2013 ZX6R Issue's - Page 10 - ZX6R Forum
 98Likes
post #136 of 1098 Old 05-03-2013, 03:31 PM
Duane S's Avatar
Originally Posted by ZXNasty View Post
I wasn't commenting on the original problem just on the mechanics so called advice because it's not correct.
POW! Shits true stocks are just as good
Duane S is offline
post #137 of 1098 Old 05-05-2013, 08:58 PM
rkt14's Avatar
I Ride: 2013 Kawasaki Ninja ZX636
Your air filter won't make the bike die at idle ... if that were the case, it would mean there would be something blocking air flow and the bike would starve for air.
an aftermarket filter won't fix the issue.
1998 Kawasaki Ninja ZX6R (Sold)
2006 Kawasaki Ninja ZX6R 636 (Sold)
2013 Kawasaki Ninja ZX6R 636 (Currently Own)
YouTube : www.youtube.com/c/sc2racer
rkt14 is offline
post #138 of 1098 Old 05-05-2013, 10:34 PM
I Ride: 2013 ZX6R 636
My DFI light came on at 400km's, ran the cluster diagnostic check. Code 34 appears, exhaust flap servomotor fault. Runs fine, but start up it hesitates like crazy.
mtran is offline
post #139 of 1098 Old 05-05-2013, 11:22 PM
Too bad you are having issues. I have had mine since Dec and I have not had any issues. In fact, I have tracked it a few times and will be heading back on the 18th. The bike is a track weapon. I hope you get things sorted.
rkt14 likes this.
coopisone is offline
post #140 of 1098 Old 05-08-2013, 12:06 PM
H00NIGAN's Avatar
Mine did the 3rd times the charm start...but I attributed it to low fuel. Hasn't done it since.
H00N Responsibly
H00NIGAN is offline
post #141 of 1098 Old 05-08-2013, 10:19 PM
rkt14's Avatar
i'm at almost 600km's and she's running perfectly fine . just figuring out that knock or bang is alittle annoying lol
rkt14 is offline
post #142 of 1098 Old 05-10-2013, 10:25 PM
So I brought the bike in for Kawasaki to look at. Told them code 34 was on the cluster. The tech took the seat off and right away said the exhaust flap sensor was bad. New servomotor ordered from Japan.
Now to play the waiting game and have this damn DFI light turned off lol.
mtran is offline
post #143 of 1098 Old 05-11-2013, 01:46 PM
rkt14's Avatar
Good to hear they're taking care of it for you !
rkt14 is offline
post #144 of 1098 Old 05-11-2013, 04:49 PM
Hiltz's Avatar
I am now at 1300 K and no issues. there was one day that i was having problems going into 4th but havent had it again. everything be iry!
rkt14 likes this.
2013 Kawasaki ZX6R 636
*TwoBro's Carbon slip on w/link pipe
*K&N Intake filter/Oil filter
*Conti Road Attack 2 EVO's
*Driven Shorty clutch/brake Levers
*1down/2up Driven Sprockets w/Driven black hub nuts
*D.I.D Oring Chain Gold
*Ergo grips, Stud bar ends, Quick fill machined gas cap
*Integrated Tail/Fender Eliminator
*Plasti-Dip Black Out, Wheel decals, Tank protector
Hiltz is offline
post #145 of 1098 Old 05-23-2013, 07:18 PM
j0n0070's Avatar
I Ride: 2013 Kawasaki zx6r(crashed) - 2012 Ducati Monster 696
i havent had any issues with the starting my self but i do let the bike warm up while put on my gear, i have noticed the veering to the right as well but right now shes at the dealer getting the 600 mile service done so i mentioned it to them hopefully they will figure it out
j0n0070 is offline
post #146 of 1098 Old 05-23-2013, 08:29 PM
I Ride: 13 zx6r
I got that starting problem also in the am
8thgenj35 is offline
post #147 of 1098 Old 05-24-2013, 03:14 AM
New servo motor installed, took the tech 2 hours to figure out how to turn off the DFI light lol. Apparently the software he had at the dealer didn't want to communicate with my bike.
Runs like it did from day 1, starts up the first crank, runs smooth.
mtran is offline
post #148 of 1098 Old 06-04-2013, 05:49 PM
I Ride: 2013 636 ABS
Anyone with the cold start issues have an update? My bike would start first try 80% of the time and second 20%. Now at just shy of 600 miles today it died like 4 times before I held the throttle a bit to get it started.
Taking it in for the first service in a few days, wondered if anyone had found a solution or problem to mention when I go rather than just, "lots of other people on the internet said this too."
FightTest is offline
post #149 of 1098 Old 06-05-2013, 04:48 PM
I Ride: 2013 636
same here, it sounds like the forks are loose, but only under about 10mpg, and my 13's takes a little throttle on a cold start to, :l and mine idles just fine when warm, like 1300 rpm
N to 1st i have the same problem of not finding the gear, but i give it a tiny push forward or back and it gos in fine,,
greengoblinn is offline
post #150 of 1098 Old 06-06-2013, 08:04 AM
rkt14's Avatar
I've been having this knock issue since day one riding my 2013 636 .. i'm going to be taking it in for my first service a week from this upcoming monday,
I'm going to let the dealer know my issue, and we'll see if they can figure it out.
rkt14 is offline
2013 kawasaki zx6r 636 cold start problem fixes
2013 zx6r
2013 zx6r idle
2013 zx6r is bad
2013 zx6r review
21175-0811
kawasaki zx636 code 39
kawasaki zx6r issues
ninja 636 2013 common problems
vapor lock 2013 zx6r
zx 636 known issues
zx6r 2013
Parts compatibility list ! Stiggy Mechanical and Technical 151 12-16-2016 10:23 PM
2005/2006 zx6r - color / add ons / issues / milleage/ PIC! brar The ZX6R 244 01-12-2014 07:53 AM
2013 ZX6R Graves Slip-On ilotek The ZX6R 51 02-01-2013 02:03 PM
NEW!!! 2013 ZX6R Graves low mount Slip on fits 09-12 as well!!! smokey11 Mechanical and Technical 36 11-20-2012 11:45 AM
