Removing Cats from Stock Headers = Full Exhaust - ZX6R Forum
 27Likes
post #1 of 30 Old 04-17-2013, 08:34 PM Thread Starter
Half Wit's Avatar
So I did a quick search and found some dated threads on people punching out the cats from the stock headers of 09-12 zx6rs. Mostly how-to's. Seems pretty straight forward and can be done with headers still on the bike. Drill out multiple holes until most of it comes out and scrape off the residual honey combs / dust.
What I'm really interested in is what gains / drawbacks does this create? I have an FMF Apex exhaust with the "boom-box" or pre-muffler removed so this would essentially create a "full exhaust."
Obviously this would require a power commander or a remapping. Has anyone done this and if so:
1) Does this create the same performance gains as you get from full race headers?
2) Could there be performance loss due to lack of back pressure even after re-mapping?
3) Also heard that the cats sit in a small expansion chamber which when cleared, reduce flow through the headers??
4) How does this sound versus leaving the cats in?
Hope to get some real facts on the mod, so thanks in advance for the contributions!!
Half Wit is offline
post #2 of 30 Old 04-17-2013, 10:03 PM
smokey11's Avatar
I have done this, I ran a similar set up to you and had good results so I will try to answer your questions.
1) You will get similar performance gains but not the same, most gain about 9hp with gutted header which is on par with most full sytems give or take 1-3 hp. A full system should gain more in the higher revs while gutted stock header might be a little stronger in the mid range. The true advantage of gutting your header is the money saved vs a full system, I spent 225 on a slip on and you can gut the header for free as opposed to 750-1700+ on a full system.
2) I did not see a performance loss anywhere after tuning, don't know why you think you would that. A proper tuner will tune to gain performance... In fact my bike ran cooler as well.
3) I never heard that and that makes no sense to me, when looking at this pic of my stock header gutted. The whole point of clearing it out would be to increase the flow.
4) Sounds about the same to me maybe a little deeper, I couldn't really hear a difference.
Here's my dyno chart so you can see the power curve etc, (sorry it's sideways) pretty straight and smooth and good power gains through the whole rev range, seems like a win win to me
MrZ likes this.
__________
Mods
smokey11 is offline
post #3 of 30 Old 04-18-2013, 06:14 AM Thread Starter
Half Wit's Avatar
Thanks Smokey! Very helpful, are you running the PCV?
Half Wit is offline
post #4 of 30 Old 04-18-2013, 06:30 AM
martydmb's Avatar
He is running a bazzaz ZFI TC which is listed on his post
[[11' zx6r green & black]]
martydmb is offline
post #5 of 30 Old 04-18-2013, 06:31 AM
Sandman's Avatar
I Ride: 16 WRX, 11 Fusion
Generalization of benefits of an aftermarket full exhaust vs gutting cats:
-- Larger diameter piping.
-- Smoother, faster exhaust flow.
-- Better, lighter materials.
-- Higher total power.
-- Better heat dissipation.
-- Volume/tone (subjective).
-- Looks (also subjective).
Edit - With either aftermarket or modifying stock exhaust you'll have to adjust the tune. Also, with aftermarket, the pieces all work together as designed, modified stock parts do not.
Sandman is offline
post #6 of 30 Old 04-18-2013, 06:53 AM
trackdayhero's Avatar
I just leave my cat in there.
Lee76, PowerGroove, Venge and 11 others like this.
trackdayhero is online now
post #7 of 30 Old 04-18-2013, 07:54 AM
tails636's Avatar
I Ride: 06 Black 636
^lmfao
2006 ZX6R (636)*Yoshimura RS-5 Slip on*Power Commander*Vortex -1/+2 Front and Rear Sprockets*EK 520 Gold Chain*Bohemian Racing Gold Rearsets*Integrated Tail Light*Smoked Flush Mount Front Signals*Hotbodies Blacked Out Windscreen*Frame Sliders*8000K HIDs*Adjustable Lowering Links (currently lowered 1 1/4")*Tank Pad*Stomp Grips
tails636 is offline
post #8 of 30 Old 04-18-2013, 08:40 AM
smokey11's Avatar
Actually, I was running a PCV for this set up and dyno runs, but yes I'm running a Bazzaz now but with a whole different set up.
__________
Mods
smokey11 is offline
post #9 of 30 Old 04-18-2013, 10:19 AM
kone35's Avatar
I Ride: 2001 j2
I used to gut cats on the regular......then I got married.
Now, I only gut cat every now & then, so I make sure that I make it memorable when opportunity presents itself.
kone35 is offline
post #10 of 30 Old 09-17-2014, 07:30 PM
636 Mike's Avatar
I Ride: 2013 Kawasaki Ninja ZX6R 636
Hey smokey11, did you have to remove the header? If so, does that mean you also have to remove radiator?
636 Mike is offline
post #11 of 30 Old 09-17-2014, 09:35 PM
smokey11's Avatar
I actually bought a MJS header so the work was done off of the bike and the header installed but I do recall people saying they drilled and did the chisel work with the header still on the bike, apparently they just used a shop vac to suck out the leftover cat material
__________
Mods
smokey11 is offline
post #12 of 30 Old 09-17-2014, 10:53 PM
636 Mike's Avatar
Cool, thanks.
636 Mike is offline
post #13 of 30 Old 09-18-2014, 05:31 AM
oic0's Avatar
If you don't mind your neighbors hating you, you could just start it and give a blip.
863JOE and Gawernator like this.
oic0 is offline
post #14 of 30 Old 09-18-2014, 06:31 AM
Schooley's Avatar
De-catting the headers is a little more physical than just scraping away what's left after drilling. It's worth it, but you're going to be sweating by the time all is said and done.
Schooley is online now
post #15 of 30 Old 09-18-2014, 07:28 AM
Sandman's Avatar
....and certainly bleeding.
........and probably crying.
That makes the trifecta complete.
PrestonK, zaneyard and Gawernator like this.
Sandman is offline
03 zx6r cat
03 zx6r facts
05 636 cat removal
05 zx6r cat delete
2006 zx6r exhaust to header
2006 zx6r headers
gutting cat zx6r
ninja 300 header cat removal
ninja zx6r no cat stock muffler
z 750 original header remove cat
zx6 cat removal
zx6r 09 stock header material
Zx6r 2006 stock exhaust and headers cha12les Classifieds 2 08-14-2012 08:51 PM
FS: Full OEM exhaust for 2005-2006 ZX6RR emiller480 Classifieds 1 08-06-2012 01:22 PM
WTS: Gen2 (05-06) full stock Exhaust and servo motor 06sixdirty6 Classifieds 0 06-20-2012 08:35 AM
Stock exhaust zx6r 04 902zx6r Mechanical and Technical 1 06-04-2012 01:23 PM
FS: Vance Hines CS One Slip-on, Stock Headers, Stock Tires IDWIN Classifieds 11 04-19-2012 06:13 PM
