2013 Ninja 636 stalling issues - ZX6R Forum
 6Likes
post #1 of 41 Old 02-15-2014, 08:05 PM Thread Starter
I Ride: 2013 Kawasaki Ninja 636 ABS
Thumbs up 2013 Ninja 636 stalling issues
Hello. I noticed today that when I start out in first gear and try to come to a stop without using the brake the motor will stop. Is this normal? If I use the brake, even if I don't need the brake it doesn't stall. If I don't use the brake it stalls. Is this a safety mechanisms or is this something I should get checked out? Thanks.
Lucas is offline
post #2 of 41 Old 02-15-2014, 08:12 PM
cross636's Avatar
I Ride: 2013 636 ABS / 2013 300SE ABS
Are u serious? Stop riding immediately and take a safety course!
Burnt toast likes this.
cross636 is offline
post #3 of 41 Old 02-15-2014, 08:22 PM
shortyx5's Avatar
I Ride: 2013 636
No its a common issue with the '13. When you pull in the clutch the revs will drop low and the bike shuts off.. Its a problem with the ecu. There's no way around it unless kawi gets their shit together and does a recall to fix the fuckers.
shortyx5 is offline
post #4 of 41 Old 02-15-2014, 08:23 PM
I Ride: 2013 ZX-6R ABS
I don't understand. Are you saying that if you coast to a stop without using the brake it stalls, but if you use the brake it doesn't?
GreenDemon is offline
post #5 of 41 Old 02-15-2014, 08:25 PM
givuhcky22's Avatar
I Ride: 2015 636 Carbon Grey
hah... WHAT.
givuhcky22 is offline
post #6 of 41 Old 02-15-2014, 09:16 PM
i don't think i have ever heard of that. why would u try to stop without using the break
motomuscl3 is offline
post #7 of 41 Old 02-15-2014, 10:29 PM
cross636's Avatar
You apparently didn't read that correctly, and I have no idea what your talking about.
cross636 is offline
post #8 of 41 Old 02-15-2014, 11:07 PM
Rides a ZX6R's Avatar
Location: Ocala, FL......go GATORS. Currently transplanted in California near Sacramento.
I Ride: RIP 2013 zx6r, Current 2010 R1
I don't exactly understand the question....however I have noticed that when the bike is cold it will stall when coming to a stop. However this has only been occurring since I installed my exhaust. So I don't know if it might have something to do with back pressure. Also only occurs when I have the silencer inserts removed. With the stage 2 silencer in I haven't experienced the stalling.
RIP 2013 ZX6r
Current...2010 R1.
Rides a ZX6R is offline
post #9 of 41 Old 02-15-2014, 11:13 PM
Burnt toast's Avatar
I Ride: eye candy
Bang bang boogie. This should be good
rkt14 likes this.
Burnt toast is offline
post #10 of 41 Old 02-16-2014, 12:15 AM
j0n0070's Avatar
I Ride: 2013 Kawasaki zx6r(crashed) - 2012 Ducati Monster 696
i have this same problem, i think what he means is that in first gear if he pulls in the clutch and doesn't give it any throttle the revs dip below 1k rpm and shuts off, its annoying as all fuck, but an issue the majority of the 13s are having like shortyx5 said
shortyx5 likes this.
j0n0070 is offline
post #11 of 41 Old 02-16-2014, 12:39 AM
shortyx5's Avatar
I Ride: 2013 636
Yeah that's what I meant. If you're in gear and you hold in the clutch the bike stalls. Not all the time but it gets a habit of doing that. You can try raising idle speed.. At least that's what I do.
shortyx5 is offline
post #12 of 41 Old 02-16-2014, 01:02 AM
j0n0070's Avatar
i did that too but it still happens every so often
j0n0070 is offline
post #13 of 41 Old 02-16-2014, 01:33 AM
madmax31's Avatar
I Ride: 2013 ZX6R, 2009 ZX6R Track
are you pulling in the clutch completely at a stop or just partially? Only time that has happened to me is when I had the clutch lever adjustment to close and wasn't completely disengaging the clutch while holding the brake lever.
madmax31 is offline
post #14 of 41 Old 02-16-2014, 02:05 AM
j0n0070's Avatar
im pulling clutch all the way, and it only happens in the first 10 minutes afterwards she runs solid
j0n0070 is offline
post #15 of 41 Old 02-16-2014, 02:38 AM
OK my tuppence - oil drag when cold, increase tickover speed until it stops doing it,
Could also be the sub throttle set low.....
oldboyonrgv is offline
2013 kawasaki 636 low idle
2013 kawasaki 636 stalling
2013 kawasaki ninja 636 cold idle problem
2013 kawasaki ninja zx6r stalling
2013 zx6r shuts off at low revs and
636 stall ecu issues
engine stuttering when opening throttle zx6r
kawasaki zx6r stalling
stalled zx6r
stalling not starting ninja zx6r
zx6r 2013 636 stalling 1st gear
zx6r engine shuts off when cold
FS: WTS New 2012 Kawasaki Ninja 250R...........$3000 loexrexi Classifieds 14 09-18-2012 07:18 AM
