Hard acceleration and front end wobble? - ZX6R Forum
 6Likes
post #1 of 38 Old 08-20-2013, 06:59 PM Thread Starter
kawiDoh's Avatar
I Ride: 2012 zx6r
Alright so ive taken off pretty hard on the zx6 (2012) quite a few times even hitting the rev limiter through 3rd gear with no issues. Tonight I was with a group of guys going to lowell bike night and I cracked it open in first and it just felt like the front end was about to come off tje groulund and the bars started wabbling pretty bad even with the damper on almost the stiffest setting. In fact im pretty sure thats the only thing that saved me. Is this common? I mean It felt like I could have easily picked the front end up if I just pulled up a little at the top of first. Sorry for the long post.
kawiDoh is offline
post #2 of 38 Old 08-20-2013, 07:02 PM
boloson's Avatar
Stock damper? Might as well use a piece of stick as a damper
PowerGroove likes this.
boloson is offline
post #3 of 38 Old 08-20-2013, 07:03 PM
FieldDay's Avatar
I Ride: 2011 ZX-6r CPB
Yeah, thats normal. Just roll off the throttle smoothly. she'll even out.
FieldDay is offline
post #4 of 38 Old 08-20-2013, 07:06 PM
06330i's Avatar
I Ride: 2005 zx10r
Very normal. And if you have a stock damper it does absolutely nothing.
06330i is offline
post #5 of 38 Old 08-20-2013, 07:15 PM
Lobster's Avatar
I Ride: 2008 ZX6R x2 (Track)
Its normal. I typically see it happening just as the front end is lifting up. When I relax my grip on the bars when going WOT, it doesn't shake.
Lobster is offline
post #6 of 38 Old 08-20-2013, 07:26 PM Thread Starter
kawiDoh's Avatar
I Ride: 2012 zx6r
Well I'm glad to hear it's normal (I guess) Guess I'll be getting the damper revalved for my next mod prob over the winter. And I did roll off the throttle easy and it straightened out but it was pretty sketchy especially since its the first time its happened.
kawiDoh is offline
post #7 of 38 Old 08-20-2013, 09:14 PM
Dragone's Avatar
Check your fork seals for any leakage, but as mentioned, the stock damper is a minor band-aide in stock form.
Stable rides: I love stable rides
Dragone is offline
post #8 of 38 Old 08-20-2013, 09:28 PM
ZX6RRECTION's Avatar
My thoughts exactly..learn to push hard without holdin on for dear life
Smooth throttle::::throttle control
ZX6RRECTION is offline
post #9 of 38 Old 08-20-2013, 10:17 PM
WillkilV's Avatar
I Ride: 2001 ZX6R, 2005 ZX6R
All from your bike wanting to power wheelie. Happens once in a while to me but I ride through it and shift up (don't have a damper.) It's from the front tire trying to regain traction!
the 2005-2006 is the best zx6r... evar.
WillkilV is offline
post #10 of 38 Old 08-21-2013, 01:53 AM
My E does this when hammered (-3 front sprocket ), it tends to do it in second gear when it tries to lift the front but doesn't quite get all the way off the ground
Originally Posted by scoobs View Post
dave just tell her you are THE MAN and it was just a pair of nockers nothing more .......
then ask her did you pull over to the side of the road and flop your manhood out and thrash it uncontrollably.......NO
and then ask her did you stop the bus pull the girl out with amazing nockers throw her to the ground and plant your Little Dave into her cream donut......NO
so tell her its life things like that happen........... HAHAHAHAHA
SteveZZR is offline
post #11 of 38 Old 08-21-2013, 02:22 AM
joshgilvin34's Avatar
I Ride: 2011 ZX6R
How do you go about getting the damper revalved? Do I just send ohlins a email or call them or something or is there an exact place to look on the Internet for it. I really wanna do this over the winter.
Hotbodies MotoGP Growler Exhaust
PC5
K&N Air filter
custom led integrated tail light
Driven block off plates
Pine box link pipe
Core moto stainless steel brake lines
joshgilvin34 is offline
post #12 of 38 Old 08-21-2013, 04:46 AM
Sandman's Avatar
I Ride: 06 GTO, 11 Fusion
My 09 did the same thing. Got head shake when wide open in first gear, usually when it gets into the powerband. Scared the crap out of me the few times it happened.
I got my damper revalved through Kyle Racing. It's completely different now.
Sandman is offline
post #13 of 38 Old 08-21-2013, 04:46 AM
Ebster1085's Avatar
If you crack her open in first, yes, it is normal for the front wheel to want to come off the ground and feel light.
Also, you mention your damper. Is it the OEM one that came with the bike? if so, those things have vastly inadequate valving, and without a revalve, they are almost useless.
Track Bike: 2006 ZX6R
Daily: 2007 Speed Triple
A link to my build thread!
Ebster1085 is offline
post #14 of 38 Old 08-21-2013, 05:35 AM
hotleadsinge's Avatar
Yup. Grip the tank with your knees when it happens and you should have no trouble.
Also, relax your grip a bit when blasting.
~Current~
2013 Kawasaki ZX6R (636EDF)
2000 Honda Nighthawk 750
~Previous~
2006 Yamaha R6
2007 Kawasaki ZX6R
2004 Kawasaki ZX10R
hotleadsinge is offline
post #15 of 38 Old 08-21-2013, 05:40 AM Thread Starter
kawiDoh's Avatar
I Ride: 2012 zx6r
Yea I always try to constantly remind myself of this and usually I am pretty relaxed. Especially in corners. I dont remember if I was gripping the bars tight or not when it happened I probobly was
kawiDoh is offline
07 zx6r front end shake
08 kawasaki zx6r wheel shake
2001 zx6r front tire shakes
front end wobbles under acceleration
front wheel skip acceleration
motorcycle front end goes light under hard acceleration
traction control zx6r what setting to use normal
what causes front end to shake on zx6r
wobble front superbike
zx6r 1st gear wobble
zx6r 636 wobble
zx6r hard acceleration
Because Race bike. ConradM Pictures 66 07-26-2013 05:52 AM
Violent back and forth front wheel wobble under hard acceleration? SadbutTrue Mechanical and Technical 13 10-18-2011 12:24 AM
