Where the hell is the headlight relay?This is a discussion on Where the hell is the headlight relay? within the The ZX6R forums, part of the ZX6R Forum category; Short story, headlight won't run high or low, but bulb isn't burned out and fuses are good. I suspect it's the relay, but I can't ...  |
02-21-2012, 10:42 AM
#1 | | Team Green
Joined: Jun 2011 From: UT Posts: 231 I Ride: '99 zx6r | Where the hell is the headlight relay?
Short story, headlight won't run high or low, but bulb isn't burned out and fuses are good. I suspect it's the relay, but I can't figure out where it's actually located on the bike even after looking over the manual and searching online. Bike is a 99 ZX6R. Any help is appreciated.
02-21-2012, 11:53 AM
#2 | | Team Green
Joined: Jul 2011 From: Dayton, Ohio Posts: 207 I Ride: 2006 ZX6RR |
I have a 06 and its right by the fuse block under the rear fairing, I have heard of other bikes being up near the headlight area. Ill see If I can find it online.
02-21-2012, 02:07 PM
#3 | | Track Star
Joined: Dec 2011 From: Columbus, Ohio Posts: 404 I Ride: '08 ZZR600 |
It's behind the cluster. Take your windscreen off & the top of the relay should be facing up. It's hanging on a bracket with a rubber ring. Mine has 1 relay for each bulb.
02-21-2012, 02:15 PM
#4 | | Team Green
Just found out online that it's in the junction box (where the fuses are) hidden inside. Pulled it apart and sure enough, I found a few relays in there. In order to replace them, you have to buy a whole new junction box.
02-21-2012, 02:37 PM
#5 | | Track Star
Same shape, different location I guess.
| | | Search tags for this page | | 03 636 headlight relay, 03 zx6r flasher relay location, 03 zx6r headlight isnt working, 07 zx6r headlight fuse location, 2002 zx6r headlight relays, 2006 zx6r fuse box, 2006 zx6r headlight relay, 636 headlight relay, head light fuse on zx6r 2002, head light relay on a zx6r, headlight fuse for zx6r, headlight fuses for 2003 ninja, headlight relay on 06 zx636, headlight relay zx6r, where are headlight fuses 2000 zx6r, where is the headlight relay 2006 zx636, where is turn relay on 06 zx6r, zx6 head light fuse, zx6 headlight relay, zx6r headlight relay
