advice on rim stripe removalThis is a discussion on advice on rim stripe removal within the The ZX6R forums, part of the ZX6R Forum category; how to do it easy?!...10 min in and this is pissing me off!...  |
02-20-2012, 01:12 PM
#1 | | Team Green
Joined: Dec 2011 From: GB Wisconsin Posts: 226 I Ride: 2011 ZX6R | advice on rim stripe removal
02-20-2012, 01:13 PM
#2 | | MotoGP Champion
Joined: May 2011 From: OMAHA NEBRASKA / TULSA OKLAHOMA / OCEAN CITY MARYLAND Posts: 4,735 I Ride: 2009 ZX6R DIABLO BLACK (TOTALED) COMING SOON: 2009 ZX10R DIABLO BLACK |
Did u heat it up with a hairdyer as you go ?
I KNOW THAT WORKS FOR DECALS NOT SURE ABOUT RIM JOB ?
02-20-2012, 01:17 PM
#3 | | MotoGP Champion
Joined: Jul 2011 From: Murray, KY Posts: 3,018 I Ride: 2011 ZX6R | Quote:
Originally Posted by THUG NOT SURE ABOUT RIM JOB ? | |
02-20-2012, 01:24 PM
#4 | | Team Green
Joined: Dec 2011 From: GB Wisconsin Posts: 226 I Ride: 2011 ZX6R | Quote:
Originally Posted by THUG Did u heat it up with a hairdyer as you go ?
I KNOW THAT WORKS FOR DECALS NOT SURE ABOUT RIM JOB ? | yea but it still wasn't working good, any tool i can use
02-20-2012, 01:32 PM
#5 | | MotoGP Champion
Joined: May 2011 From: OMAHA NEBRASKA / TULSA OKLAHOMA / OCEAN CITY MARYLAND Posts: 4,735 I Ride: 2009 ZX6R DIABLO BLACK (TOTALED) COMING SOON: 2009 ZX10R DIABLO BLACK | Quote:
Originally Posted by n0ob rider yea but it still wasn't working good, any tool i can use | pm hickey he has probabaly done more rim jobs than anyone i know
02-20-2012, 01:49 PM
#6 | | Post Master General
Joined: Sep 2010 From: VA Posts: 8,765 I Ride: 2009 GREEN ZX6R |
this one cracked me up.
just take your time. heat things up to loosen it. it'll get gooey, the you can tug it off.
02-20-2012, 03:00 PM
#7 | | Pro Racer
Usa a hair dryer or heat gun on LOW then slowly peel off use wd40 to remove glue voila done.
02-20-2012, 03:48 PM
#8 | | Track Star
Joined: May 2011 From: U.S Posts: 454 I Ride: ZZR600/ZX6R Hybrid |
Two products will work. "Goof Off" and "Goo B Gone". I wouldn't recommend using it on painted rims, just in case. I have used both on factory coated wheels to get the sticky gunk off from ballance weights.
02-20-2012, 03:55 PM
#9 | | Team Green
i got em off now, all the decals are off...tomorow I have to pick up the new ones.
02-20-2012, 04:23 PM
#10 | | Post Master General
Joined: Aug 2009 From: Looneyben escapee Posts: 8,384 I Ride: 2007 ZZR/ZX6R | Quote:
I KNOW THAT WORKS FOR DECALS NOT SURE ABOUT RIM JOB ? | +1
02-20-2012, 04:33 PM
#11 | | Track Star
Joined: Oct 2011 From: Boise Id Posts: 389 I Ride: 2003 ZX6R |
hahaha rim job, Awesome. I feel ya, that stuff breaks off in little pieces. If you use goof off make sure to test it out where you wont notice if it messes up the paint.
02-20-2012, 04:45 PM
#12 | | Guest |
That shits made to stick. When I put mine on I used soapy water in a spray bottle. Use a hair dryer like everyone else said. It'll be a slooooooiow process. They got this stuff its called either goo begone or glue begone. Check a walmart maybe. Also not sure if you want to use it and then scrub the hell out of it but lighter fluids good for that. Watch out it may be like paint thinner. Also could start a fire. I do not advise. If you do use lighter fluid hve a camcorder ready haha!
02-20-2012, 05:02 PM
#13 | | World Superbike Champion
Joined: Mar 2011 From: Greenbelt, Maryland Posts: 2,387 I Ride: 09 ME ZX6R | Quote:
Originally Posted by EmDoubleu Usa a hair dryer or heat gun on LOW then slowly peel off use wd40 to remove glue voila done. | +1
02-20-2012, 06:08 PM
#14 | | MotoGP Champion
Joined: Aug 2011 From: Bury St Edmunds, Suffolk, England. Posts: 2,682 I Ride: 2001 Blue J2 ZX6R |
Hickey you can come to mine and do a RIM JOB...... |
02-20-2012, 06:22 PM
#15 | | Post Master General
Joined: Sep 2010 From: VA Posts: 8,765 I Ride: 2009 GREEN ZX6R | |
| | | Search tags for this page | | 2007 zx6r wheel strips, how to remove rim zx6r, removing factory wheel strip from 09 zx6r, rim stripe removal, rim striping removal
