Teouble upshifting - ZX6R Forum
post #1 of 21 Old 05-11-2013, 02:50 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
Teouble upshifting
Ok guys I'm having trouble upshifting don't know if it's me or something wrong with bike. I press clutch lever and shift up but it does not Change gear. It does not do this all the time but sometimes it I have to shift I up a few times before it will switch. It's not one gear in particular but mostly 2nd to 3rd and fourth to fith. No problems down shifting. I just broke thousand miles on bike and this has got me worried. Just started doing this today
I'm one of those guys that jumps off a bridge and on the way down realizes he forgot to tie off the bungee cord
Kawiwolf is offline
post #2 of 21 Old 05-11-2013, 02:53 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
Damnit I should have put this in mechanical techinical section
Kawiwolf is offline
post #3 of 21 Old 05-11-2013, 03:24 PM
Berzerker's Avatar
I Ride: 2009 zx-6r
Id say a case of weak/lazy shifter foot. Maybe check your clutch adjustment also.
Berzerker is offline
post #4 of 21 Old 05-11-2013, 03:32 PM
hellonearth's Avatar
I Ride: 2007 zx6r :D
You don't really even need your clutch for up shifting. Its just that yiu need to get used to shifting and leqrn the distance you have to move the shifter in order to change gears.
hellonearth is online now
post #5 of 21 Old 05-11-2013, 03:34 PM
Also if its a super persistant problem switch to gp shifting so the patter is reversed to 1 up 5 down.
post #6 of 21 Old 05-11-2013, 03:38 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
I thought I may be being to easy on the lever
Kawiwolf is offline
post #7 of 21 Old 05-11-2013, 03:40 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
I thought bout switching to gp style anyway how do u do that
Kawiwolf is offline
post #8 of 21 Old 05-11-2013, 03:42 PM
Take a flip the shift boot coming off the transmission 180*
post #9 of 21 Old 05-11-2013, 03:54 PM
I Ride: 2013 ZX6R 636
Are you positively lifting your foot all the way? If you are, maybe it's time to bring it in for warranty?
mtran is offline
post #10 of 21 Old 05-11-2013, 04:01 PM
I Ride: '13 NC700X, '13 ZX-6R, '12 STI GVB
I agree, don't fuck with it. Use the warranty while you have them.
MadeInJapan is offline
post #11 of 21 Old 05-11-2013, 04:53 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
Going to make sure it's not just me if its not going to use warranty
Kawiwolf is offline
post #12 of 21 Old 05-11-2013, 05:30 PM
martydmb's Avatar
Have the same problem on my 11' around 1600 miles but is 4th to 5th gear.
[[11' zx6r green & black]]
martydmb is offline
post #13 of 21 Old 05-11-2013, 06:24 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
What was wrong
Kawiwolf is offline
post #14 of 21 Old 05-11-2013, 06:25 PM Thread Starter
Kawiwolf's Avatar
I Ride: 2012 zx6r
Awsome avatar
Kawiwolf is offline
post #15 of 21 Old 05-11-2013, 07:02 PM
I Ride: 06 ZX6R, 93RGV250
Sometimes when im giving the bike a bit of shit i have trouble shifting into 3rd.
I put it down to me not releasing the gear lever all the way down before trying to shift again.
Like everyone else has said, examine your technique before looking at the bike for issues.
Hilters Cat is offline
a4ld trouble upshifting
