my zx6r is dead I need a miracle - ZX6R Forum
 9Likes
post #1 of 28 Old 05-11-2013, 08:38 AM Thread Starter
I Ride: 1999 ZX6R
I don't know whats going on with my bike. Its not getting power for some reason. New battery just charged, spark plugs, all the fluids but still getting no power. Please help me I need to get my bike on the road
ninja3475 is offline
post #2 of 28 Old 05-11-2013, 08:41 AM
Venge's Avatar
I Ride: 2012 Ninja ZX6R (Rin), 2015 KLR
No power = You turn the key, push the starter and nothing happens?
2012 ZX6R "Rin"
Akrapovic Full Racing Exhaust | K&N High Flow Filter | Vortex V3 Frame Sliders | RaceTech Springs | TechSpec Tank Pads | ASV Levers | T-Rex Fork Sliders | PCV | Zero Gravity Corsa | CustomLED Integrated Tail
"im not into riding curves and ish man and yall getting crazy chillout i want ur opinions but dont call me a squid i no alot about
zukis maybe not as much as yall but deff not comparable to a squid w.e yall say buttt" - Benjamin Franklin, Esq.
Venge is offline
post #3 of 28 Old 05-11-2013, 09:24 AM Thread Starter
I Ride: 1999 ZX6R
yeah thats it
post #4 of 28 Old 05-11-2013, 09:31 AM
When you push the starter
a)nothing happens at ALL
b)engine turns over but won't fire up
Actually just give us a video. Did this happen right after you changed sparks/fluids/etc? If so, something may have been installed incorrectly.
rayshon is offline
post #5 of 28 Old 05-11-2013, 09:33 AM
ninjazx6r636's Avatar
I Ride: 2013 green-black zx6r 636
Checked fuses? Especially the main one?
2013 Green/black 636 - stock
ninjazx6r636 is offline
post #6 of 28 Old 05-11-2013, 09:37 AM Thread Starter
I Ride: 1999 ZX6R
yeah it was doing it before to, I put the key in turn to on, press the starter no noise at all. not even a click as if it was trying to start
post #7 of 28 Old 05-11-2013, 09:43 AM
Any lights come on?
post #8 of 28 Old 05-11-2013, 09:50 AM
Ebster1085's Avatar
When you turn the key to the on position, do the gauges illuminate? Does the headlight come on? Do you hear the fuel pump prime?
Have you checked the voltage of the battery? You should have around 13 volts
Sounds like you may have an issue with the kill switch or the ignition button. If all of the above checks out, take apart the kill switch/ignition button component and inspect for damage. With the kill switch turned to the on position, check voltage at the connection point. Should also be around 13 volts. Do the same with the ignition contacts.
Ebster1085 is offline
post #9 of 28 Old 05-11-2013, 09:51 AM Thread Starter
I Ride: 1999 ZX6R
all the fuses are good, won't even push start when i pop it into second
post #10 of 28 Old 05-11-2013, 09:52 AM Thread Starter
I Ride: 1999 ZX6R
no gauges are lighting up either, could hear the fuel pump but then it stopped after the lights and everything went dead to
post #11 of 28 Old 05-11-2013, 01:40 PM
ProAv's Avatar
I Ride: ZX6R
obvious its an electrical problem so nothing engine wise i guess but i aint no mechanic lol. id say start checking voltages from the battery and follow along to starter etc seeing if theres any power getting there.
Venge likes this.
ProAv is offline
post #12 of 28 Old 05-11-2013, 02:24 PM
Ebster1085's Avatar
If the gauges and headlights arent even coming on it sounds like nothing is getting power. You sure your main 30amp fuse isnt blown?
Believe it or not I have seen cases where even though a fuse looks fine, it is still no good. If you have a multimeter start probe both sides of the fuse to ensure that voltage is still crossing the terminals.
863JOE, RJ2112, beckzach05 and 2 others like this.
post #13 of 28 Old 05-13-2013, 11:09 AM Thread Starter
I Ride: 1999 ZX6R
Ebster1085 your a life saver, was just 30amp simple fuse. Almost took it to a shop
4htrs likes this.
post #14 of 28 Old 05-13-2013, 11:27 AM
Dude, good call.
Howitzer likes this.
beckzach05 is offline
post #15 of 28 Old 12-09-2013, 02:35 PM
I Ride: 2012 ZX6R
Bump. What is the voltage for the 30 amp fuse?
yefrem is offline
03 ninja 636 has no power
07 zx6r no power when turn the key on
07 zx6r press start button then goes dead
2013 zx6 makes no power
2013 zx6r no ignition
98 zx6r no power wont turn over
99 zx6 no lights
fuses on a zx6r
no power when i hit my start button 99 zx6r
why do the red light on my 2000 zx6r not turn on when i turn the key
zx6r no electrical power
zx6r no power
Parts compatibility list ! Stiggy Mechanical and Technical 151 12-16-2016 10:23 PM
FS: 03-04 ZX6R 636 Part Out/ 2000 ZX6R Misc. NickM Classifieds 151 02-11-2016 08:20 AM
Comparison: 98'-02' and 03'-04' ZX-6R WakeDude Mechanical and Technical 14 04-21-2013 08:48 PM
Exhaust headder swapping? arron Mechanical and Technical 8 05-31-2012 03:01 AM
Can a 95 zx6r cam chain tensioner be used for 98-02 zx6r? idriftnaked Mechanical and Technical 0 05-20-2011 02:44 AM
