Rake and Trail with 120/70zr17
This is a discussion on Rake and Trail with 120/70zr17 within the The ZX6R forums, part of the ZX6R Forum category; Just put a 1300 dollar order in for my 05 636 to get her ready for spring. With that order came new Dunlop Q2 tires. ...
Old 02-21-2012, 02:01 PM   #1
Squirrel636's Avatar
I Ride: 2005 Zx6r
My question is how much will the upsize to the 70 series front tire affect my rake and trail? The stock size was the shitty 170/65ZR17 Battleaxe 014's...which the only manufacturer I found that makes that size is the older Pilot Powers.
The aspect ratio of the 70 adds 5-6mm and I'm worried its going to have a negative impact on cornering. I've read alot of post about how it makes it alot slower for turn in and sluggish recovery.
Anyone with the same bike have any adverse effects? What are my options for getting the bike back into standard specs for rake and trail assuming the taller tire takes it out of spec.
Squirrel636 is offline
Old 02-21-2012, 02:32 PM   #2
ninjazx6r636's Avatar
I Ride: 2005 Kawasaki Ninja Zx6r 636
i have a 120/70-17 on my front, rides just fine, my rear is still stock size 180/55-17
ninjazx6r636 is offline
Old 02-21-2012, 02:52 PM   #3
I Ride: 2005 Zx6r
What tires are you running? No rubbing issues on the front fender?
Old 02-21-2012, 02:56 PM   #4
I have Shinkos on my bike and no rubbing has occurred.
Old 02-21-2012, 05:41 PM   #5
TC636's Avatar
I Ride: 06 kaw 636 and women
I have an 06. Same bike as yours really. I got tired of trying to run down a 65 series
front tire. So i recently put a set of The pilot power 2ct's. And i went with the 70
on the front. Being that the tires were new, i didn't notice any difference in handling.
And no rub. When my front gets some wear in it, and i feel like it's starting to steer
a little slow, i'm just going to raise my forks up in my triple clamps.
I think the difference between the 65 and 70 is like around 1/4 inch.
TC636 is offline
Old 02-21-2012, 05:46 PM   #6
johnnyE's Avatar
If you dont like the way it feels just raise the forks a few mm
johnnyE is offline
Old 02-21-2012, 08:01 PM   #7
I Ride: 2005 Zx6r
Thanks for the feed back. Ill see how it feels this without any adjustments, I figure if it feels worse ill just have the suspension tuned.
05 zx6r 120/70/17?
120/70zr17 on a 2003 zx-636
2003 zx6r 120/70zr17
is 120/70zr17 right tire for zx6r?
rake and trail kawasaki zx6r
what tire runs speedometer zx6r
why did kawasaki zx6r go to 120 70
will 120 70 zr 17 fit the zx6r
will 120/70-zr 17 rub on a 2006 zx6r 636
zx6r rake is wrong
zx6r rake trail
zx6r speedometer taller tire
