The Official Bazzazz Q&A Thread - Page 4 - ZX6R Forum
 29Likes
post #46 of 355 Old 01-29-2013, 03:27 PM
Super Moderator
EvilTwin's Avatar
Originally Posted by 12zixR View Post
need some clarification here..
If I get just the z-fi, I will have to manually map it. If I get both z-fi and z-afm, the z-afm will suggest maps for me and I just do what it suggests? Is this an accurate way of looking at it?
Apologize for the possible dumb question but I want to clear things up before I drop 600+ bones if I don't absolutely need to.
I have a custom slip on and a bmc air filter btw
Pretty much, the Z-Fi by its self has no auto mapping abilities; the Z-AFM (when combined with a Z-Fi) will acquire data while you ride, then show you the changes it wants to make to your active fuel map. You can then choose to accept all or select parts of the changes or none at all.
EvilTwin is offline
post #47 of 355 Old 01-29-2013, 03:38 PM
I Ride: 2012 Black ZX6-R
Ok. Is it hard to do yourself if you don't know what you are doing?
12zixR is offline
post #48 of 355 Old 01-29-2013, 03:46 PM
Super Moderator
EvilTwin's Avatar
No it's pretty easy. We've got some instructional vids on our website about mapping; take a look at those and let me know if you have any other questions.
EvilTwin is offline
post #49 of 355 Old 01-29-2013, 03:50 PM
Right on man appreciate the quick help. I'll def take a look at that and ask any other questions if they come up
12zixR is offline
post #50 of 355 Old 02-02-2013, 07:13 PM
Nickoli's Avatar
I Ride: 08 ZX6R
So im going to buy the zf-I unit for my bike. What kind of maps are offered directly from Bazzaz? I'll have a rs5 and a factory header that I will be cutting the cat out of, kleen air mod and thats really it for engine performace besides an air filter.
If there is a tune that can get It close right off the start I would be happy. I'm am going to try and find a shop in my area that has dealt with and tuned Bazzaz systems before for my custom tune.
Nickoli is offline
post #51 of 355 Old 02-04-2013, 09:07 AM
Super Moderator
EvilTwin's Avatar
For the 08 we just have slip-on maps; the one that comes in the control unit was made with an RS5 slip-on I believe, and then I made one for my two-bros slip-on.
EvilTwin is offline
post #52 of 355 Old 02-04-2013, 02:54 PM
Nickoli's Avatar
I Ride: 08 ZX6R
How far off do you think the map would be without the CAT and air injection system?
Nickoli is offline
post #53 of 355 Old 02-06-2013, 05:55 PM
rideordye's Avatar
quick question, is the bazzaz worth it if i dont get a full exhaust? just got a slip-on, new filter, and sprocket change. and im talking about the standard zi-fi w/o TC and quick shift as i am not to keen on either. well maybe the TC.
rideordye is offline
post #54 of 355 Old 02-06-2013, 07:01 PM
Nothinguntil's Avatar
I Ride: 2006 zx6r 636. Blue
I followed eviltwins advice and purchased the z-afm with my z-fi controler. I live at high altitude. So I know if I use a standard map with a slip on from bazzaz it will come from sea Level. i'm excited to get my crap installed and tuned
Nothinguntil is offline
post #55 of 355 Old 02-07-2013, 07:51 AM
Super Moderator
EvilTwin's Avatar
I have my kleen air system blocked off too, that doesn't effect fueling. My map will be a little leaner than you'll want once the cat is removed. Can't say how much though, I've never tuned one of our bikes with a gutted header.
The short answer is yes, it is worth it. The long answer is to read the article about fuel controllers linked in my sig.
EvilTwin is offline
post #56 of 355 Old 02-20-2013, 09:47 AM
EvilTwin is a bad ass
Thanks for all your help! After going through everything and loading the new driver I still couldn't get connected to the ZFi. I was talking with my brother about my issue and he said to try another usb cable. I told him that I have never in my life had a bad USB cable. Well sure enough, I replaced the usb cable and I have no issues connected to the ZFi unit. All that just from a bad cable. Any way next week I'm hoping the weather will clear up so I can mess with the auto tuner. Thanks again for all your help and I'm sure I will taco soon.
post #57 of 355 Old 03-16-2013, 11:27 PM
You won't be disappointed.
Well I have finally been able to tune my bike this weekend and I am not disappointed. I also feel like I could be making changes to my fuel map all week of I wanted to. I have noticed a huge difference in both power and throttle responce. Cant wait to really start riding this summer
post #58 of 355 Old 03-23-2013, 07:41 AM
MarylandZx6r's Avatar
I Ride: 2009 zx6-r
I have a yoshi rs4 slip on with a pine box link pipe and mjs headers. Virtually a full system now for a 2009zx6r. Also have BMC race filter as well.
Once i get the zf-i is it just plug and play? is their a proper map i can download that can take advantage of this? I live in maryland as well
o_O
MarylandZx6r is offline
post #59 of 355 Old 03-23-2013, 12:13 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
yes all the bazzaz systems are direct plug and play...they have a map preinstalled for your ride if u get it from them... if you get it from else where u will need to DL a base map from Bazzaz.net.....
the map IS NOT 100% ACCURATE!!!! you will still need to get a proper tune done by a dyno tech...
2010 ZX6R-Ti Valves-Billet deg.cams-MPQT Throttle-Type A&C Trans-Bazzaz ZFi-QS-TC-Ign.Mod.-M4(full) exhaust-MBR AMA Engine-BMC Race filter-SMEv3-SpeedoDRD-STPS mod-Magnesium Wheels-R10 type 3-RK gold-15f/16f w/42r,44r,45r spkts.-ohlins 25mm forks, ohlins TTX36 Markll shock- brembo ft/rr Mstr. cyl-SS lines-Vesrah Sinterd pads-galpher wave ft/rr rotors-alumalite tripple clamps-custom paint-tank foam-tecspec pads-VDS mod-Manual dual fan-Radiator guard-keyless ign.-dual mapped.
BMW Motorrad, Suzuki Gold, Kawasaki, Triumph, Polaris/Victory, Can-Am, Sea Doo, Ski Doo,& Spyder Certified Technician !!! and KTM qualified Technician.
09ZX-6R is offline
post #60 of 355 Old 03-25-2013, 08:10 AM
Super Moderator
EvilTwin's Avatar
Yeah like 09ZX-6R said, everything is plug and play, but the map that comes on the unit was made for a slip-on exhaust with stock filter. So with your setup I'd recommend getting a custom tune done, as we do not have any maps for full systems, since they're all a bit different from each other.
EvilTwin is offline
07 , bazzaz , bazzazz , dyno , dyno tune , efi , eviltwin , quick shift , traction control , tuning
2003 zx6r bazzaz
2009 zx6r launch control
2012 zx6r bazzaz
bazzas zx6r
bazzaz forum
bazzaz location 07 zx6r
bazzaz maps for zx6r
bazzaz qs sensor type
bazzaz z fi instalation on a '06 636
bazzaz zfi benefits on 2013 ninja 636
bazzaz zx6r
zx6r f changes
The official "Rider Down" Thread MistressOfMayhem Motorcycle Talk 2 04-15-2012 10:48 PM
Official Maryland Spotted Thread HotIce East Coast 46 09-21-2011 07:32 PM
