Have I ruined my 2013 headlight, Or are they fixable what do you guys think? - ZX6R Forum
 6Likes
post #1 of 27 Old 03-13-2015, 04:46 PM Thread Starter
Pcervant136R's Avatar
I Ride: 2013 kawasaki ZX636ED
A couple of months ago I purchased a set of Lamin-X headlight Tint /covers I didn't like how they fit so I removed them Long story short Some of the tints adhesive was left behind I cleaned it and some came off and some was very stubborn. I decided to use Goof off tested a small part of the Headlight for any reactions and it seamed to be safe. So I went ahead and used this goof off to try to clean up my headlights and It was like some kind of chemical reaction or something. To me it looks like the Goof off reacted with the adhesive and caused it to I guess melt or burn through the plastic Or I am just seeing things. I use to be able to run my nail across the headlight and hit the adhesive from the outsidr now I run my nail over the headlight and it's like a crater and my nail hits the outside of the adhesive indentation weird? What do you guys think are these Toast or are they fixable? Reason I think this is because The adhesive is deeper Now instead off on top off the clear headlight hope you guys understand what I mean. I hope I am over reacting and this is all in my head and they can be fixed. What would you guys use to Remove this type of adhesive Any recommendations would be great as they look horrible. Edit I used Goof Off not Goo Gone..
ID:	33038   Click image for larger version
ID:	33039   Click image for larger version
ID:	33040   Click image for larger version
ID:	33041   Click image for larger version
2013 kawasaki zx6r Gutted MJS Header with SC-PROJECT GP M2 Slip-On, Pinebox Midpipe, Power commander V. Dynojet Auto Tune, BKMOTO Bixenon 5000k HIDs, Front & Back White Halo Angle Eyes, Red Demon Eyes, Led DRLs, Audi Style White Amber Switchback Leds, Stock smoked tail light, smoked front and rear blinkers.Ohlins SD021Damper,ASV C5 Levers. Core Moto SS Brake lines
Pcervant136R is offline
post #2 of 27 Old 03-13-2015, 04:49 PM
Not going to "hurt" them per-say. You basically burned off the clear coat on the lens. As long as there is no physical hole that water can get through then you're fine. But a new set of lights ain't gonna be cheap!
PowerGroove is offline
post #3 of 27 Old 03-13-2015, 05:00 PM
Are those blotches the remains of adhesive? Cause I dont see anything else wrong with that headlight.
post #4 of 27 Old 03-13-2015, 05:06 PM Thread Starter
What you see is what was left after the adhesives reaction with the Goof Off. The adhesive seemed to have turned milky white and these craters were left After I wiped it down. It just looked horrible. I should have just left it the way it was.
post #5 of 27 Old 03-13-2015, 05:12 PM Thread Starter
It sucks as I tested it on a clean spot and I guess it reacted to the adhesive and caused this. I might look into a new or used headlight down the road and have New bi Xenons projectors & maybe some demon eyes / angle eyes . But ya your right about them not being cheap. Not the kind of money I want to spend any time soon .
post #6 of 27 Old 03-13-2015, 08:32 PM
devildogae's Avatar
I Ride: 2009 Black ZX6R
The goof off turns it liquid then it dries up again. You need to use more and keep wiping it off. It should eventually get it all off, then wash with liquid dish soap and clean towel, should be good to go, wipe on, wipe off.
NitrusReigns and Strider like this.
______________________________________
WERA # 333 Novice
devildogae is offline
post #7 of 27 Old 03-13-2015, 09:04 PM
dhorcher's Avatar
I Ride: 99 zx6r. 05 zx10r. 15 zx10r
As 👆 said continue to use goof off until it's gone, or try wd40 which is what I usually use to remove adhesive from plastics. Either way when it comes mostly off go to a scratch remover and buff the lights by hand. Then give them a good coat of wax to protect them since they will then be bare to the elements.
dhorcher is offline
post #8 of 27 Old 03-13-2015, 09:12 PM
greenmeeny's Avatar
You might be able to get it polished out.
greenmeeny is offline
post #9 of 27 Old 03-13-2015, 09:21 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Next time you want to remove an adhesive, Use wd-40 or goo B gone.
That goof off stuff is way to strong for any soft plastic, shits as strong or stronger than carb/brake cleaner.
read only one page"
oldninjadude is offline
post #10 of 27 Old 03-13-2015, 09:48 PM Thread Starter
It did more than turn it into liquid I think it did exactly what "PowerGroove" said it burned through the clear on the headlight. I don't want to use this stuff on them any more as I don't want to make them worse then they are.
post #11 of 27 Old 03-13-2015, 09:57 PM Thread Starter
I will try WD40 and see what that does but like I mentioned I think it burned through when the adhesive came in contact with the Goof off as I put some on the area without the adhesive and it didn't do anything so I applied it to the adhesive and that's where it messed up I will try a headlight restoration kit maybe go to a friends detail shop & see if he has one he can trY to polish it out. Thanks guys. Lesson Learned NEVER use Goof Off on ANY thing on my Bike. I was even going to try 3m Adhesive remover but they told me it could mess it up.
post #12 of 27 Old 03-13-2015, 10:16 PM
40acres's Avatar
I Ride: 2008 zx6r, 2011 kx250f
If all else fails, wet sand and Maguire's polish
Or if you aren't comfortable with it, you can have a body shop do it and lightly smoke your headlights for under $100. That is the look you were going for anyways, correct?
riverszzr and RJ2112 like this.
40acres is offline
post #13 of 27 Old 03-14-2015, 06:53 AM
NitrusReigns's Avatar
Even just try some rubbing compound on it rather than heading straight to wet sanding. That's what I've done on old plastic headlights in cars that have gotten foggy from sun damage over years of exposure and it's always worked great.
40acres likes this.
NitrusReigns is offline
post #14 of 27 Old 03-14-2015, 06:58 AM
40acres's Avatar
Yep, that too!
40acres is offline
post #15 of 27 Old 03-14-2015, 08:48 PM
rkt14's Avatar
I Ride: 2013 Kawasaki Ninja ZX636
I haven't tried this on the headlights, but when I'm removing sticker gunk from windows and such, I use windex ..
I'm not sure how it will be on the head lights, but I have used it to clean my Jeep's headlights and nothing has happened.
Up to you to try !
1998 Kawasaki Ninja ZX6R (Sold)
2006 Kawasaki Ninja ZX6R 636 (Sold)
2013 Kawasaki Ninja ZX6R 636 (Currently Own)
YouTube : www.youtube.com/c/sc2racer
rkt14 is offline
2013 636 Headlight Covers born2ride The ZX6R 3 03-10-2014 03:22 PM
Why people are__________ to guys on 6xx bikes. moparman Motorcycle Talk 56 02-28-2014 07:25 AM
2013 636 Headlight gazserm Want to Buy 0 12-14-2013 02:14 PM
A Cry for Help - Headlight v's Power Seasider71 Mechanical and Technical 5 10-14-2013 12:27 AM
How To: 09-12 Bi-Xenon HID Conversion ibekman Guides 8 12-29-2012 09:08 AM
