'00 ZX6R Fork Problems!!! - ZX6R Forum
post #1 of 9 Old 09-15-2008, 10:32 PM Thread Starter
rizocket's Avatar
Location: Currently living in Mobile, AL Great Riding Weather
I Ride: 2000 zx6r
Question '00 ZX6R Fork Problems!!!
I have a 2000 zx6r. The bike is lowered about an 1 1/2 in the front. I purchased the bike this way and plan on changing this very soon. My main problem is when I get on the bike I can feel a short drop(about a 1/4 to 1/2) as soon as weight is applied to the front end. I spoke with a local guy that said my forks were probably running dry and I needed to replace them. Is he correct or can I rebuild these with some type of rebuild kit? I have yet to remove them and check my fluid levels and I know I need to do this. I'd just like to know how long my baby will have to be down!! Any help will be greatly appreciated.
rizocket is offline
post #2 of 9 Old 09-16-2008, 02:14 AM
Jimmy'Z-X6's Avatar
I Ride: 2002 ZX-6R
Rizrocket,
Hey bro, just go to the Vault section and download the service manual, it will help you out on this!
You DON'T have to replace the forks simply because they are low on fluids, and the only place I know of to leak fork oil is around the fork seals. You should also be able to tell if you are leaking fork oil past the seals on each fork leg, it'll be oily around the tube where the seal and the slider tube meet. There should not be any oil there normally.
Depending on your mechanical skills and parts availability, seal replacement can be done in an afternoon, but if you are'nt comfortable doin' it, take it to the stealership service department!
With out knowing any more about your bike, this is my best guess for you!
Good Luck to ya.
Jimmy'Z
Jimmy'Z-X6 is offline
post #3 of 9 Old 09-16-2008, 04:48 AM
Steve_TLS's Avatar
I Ride: GSXR1000K3
1/4 to 1/2 what?
There is supposed to be some sag when you get on the bike >> here >> http://wotid.com/tls/content/view/22/53/
The fluid in the forks slows the rate of change down, its called damping. The springs control how much it moves. Preloading the springs can control the sag when you hop on the bike as long as the spring range is suitable for your weight.
Steve
"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
N6Z Forums Staff - Resident Antipodean
Questions about the Forums? Click Here
Help Support Ninja6Zone: Subscribe
-TLzone- -Ninja6zone- -RSVzone.com- -TuonoZone.com-
-My TLS pages- -My GSXR pages- -My Dyno pages- -My Blog-
Steve_TLS is offline
post #4 of 9 Old 09-16-2008, 05:15 AM
Mentok's Avatar
There's plenty of rebuild kits around or you could go see a specialist who will rebuild and set up the forks to suit your height, weight, etc.
Which is nice.
Mentok is offline
post #5 of 9 Old 09-16-2008, 06:32 AM
I'm special - like a short bus
50outlaw's Avatar
I Ride: 03 636
Originally Posted by Steve_TLS View Post
1/4 to 1/2 what?
+1 your forks are fine...
dude's tryin to pull one over on ya
50outlaw is offline
post #6 of 9 Old 09-16-2008, 06:57 AM
Buster's Avatar
I Ride: ZX6R J1
Yep sounds like sag do the checks as above. If you can afford +1 on the proffesional rebuild, tailored to your weight and riding makes a huge difference.
I got holes in my socks, I got holes in my shoes, I got the down payment blues.
Buster is offline
post #7 of 9 Old 09-16-2008, 09:57 AM
I Ride: 01 ZX-6R
dude if u sit on the bike u dont expect the suspension to not move do you if that was the case it would be one rough ride....
Ninja_ZX_6R is offline
post #8 of 9 Old 09-17-2008, 11:44 AM Thread Starter
rizocket's Avatar
I Ride: 2000 zx6r
Thanks guys, I felt like I was getting bad info from my local guy. Looks like I have a day of fork duty in my near future. All you guys have been a grat help.
rizocket is offline
post #9 of 9 Old 09-20-2008, 08:59 PM
manley845's Avatar
I Ride: 2001 ZX9-R
I had my 00 zixxers forks rebuilt in less than an hour. Forks and valve lash are the only things I wont do. My tech kicked some ass on that job.
It doesn't have to be the right tool; Just one that works.
manley845 is offline
Bolt in Fork bottom won't tighten 07 ZX6R motodug Mechanical and Technical 0 06-18-2011 08:46 PM
99 ZX6R, New but some problems HELP psilo The ZX6R 7 06-12-2011 07:29 AM
