Goodridge Superbike front 3-line brake kit? - ZX6R Forum
post #1 of 16 Old 04-21-2012, 08:34 AM Thread Starter
I Ride: 09ZX6R
Has anyone installed the Goodridge Superbike 3-line front brake line kit on 09+ model, kit came with no instructions? Don't know which line goes where, lines not labeled. Lines don't appear long enough to be routed in front of forks. Kit is clearly labeled for 09 ZX6R. Any Pics or advice out there
ninjabobs is offline
post #2 of 16 Old 04-21-2012, 08:42 AM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Iv got the Goodridge 2 line kit on mine. (different bike from yours)
But it should be easy enough, If its the 3 line kit, I'm assuming its got a T joint.
It should go like this:
1 banjo gos to your master, the other 2 go to the calipers, The longer of the two(if one is longer)
gos to the left (clutch) side of the bike.
Simple enough.
read only one page"
oldninjadude is offline
post #3 of 16 Old 04-21-2012, 08:48 AM
On 2nd thought, if you have never done brakes before,?
Here's a bit more, Take your old set off(remembering exactly how it was assembled)
Now lay it on the floor, Lay your new components next to the old & build it accordingly.
Remember not to tight down the crush washers until your certain of your positioning.
You should only use them once.
When you get everything in place & your sure it looks right then & only then tighten it all down.
read only one page"
post #4 of 16 Old 04-21-2012, 08:52 AM
Farmboyzx6r's Avatar
I Ride: 2014 Daytona 675R, 2009 black zx6r-Totaled :(
Take some pictures before you take off the old ones so you can refer back to them if you forget how stuff goes. That usually helps me ALOT!
Originally Posted by Schooley View Post
DO NOT put a baffle in the racefit! Let that mf'er sing for the world the hear!
Farmboyzx6r is offline
post #5 of 16 Old 04-21-2012, 11:06 AM
oKayH's Avatar
I've got that kit on my 09. I just redirectioned it until I found the correct orientation (only 3 combos so won't take long). I'll take pictures when I get home tonight if you still need them.
CCS EX
More gas, less brake
oKayH is offline
post #6 of 16 Old 04-21-2012, 01:02 PM Thread Starter
I Ride: 09ZX6R
I would really appreciate the pics. Did you install your kit in front of or behind fork tubes?
post #7 of 16 Old 04-21-2012, 03:08 PM
You will want to put them like you stock lines, id say there behind the tubes.
@ the top they will start in front of the tubes, Drop down between & behind the tubes.
read only one page"
post #8 of 16 Old 04-21-2012, 03:12 PM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
Just take the lot off in 1 go and then build the new lines the same. My hell lines are 2 bit front. Longest goes to the left
still lovin forever!
arron is offline
post #9 of 16 Old 04-21-2012, 04:26 PM
Gav179's Avatar
I Ride: 2010 ZX10R
If you gone to the trouble of buying goodridge braided hoses, why didnt you get the 2 line race setup for better and stronger braking, one line to each of the calipers direct from the master cylinder, and to answer your question the lines go behind your forks
2009 ZX10R
* Tailtidy * Dark tint D/B airflow screen * HEL braided lines * Pazzo replica levers
Gav179 is offline
post #10 of 16 Old 04-21-2012, 04:35 PM
oKayH's Avatar
These lines have 1 connection off the MC and have a T-tap in the middle. I had Galfer 2 lines on my 636 and honestly, I can't tell a difference in feel. Just keep the brakes properly bleed with quality fluid. It was easier to get fluid into these Goodridge lines initally however...
I ran the joints behind...
I'll have the front end off sometime before the 29th for swapping to track fairings. Let me know if you would like a better view...
CCS EX
oKayH is offline
post #11 of 16 Old 04-21-2012, 05:22 PM
I've got the 2 line set on the shelf in the shop now. Can't decide if I want to put them on or get the set with the T. I prefer the look of the T set.
post #12 of 16 Old 04-22-2012, 06:49 AM Thread Starter
I Ride: 09ZX6R
It took some time but I got it figured out. Thanks for the pics, it made a big difference.
post #13 of 16 Old 04-28-2017, 06:07 AM
blank's Avatar
I Ride: 06 CBR600RR (Sold), 2010 R1 (Sold), 2014 1199R, 2014 ZX6R
How are the goodridge build quality? I got Spieglers Rennsports and I'm not happy with the fitment.
blank is offline
post #14 of 16 Old 04-29-2017, 02:30 PM
mharrison's Avatar
I prefer the two line myself. Less connections means less potential for leaks.
mharrison is offline
post #15 of 16 Old 04-29-2017, 06:01 PM
I Ride: 13 zx6r, Tuono V4, Grom
i have the goodridge 3 line kit
3rd line is the rear line no?
Fxclm5 is offline
Bohemian Racing Adjustable Rearsets ZX6R Kevin2109 The ZX6R 130 12-26-2013 05:04 PM
How to: Install Stainless Steel Brake Lines Chaos Guides 18 04-02-2012 06:52 AM
BUY a FRONT Set, and get Rear FREE.!!!) GALFER SS BRAKE LINE FORUM SPECIAL SALE ICHIBAN The ZX6R 12 11-15-2011 08:37 PM
Front Brake LIne Burst. Es617 Mechanical and Technical 8 05-02-2011 01:10 PM
