05 zx10 front end on 03-04 636
This is a discussion on 05 zx10 front end on 03-04 636 within the The ZX6R forums, part of the ZX6R Forum category; The 03-04 636 forks are very prone to snapping mid stoppie, my question is: Is it possible to put the 05-06 zx10 front end on ...
Old 02-05-2012, 11:16 AM   #1
The 03-04 636 forks are very prone to snapping mid stoppie, my question is: Is it possible to put the 05-06 zx10 front end on a 03-04 636? What about the 636 front end on the zx10?
jeremyRockit is offline
Old 02-06-2012, 08:08 AM   #2
birddog0347's Avatar
I Ride: 08 ZX-10R, 03 ZX-636, 09 KX-450F
You would need to change out the triple clamps, but you would have to get the steering stem pressed off the lower of the 636 triple clamp and pressed onto the lower of the zx-10 triple clamp. If you are really wanting to do it, I have a set of 08 ZX-10R forks with AK-20's installed already I will sell you.
birddog0347 is offline
Old 02-06-2012, 10:54 AM   #3
What exactly is the ak-20s? I have a 05 zx10 waiting to get rebuilt and I just put new forks on it, how difficult is it to pull the stem from the 10 and repress it on the 6?
Old 02-06-2012, 11:10 AM   #4
AK-20's are internal replacement components (Like Ohlins or Mupo, etc). They are Very high quality and totally change out the feel of the front end, and really smooths out the bumpy tracks down here in Texas. The stem, you would have to take them to a machine shop and ask them. You will need a press, and it will have to be perfectly pressed in exactly perpendicular.
Old 02-06-2012, 12:52 PM   #5
Oic, sorry I'm not too familiar with the racing side of sport bikes. I just stunt. I would most likely have to buy the front wheel, calipers etc to make them work I'm guessing.
Old 02-06-2012, 04:56 PM   #6
The front wheel for the 06+ ZX-10R is the same as the 05+ ZX-6R (636). I think the axle is the same on the 03/04 636 as well, but not 100% sure. If you have an 05+ 6R, then you can use the same brakes, calipers, wheel, but might need a different fender.
03 04 zx6r front forks
03 zx10 front fork
04 636 front rim
04 zx 10 forks on my 636
04 zx6r fork diameter
05 636 front end work on a 2000 zx6r
05 636 front forks
05 636 rim
05 forks zx6r
2006 zx 636 triple tree cover
average price to get forks rebuit on my 06 zx10
can u lower the front of a 03 zx6
is the 05 636 the same as 03
what forks will swap out on a 03 zx6r
what front ends will fit my zx6rr
what year forks will fit a 03 zx6r
zx10 forks on zx6r
zx6 636 forks for sale
zx6r 04 front rim size
zx6r wheels on zx10 forks
removal front sprocket - zx6r 636 a1p 2002 thegreensnot Mechanical and Technical 21 01-31-2012 04:28 AM
FS: 03-04 636 front forks and lower tree for sale cooker636 Classifieds 0 09-16-2011 12:50 PM
636 b1 front end parts needed ollieox Want to Buy 0 07-25-2011 01:53 PM
front end vibration califab The ZX6R 16 10-31-2009 05:54 AM
click from front end on light braking BadAssRX-7 The ZX6R 12 05-19-2009 05:35 PM
