1998 ZX6E carb problem - ZX6R Forum
post #1 of 4 Old 07-08-2008, 11:47 AM Thread Starter
Guys
I am having a maddening intermittent problem with my carbs. About 80% of the time when I am riding about 70mph@5600rpm I get a pronounced surge. I get the same rough engine behavior if the engine is loaded up (up hill low-moderate rpm). If I am on the hwy at 70mph (engine surging) and unload to stop at a light or intersection...the engine has died when I pull the clutch in and/or runs like crap at the idle. At any speed, if I crack the throttle open the engine reponds perfectly up to redline. WTF? Help! - Jim
Maxvne is offline
post #2 of 4 Old 07-08-2008, 03:12 PM
THRESHER6R's Avatar
I Ride: 2000 ZX-6R
Talk to manley845 hes the carb dude, also check out the thread
http://www.ninja6zone.com/forums/showthread.php?t=4617
I would mainly suggest a good carb teardown and cleaning and checking all the internals for wear.
2000 ZX-6R chassis with 2005 ZZR engine swap, -1/+2 sprockets and 520 kit, +4 ignition advance, stage 1 jet kit, lowered 1.5" up front (rear lowered 1.5" or stock depends on the day),
THRESHER6R is offline
post #3 of 4 Old 07-09-2008, 07:35 PM
manley845's Avatar
I Ride: 2001 ZX9-R
hehe, thanks for the REC man.
without more info I would be lead to believe that the pilot circuit is jacked up.
It doesn't have to be the right tool; Just one that works.
manley845 is offline
post #4 of 4 Old 07-09-2008, 07:38 PM
manley845's Avatar
I Ride: 2001 ZX9-R
didn't mean to send that reply so quick.lol.
Can you work on the carbs yourself?
Remove the mixture screws and spray LOTS of carb cleaner(the cheap stuff from Wal-Mart) through the ports. If this helps, and it should, go back in and tear down the carbs and clean the pilot jets and everything else while your in there.
hope this helps. let me know if i can be of better assistance.
1998 kawasaki zx6e
1998 zx 6 carburetor
1998 zx6e
1998 zx6r carb
1998 zx6r problem
1998 zx6r problems
98 zx6r carb job
carb issues zx6r 1998
zx6e carb problems
zx6e problems
zx6e wont idle
zx6r 1998 problems with crap
carb problem bcrooks Mechanical and Technical 6 11-16-2011 06:56 PM
Can zx6g and zx6e interchange dilemma mobilemowers Mechanical and Technical 0 04-22-2011 06:14 PM
Gas Ventilation Problem!! Help jdthieme The ZX6R 2 06-29-2009 08:51 PM
Gas Venting problem....kream coating? Brichard The ZX6R 13 05-28-2009 09:22 PM
carb questions raddiver The ZX6R 1 01-04-2009 12:40 AM
