Can this gas tank dent be pulled?
This is a discussion on Can this gas tank dent be pulled? within the The ZX6R forums, part of the ZX6R Forum category; Got all my parts on order and when all was said and done, I can't afford the 200 dollars for a new tank. My old ...
Old 02-22-2012, 12:14 PM   #1
Lobster's Avatar
I Ride: 2007 ZX-6R
Got all my parts on order and when all was said and done, I can't afford the 200 dollars for a new tank. My old one does not leak but it has a giant dent in it.
I googled my options. Many said just throw it out. Some said it was possible to take a small hammer to the inside of it.
I was thinking about taking a hammer to it and getting the dent out the best I can and then sanding it down with filler primer then painting it to match my new fairings.
I've also seen vinyl wraps. Since my new fairings are gloss white, I'm thinking of vinyl wrapping the tank. Any one ever deal with vinyl wraps?
Am I wasting my time? Anyone have experience with stuff like this?
Lobster is online now
Old 02-22-2012, 12:21 PM   #2
ZX6RRECTION's Avatar
I Ride: Green 2006 ZX6-RR (was Limp) on Viagra/ 05 ZX6RR (parts bike)
Call this guy offer him $75 shipped for the gas tank....get ur self some paint
★MULTI PAROUTS★ 05/06 ZX636's (crackhead prices)
ZX6RRECTION is offline
Old 02-22-2012, 12:24 PM   #3
Btw $200 for a new tank is a really good deal....keep in mind that ur tank is fine
...that dent in the tank in a non urgent repair...so get a new tank whenever u get ur money right
...new tanks r close to $500 from the stealership
Old 02-22-2012, 12:26 PM   #4
Lobster's Avatar
I Ride: 2007 ZX-6R
Shit, I'm an idiot.
I realized that on my profile, it says I own a 05 636.
This is actually for my 07 ZX6R.
I found a used tank for 200 shipped but its red.
Old 02-22-2012, 01:32 PM   #5
MrZ
MrZ's Avatar
I Ride: 636 '05
Seems repairable.Ask for a body shop that does that short of stuff for a price to fix it.They use some bent piece of metal through the gas cap hole to push the dent out as much as possible and then the usual stuff...
MrZ is offline
Old 02-22-2012, 01:35 PM   #6
Lobster's Avatar
I Ride: 2007 ZX-6R
I got a quote for 250 for a body shop to do it.
I guess I have nothing to lose. Maybe take a thick piece of metal and hammer it out and level it out through filler and sanding.
Old 02-22-2012, 01:40 PM   #7
tgold's Avatar
I Ride: '05 ZX6R racebike, "04 Multistrada street
It's not going to be worth the hassle to try to push that dent out for the .05 gallon increase in capacity. Just put the body filler on it, shape it, and respray it.
tgold is online now
Old 02-22-2012, 02:34 PM   #8
Souleh's Avatar
Can be filled and youd never know the difference, check it
Same tank
Souleh is offline
Old 02-22-2012, 02:58 PM   #9
bikerben's Avatar
From: mildura, Australia (small town with no twisties)
I Ride: 95 zx6r
Look for the dent in freaks zx10 tank anything and be filled and fixed
bikerben is offline
Old 02-22-2012, 03:59 PM   #10
moody729's Avatar
I Ride: 2007 Black ZX6R
Call/E-mail Johan @ sportbikeplasticsrepairs.com. send him a pic. He's one of the few ppl around that actually pulls the dent rather than filling it. He does great work. Last time I talked to him, I asked about my friend's dented tank...he said he does tanks for anywhere from $135-190 depending on the size/location of the dent. You can E-mail him a pic right through his website and he'll reply w a quote usually same day. You canto haggle a little bit w him too. Tell him Moody sent you. He just painted/repaired a nose fairing for me.
moody729 is offline
Old 02-23-2012, 05:31 AM   #11
tgold's Avatar
Really? Like he's going to pull the dent and NOT fill it? Like I said, it's not worth the hassle to get back the .05 gallons of capacity. At least not for that kind of coin. Less labor means less cost.
tgold is online now
Old 02-23-2012, 07:09 AM   #12
Street Hawk1's Avatar
I Ride: 09 ME ZX6R
Tank bag.
Street Hawk1 is offline
Old 02-23-2012, 07:22 AM   #13
Jude20VT's Avatar
I had a couple dents pulled from a cruiser tank while getting the entire bike sprayed. My guy said he welded small pull bars to the dent, then used a slide hammer to pull dent... then he filled the small remaining flaws. If you want it done right, this would be better than a big chunk of filler.
Here's the deal... buying a used tank still leaves you with the cost of having it repainted. So just have yours repainted and have the guy fix the dent at the same time for a few extra $$. Any body shop guy can fix as he paints - note some body shops will not deal with tanks (explode). See if Moody's guy can spray it too. I could get it fixed and painted around here for $200.
Jude20VT is offline
Old 02-23-2012, 02:05 PM   #14
MrZ
MrZ's Avatar
I Ride: 636 '05
It's not about the capacity....it's about the weight of the tons of filler that will be used if not pulled out!!!Weight matters!
MrZ is offline
Old 02-23-2012, 07:27 PM   #15
tgold's Avatar
The dent isn't that big and we're talking a street bike. It has zero significance. You're talking what, 5 ounces of filler? And if you're really concerned with weight, mix micro balloons in with the filler. That's what's done on aircraft to reduce the weight of filler:
3M GLASS BUBBLES from Aircraft Spruce
tgold is online now
02 zx6r fuel tank
02 zx6r fuel tanks
04 zx636 tanks
07 zx6r gas tank
07 zx6r gas tank repair
07 zx6r tank fixing
2006 zx6r dented gas tank repair
2007 zx10r gas tank
2007 zx6r gas tank
2007 zx6r green gas tank used
buy a new tank for 2009 zx6r
fixing gas tank zx6r
pull gas tank dent
should i repair my zx6r tank
vinyl my gas tank zx6r
zx636 tank
zx6r dent in gas tank
zx6r tank dent
zx6r tank repair
zx6r white gas tank
FS: 09-11 ZX6r Gas Tank + side fairings 04yfz Classifieds 0 09-28-2011 10:50 PM
Gas Venting problem....kream coating? Brichard The ZX6R 13 05-28-2009 09:22 PM
somethings up with my gas tank hocknscary87 The ZX6R 1 05-22-2009 08:49 PM
gas tank cover?? Ziggyboo84 The ZX6R 9 03-25-2009 06:57 AM
Gas Tank Ventilation Problem-Leaking Spenser The ZX6R 4 03-22-2009 12:35 PM
