Installing a slip-in - any need to 'fool' computer/butterfly valve?
This is a discussion on Installing a slip-in - any need to 'fool' computer/butterfly valve? within the The ZX6R forums, part of the ZX6R Forum category; A friend who owns/races an 06 ZX6R (same as mine) cautioned me that when installing a muffler, I need to be wary of the butterfly ...
Old 02-17-2012, 01:53 PM   #1
A friend who owns/races an 06 ZX6R (same as mine) cautioned me that when installing a muffler, I need to be wary of the butterfly valve. He said the stock setup, the valve actually closes at high rpm (at 13k ish) to reduce noise. He says most aftermarket mufflers/exhausts get want to avoid that closing since its obviously not good fo rpower. However, he said that unless the muffler comes with a 'stop' system of some kind (i'm hazy on the details), the bike will throw a check engine light.
Questions:
1) Is this true?
2) Does this apply when installing a slip-on or only a full exhaust?
3) If I need to care, what parts do I need/procedure do I follow? If there are mufflers to avoid (that don't come with the stop), what are they? Should the muffler I get come with it?
Thanks!
SadbutTrue is offline
Old 02-17-2012, 02:14 PM   #2
Aeon87's Avatar
I Ride: 2003 SixDirtySix, 2006 SixDirtySix
Do the "Jumper Mod". Search for the DIY here on the forum. That mod basically converts your bike to Euro Spec and allows for the valve to stay open at all times without throwing the FI light.
OR, you could remove the servo motor altogether and get yourself the ServoBuddy/Servo Eliminator kit. Plug n Play.
Aeon87 is offline
Old 02-17-2012, 02:21 PM   #3
yoshi's Avatar
I Ride: a 2006 zx6r
the valve shuts at the lower rpm to apparently make some back pressure for better torque, its questionable. more for noise emissions i think.
removing the silencer removes the valve, you dont need one
yoshi is offline
Old 02-17-2012, 04:14 PM   #4
Got a link? I've done jumper mods before on my old Sv650, shouldn't be too hard... but a plug and play kit might happen sooner
Thanks!
Old 02-19-2012, 11:11 PM   #5
anyone got a link to the kit/DIY jumper mod?
Old 02-19-2012, 11:14 PM   #6
givuhcky22's Avatar
I Ride: 2009 GREEN ZX6R
sad,
lift seat,
find this
pull off tab, exposing 4 holes.
connect top left to bottom right as shown:
then put cap back on. finished.
givuhcky22 is online now
Old 02-21-2012, 09:21 AM   #7
sweet. is that just any old copper wire or anything specific used to cross the jumpers?
2011 zx6r butterfly valve stuck
2012 xz6r slip on installation
butterfly valve 09 zx6r
butterfly valve 2012 zx6r
butterfly valve zx6r
check engine light zx6r
installing slip on 2011 zx6r
kleen air mod
mods for engine zx6r
slip on butterfly valve
valves butterfly slip in
zx6r open butterfly valve
