03/04/05/06 ZX636 ZX6R speedo upgrade - Page 4 - ZX6R Forum
 25Likes
post #46 of 164 Old 12-18-2012, 05:14 AM Thread Starter
extr400's Avatar
I Ride: ZX636-05, Ducati H-motard 1100S
For UK riders, I can resolve the problem with ODO correction.
Provided you send evidence (such as a copy of last MOT showing mileage) then I can correct the ODO of a new gauge for £50 including return delivery (by insured next day special delivery).
This is quite a technical process and involves re-programming one of the speedo chips.
extr400 is offline
post #47 of 164 Old 12-18-2012, 05:29 AM
hadfield's Avatar
I Ride: 2006 Kawasaki Ninja ZX6r 636 D6f
Also, for reference, this becomes a legal liability in California.. bluegauges.com won't change out the mileage for a gauge that's not an identical replacement to the one it's replacing, and they want full paperwork on the deal.. which I didn't understand, till he said that even INCREASING the mileage is an issue for California, where you have to have greater than a certain mileage on your odo, to get insurance coverage or exemption from somethingorother.. I sort of tuned out after the guy basically said, "no I won't do it."
There might be others, but they generally want $100+, and you have to ship them the gauge, which means no riding..
Personally, I didn't see the value - I took photos of the old speedo showing the mileage, with my watch in the picture (shows date/time), and then 45 seconds later, the new gauge with its different mileage, my watch again in the picture.. identifies to anyone what I've done, the ACTUAL mileage can be calculated, and I have a printout of both photos in my files for reference if I have to show what I did.. odds are I'll keep this bike for a good long time, though.
ΜΟΛΩΝ ΛΑΒΕ
2006 Ninja ZX-6R 636 (D6f) | Sidewinder Titanium 16k Chain | HEL Stealth Brake Lines | Pazzo Knockoffs | Extr400 Speedo Adapter + 2009 Speedo Cluster | Akrapovic slip-on + ServoBuddy | Shogun Frame Sliders | Zero Gravity windscreen | ProGrips | Custom Dragon Decal
hadfield is offline
post #48 of 164 Old 12-19-2012, 03:46 AM
crazy1's Avatar
I Ride: J1
Well I've bought the hardware off of Extr400 and a set of 07/08 Clocks off eBay for my J1. I expect to get a issue or two as its not originally designed for the J series but ill figure it out and post the results for you all.
crazy1 is offline
post #49 of 164 Old 12-19-2012, 06:34 AM
intercom's Avatar
I Ride: '02 ZX6R J3
Please keep in mind your temp sensor will NOT work with the new gauges. Im not sure if this will effect the fan switching on/off but you wont be able to see what your temp is. BE CAREFUL and good luck!!
intercom is offline
post #50 of 164 Old 12-19-2012, 06:58 AM
crazy1's Avatar
I Ride: J1
I think the fan has its own sensor on the radiator. I was aware of the temp gauge problem and will buy a 07/08 sensor and make it work somehow.
Thanks for the heads up though. Will post up my findings.
crazy1 is offline
post #51 of 164 Old 12-19-2012, 02:01 PM
crazy1's Avatar
I Ride: J1
Question for the masses, is the 03 temp sensor the same as the 07?
crazy1 is offline
post #52 of 164 Old 12-20-2012, 04:30 AM Thread Starter
extr400's Avatar
Hi folks,
All current adapter orders are posted.
I have only a couple left now from my last build. I'm away on a winter trip for two months from New Year, so nothing is going out until March 2013.
If anyone is hankering after doing the mod then decide now or wait until the spring.
extr400 is offline
post #53 of 164 Old 04-02-2013, 11:17 AM Thread Starter
extr400's Avatar
Adapters are being shipped again.
They are NOT compatible with the new ZX636 2013 bike clocks as these have a new connector pinout and use CANBUS (same as cars). Use only clocks from 2007 to 2012 bikes.
extr400 is offline
post #54 of 164 Old 04-02-2013, 12:32 PM
valleyrider's Avatar
I Ride: 2013 636
Re: 03/04/05/06 ZX636 ZX6R speedo upgrade
Are they still $60?
valleyrider is offline
post #55 of 164 Old 04-02-2013, 12:41 PM
Oh god. I have to have this, so hard.
MasterTurkey likes this.
beckzach05 is offline
post #56 of 164 Old 04-02-2013, 01:07 PM
04zx10rider's Avatar
I Ride: 04 zx10r
ill take one!! so nice! pm me
10 or 6 still faster than your harley
04zx10rider is offline
post #57 of 164 Old 04-08-2013, 11:39 AM Thread Starter
extr400's Avatar
Helping Crazy1 with his project and it seems a 10K resistor between the fuel reserve signal of the ZX6R (new) clocks and ground will disable the flashing fuel light.
This is only used if you have a bike with a reserve switch and no fuel level sensor!
Looking at ZX6-2000 connector pins on the adapter:
-1-2--____---8-
/ <- fit a 10K resistor between pin 2 & pin 9
-9-------------16-
extr400 is offline
post #58 of 164 Old 04-08-2013, 01:02 PM
crazy1's Avatar
I Ride: J1
-1-2--____---8-
-9-------------16-
extr400, thanks again for your help on this. Ive just worked out what the numbers, dots and dashes are above..lol..
Would it be best to fit the resistor to the wires between the J plug and the adapter or the plug pins on the J end of the adapter?
crazy1 is offline
post #59 of 164 Old 04-16-2013, 12:28 PM Thread Starter
extr400's Avatar
Wherever you can get the best access, just go for it.
extr400 is offline
post #60 of 164 Old 04-16-2013, 02:56 PM
crazy1's Avatar
I Ride: J1
Im going to throw a spanner in the works now as i plugged it in the other day to show a forum member who came over to see how the project was coming along and to pick up some j bits i promised him and the fuel light and fuel warning did not come on, i think two wires on the J model end of the connector touched together as i had the shrink cover slid up the wires exposing the connection pins on the back of the plug. Just to note i am am extremely happy with this adapter and everything works perfectly including the gear indicator, i have it set on the B1H setting with standard gearing as my bike is standard gearing too and it works seamlesly. Superb piece of kit.
I will figure out how i have managed to turn out the fuel warning tomorow without the resistor and let you know.
crazy1 is offline
03 zx6r gauge swap harness
05 zx6r gauge conversion to 07
05 zx6r gauge swap extr
05-06 636 speed gauge
2003 kawasaki zx6r speedometer upgrade
2008 kawasaki ninja zx6r speedometer
extr400
iso 04 zx6r gauge cluster
kawasaki zx6r 1998 digital clock upgrade
kawasaki zx6r cluster can i update
zx6r speedo upgrade
speedo healer for 2000 zx6r Infi17yte13 The ZX6R 1 07-01-2009 04:22 PM
FREE Copies of 05-06 Service Manual ZX6R ZX636 Ninja636XXL The ZX6R 18 02-01-2009 10:14 AM
