanted something white and super bright but 8000k's are the brightest !
brar is offline
Old 01-17-2012, 07:42 PM   #3
brar's Avatar
and about high beams and low beams it doesnt really matter cause they are super bright dont bother wasting a extra 10 bucks for high and low beam option they wont be needed
brar is offline
Old 01-17-2012, 08:23 PM   #4
Not sure exactly what you mean by this, but this is the kit I'm thinking of getting.
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
naked6 is offline
Old 01-17-2012, 08:33 PM   #5
And, how is it that just a pair of OEM halogen headlamp bulbs cost over 50 bucks , while a whole HID kit can be had for under that?
naked6 is offline
Old 01-17-2012, 08:45 PM   #6
deadazleep's Avatar
I Ride: 09 Candy Surf Blue
key word OEM lol
DDM kits work great in my experience, got a set in my car going strong after 2 years
also the 09+ bikes use 2 different bulbs H9 and H11, not sure if that matters since i havnt got a kit yet
deadazleep is offline
Old 01-17-2012, 09:01 PM   #7
illrational's Avatar
I Ride: zxSICr
Is it h9 for running and h11 for regular hi/low beam
illrational is offline
Old 01-17-2012, 09:22 PM   #8
Originally Posted by deadazleep View Post
key word OEM lol
It is my understanding that they are both H11 bulb types with the HID kit. Someone corrrect me if I'm wrong.
naked6 is offline
Old 01-18-2012, 02:06 PM   #9
brar's Avatar
What i mean is some of the bulbs u can get it so they are high beam and low beam it cost 15-20 bucks more and also 55watt cost 10 bucks more but i do recomend that furshure no point getting high beam and loow beam u are going to waste your money
brar is offline
Old 01-18-2012, 05:25 PM   #10
What did you think of the output of the lights, other than too blue? Was it much better than the stock light? The reason I ask. I run a 07 zzr6, stock headlights are 55/60 watt bulbs, but I was thinking of going to a 35 watt, 6000k, hid kit. Wasn't sure if I would see much of an improvement over stock or would I be better off going to a 55 watt kit. Not sure if the 55s might not run too hot as both are on all the time the bike runs.
Any information or opinions would be appreciated. thanks
mecman is offline
Old 01-18-2012, 05:50 PM   #11
A 35w HID will be much brighter than a 65w non HID. The H9/H11 is simply the tabs on the bulb and how they fit into the base when you swap them out. I wouldn't go with a 65w HID as you run the risk of getting some of the electrical system drawing too many amps. Amps are what fry things... not watts.
I'm runnin 35w 6000k
An 8000k bulb is NO BRIGHTER... just more BLUE in color. The whitest are 6000k.
Hope that helps!
By the way I'm running Speed Metal HID's
PowerGroove is offline
Old 01-19-2012, 08:49 PM   #12
rolledoats's Avatar
I Ride: 09 space-ship
Hope that helps!
PG,is that jeff bridges "the dude", in your prof pic?lol
rolledoats is offline
Old 01-19-2012, 10:26 PM   #13
CTninja's Avatar
No, you're a little confused. "Running lights," or parking lights are the little 194 bulbs to the left and right of each headlight. The 09'+ zx6r has an H11 bulb for low-beam and an H9 bulb for its high-beam.
Personally, I did the "H9 upgrade" to mine and I couldn't be happier. Shit ton more light on the road running a H9 bulb in place of the H11, and I don't have to have ballasts and wires everywhere hanging off my bike. Plus, I can flick the high-beam at inattentive drivers when I'm coming up to an intersection. Running HID's in both headlamps, you would lose that capability as flicking HID's on/off rapidly will ruin them.
CTninja is offline
Old 01-20-2012, 09:37 PM   #14
CTninja, or anyone else in the know. Can you please elaborate more on the H9 upgrade? So, if I run H9 bulbs on both sides, will it be like having two high beams? One of the previous posters mentioned the only difference is the tabs between the two. Will I need to order two single kits, one with an H9 bulb and the other with a H11 bulb, or just one kit with identical bulbs? Sorry for the newb questions.
edit... ok I just saw in another thread that apparently for HID kits, H9 and H11 bulbs are the same thing. So, can someone please tell me how the high beam is accomplished with an HID setup if both bulbs are identical?
naked6 is offline
Old 01-20-2012, 10:58 PM   #15
endeavor's Avatar
H9 and H11 are NOT the same thing. There's a few differences. The halogen H9 is a 65w bulb, where the halogen H11 is a 55w bulb. Also the tabs that seat the bulb in the headlight housing and the plugs are different for the H9 and H11.
To do the HID swap for a 09+ model 6r, you will need to get two single bulb HID kits. You can get either 35w or 55w. You will need a H9 and a H11 HID kit to make things plug and play. Otherwise, you will have to do a lot of wire cutting and bulb/housing modification to make things work.
endeavor is offline
09 zx6r highbeam bulb
2009 zx6r parking light hids?
2011 zx6r bulb type
2011 zx6r low beam hid
can you put 55w 8000k hid lights in a 2008 zx6r
can you use h11 bulbs for both sides?
does zx6r have different headlights
h11 bulbs for 05 zx636?
is 8000k too blue from ddm tuning
is there a difference between hid's and hi/low hid with light output?
low beam 2009 zx6r stock bulb h9
reviews for 8000k hid for 09 zx6r
speedmetal hid
speedmetal hid h7 vs h9
speedmetal hid h9/h11 not working
speedmetal hid light kit
speedmetal hid light kit review
speedmetal hid light kit reviews
speedmetal hid light kit zx636
what hid kit does the 2008 zx6r take
Do you have high/low HIDs? Lobster Mechanical and Technical 25 03-21-2012 06:31 PM
Trimmed seats plus HID's LoboZX The ZX6R 25 01-28-2012 09:06 AM
HID's and/ or Halo's SPEEDIN636 Mechanical and Technical 7 10-24-2011 05:11 AM
New Helment Opinions LenaLilLower Motorcycle Talk 95 07-12-2011 10:31 AM
HIDs and LEDs ninja z28 Pictures 8 11-05-2009 06:44 PM
