2014 TRS HID Install - Page 3 - ZX6R Forum
post #31 of 38 Old 04-23-2016, 11:14 PM
Ilya's Avatar
I Ride: 2015 Kawasaki Vulcan S
Bump. Did either of you ever get nice brackets made to use with the TRS H1 Mini's?
Cage: 2011 Infiniti M56x | Bikes: 2015 Vulcan S and 1989 KLR 650 | YouTube Vlog: FstLaneUkraine
For Sale: 2013 ZX-6R Parts
Ilya is offline
post #32 of 38 Old 04-24-2016, 06:41 AM
bboytaktix's Avatar
I Ride: 2014 zx6-dirty-6
I have the drawing from Texas, haven't had much time this year to order the kit and do the work since my work/school has been crazy. My friend should have no problem machining the bracket though. He recently did a bunch of specialized Ducati gears for a local Ducati expert who also builds race bikes.
Pushing this project until next winter. I always wait until black Friday sale at TRS to purchase my stuff.
bboytaktix is offline
post #33 of 38 Old 06-22-2016, 08:10 PM
Keedo's Avatar
Bump
Has anyone figured out a cheaper solution for the brackets? I think I am going to go for the BI-XENON: MORIMOTO FX-R 3.0 instead.
Keedo is offline
post #34 of 38 Old 06-28-2016, 06:24 AM
bboytaktix's Avatar
Originally Posted by Keedo View Post
Bump
the Morimoto FX-R are very large and won't fit inside the OEM headlight. I highly suggest not going this route.
Bracket can easily be cut out and used from the supplied template. should be cost-effective enough without having to purchase the bkmoto kit. The new Morimoto mini are a great setup to have in a bike, and are also bixenon, and will fit the OEM housings. I don't see why you would need anything else. TRS even sells a motorcycle kit now which will give you the correct adaptors and harness to make it work properly.
post #35 of 38 Old 06-28-2016, 06:52 AM
Ilya's Avatar
Cut out of what? Aluminum? Sheet Metal? Is that what people have done? I'm still curious about this myself...and the template on page 2 is the exact size?
Ilya is offline
post #36 of 38 Old 06-28-2016, 07:42 AM
bboytaktix's Avatar
Texas emailed me the original scan; you can ask him to do the same. I would use any metal that doesn't rust, aluminium if you'd like (but paint it) or galvanized steel or even stainless if you want to get fancy. Whatever your heart desires, at a thickness in which the chosen material would be rigid enough to hold the weight of the projectors.
Ilya likes this.
post #37 of 38 Old 08-11-2016, 08:30 AM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Originally Posted by Texas636 View Post
Unfortunately, I don't have any pictures of the new brackets. I can take a picture of the factory brackets, but the problem is, is that the new Morimoto Mini H1 projectors are smaller, therefor won't have a way to mount to the bracket.
Only tip I have for opening the headlights is just to take your time. Do it in one hour increments or you will get rather tired of doing it.
You can replace the halogen projectors with Bi-Xenon projectors. That's what we are doing, but you need the bracket that holds the projector. You will also have to remove the inner shield that has the reflective chrome. You can leave it in there, but you can't use the shrouds. So your option is to either use the shroud and leave the chrome reflective inner shield or you can use your shrouds, but have to take out the inner chrome shield.
Here are the factory projectors out of the headlight housing. The mount I am speaking of has the three plastic adjustment receivers that the adjuster bolts go through to adjust your projectors.
Here's a picture of the inner chrome shield that will need to be removed if you are using the shrouds.
Nooooo.....can't see the images anymore
MrZ is offline
post #38 of 38 Old 03-11-2017, 08:07 AM
I know that I'm reviving an old thread, but where did you mount the ballasts and boxes for everything? I'm trying to figure it all out now on my install.
Xanidus is offline
headlights , hid , install , trs
HID Install question Co Kop Mechanical and Technical 4 06-12-2014 01:14 PM
HID Projector install progress laggy311 The Build Thread 33 06-10-2014 08:46 PM
TRS HID Install....help please. txboarder The ZX6R 1 04-19-2014 04:36 AM
How-to: HID Install on '05 ZX6R EvoMR Mechanical and Technical 11 11-11-2013 05:05 AM
HID Install Zander92 Mechanical and Technical 8 03-14-2013 10:35 PM
