oil pressure light on - ZX6R Forum
post #1 of 5 Old 05-11-2008, 03:31 AM Thread Starter
sir nose's Avatar
I Ride: green zx6r ninja b1h
after i changed my engine oil(putoline) and oil filter(genuine kawasaki) on my 03' 6r,i started the engine and the oil light did'nt go out,i waited a moment turned the engine off and started it again waited a moment,gave the throttle a little twist,still the oil light stays on.there are no noises from the engine,the engine has no oil leaks,its always had regular oil changes.i guess the obvious thing is the oil pressure switch/sensor,does anyone know how to test the oil pressure switch/sensor,ive tested the wiring,i.e if i earth it the light comes on take away the earth and the light goes out.
sir nose is offline
post #2 of 5 Old 05-11-2008, 03:45 AM
Steve_TLS's Avatar
I Ride: GSXR1000K3
Did you prime the filter by filling it before fitting it? Even so, after a moment or two it should still make pressure.
The only real way to test the switch is to remove it and apply pressure to it. Or remove it and fit a gauge and see if there is pressure there or not.
Steve
"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
N6Z Forums Staff - Resident Antipodean
Questions about the Forums? Click Here
Help Support Ninja6Zone: Subscribe
-TLzone- -Ninja6zone- -RSVzone.com- -TuonoZone.com-
-My TLS pages- -My GSXR pages- -My Dyno pages- -My Blog-
Steve_TLS is offline
post #3 of 5 Old 05-11-2008, 04:17 AM
I Ride: speed3 1050 & 636 05
there is probably airlock in it. loosen the filter, start the bike, and when oil starts to come out of the loose filter, screw it back on.
jarkkot is offline
post #4 of 5 Old 05-11-2008, 04:26 AM Thread Starter
sir nose's Avatar
you fuhkin' legend,ive never heard of an air lock in the oil.cheers jarkkot
sir nose is offline
post #5 of 5 Old 05-11-2008, 04:38 AM Thread Starter
sir nose's Avatar
i had tested the pressure switch by applying air to it, was thinking the worst,i was cleaning a bucket to drain the oil into when the phone rang,while i was indoors i thought i'd check if anyone had replied,thank the lord for ninja6zone i was on the way to removing the sump.i could have ended up stripping the engine out.
sir nose is offline
2000 ninja zx6r losing oil pressure
2000 ninja zx6r oil light staying on
2003 kawasaki 636 oil pressure sensor
2003 ninja zx6r oil change no oil pressure
2006 kawasaki zx6r oil light in
2009 zx6r oil light
kawasaki zx6r pressure swicth
kawsaki oil sensor zx6r
low oil pressure light on kawasaki engine
were is the oil sensor light located on a 03 zx6
zx6r oil light on
zx6r oil light stays on
Stalled bike and red oil light came on ACD1055 United Kingdom 17 08-17-2011 10:18 AM
New member with oil light problem Ninja Noob The ZX6R 14 08-16-2009 10:52 PM
No oil pressure for 2003 ZX6RR. Gurus, I need you! N3RB The ZX6R 11 01-02-2009 06:05 PM
