06 XXL brake compatibility?? - ZX6R Forum
post #1 of 13 Old 05-08-2015, 03:16 PM Thread Starter
I Ride: 06 Kawi 636
Question 06 XXL brake compatibility??
Hey Guys, so first post on the forum so far... I apologize if this can be found on other threads but I just need information quick.
Needed to know what other brake calipers are compatible with my 06 636 because my front brakes seem to be bad (spongy) and looking to replace and upgrade calipers to get good braking power.
Specifically if brakes from a 2010 zx14r would be a direct bolt on replacement for my bike? Also would the master cylinder from the zx14r work as well?
Thanks in advance guys
DannyLab is offline
post #2 of 13 Old 05-09-2015, 06:16 AM
iLean2much's Avatar
I Ride: 2006 Zx636 / 2001 Zx6R
Master and brake calipers have no relation to each other.
Now the brake lever and the master very much need to be matched or you might have locked brakes since the lever might not have the right size, pushing on the master even at rest.
You can bolt up any caliper directly, that comes from a bike the the same brake rotor diameter.
Just because it's the biggest bike, doesn't mean it got the best calipers.
When buying used calipers, just go for the newest model year you can find that matches your rotors.
The 05/06 has 300mm diameter, so does any zx6r from 07-2012. Whenever I get to spend some money on changing my calipers, I will go for the 09-12, preferably 2012 depending on the price difference between the years.
Right now I'm using a 2013 zx10 brake master with stock lever.
iLean2much is offline
post #3 of 13 Old 05-09-2015, 06:51 AM
bod
bod's Avatar
I Ride: kawasaki zx636r c6f
yep 2010 nissin calipers from a zzr1400 will fit straight on matey, got them on mine as well. excellent upgrade..
KAWI ZX6R 06 636
CARBON FIBRE AIRBOX TANK COVER,CARBON FIBRE SWINGARM COVERS,CARBON FIBRE HUGGER,CARBON FIBRE MUDGUARD,CARBON FIBRE CHAIN GUARD,CARBON FIBRE ENGINE COVERS,CARBON FIBRE DASH PANELS,CARBON FIBRE FRAME PROTECTORS,CARBON FIBRE DECALS,BREMBO MASTER,ZZR1400 FRONT CALIPERS,ZX6R 2014 310MM DISCS,HEL BRAKE LINES,EBC SINTERED PADS,PAZZO SHORTY LEVERS,GALFER WAVY REAR DISC,POWERCOMMANDER3 WITH CUSTOM MAP,K&N AIR FILTER,IRIDIUM PLUGS,DE-CAT,ARATA RACE CAN,RAM AIR MOD,08 REAR SHOCK,2012 MIRRORS,SMOKED INDICATORS,HOT BODIES SMOKED SCREEN,GILLES REARSETS,POWERBRONZE GREEN CRASH BUNGS, BIKE REPAINTED KAWI GREEN WITH CARBON FIBRE DECALS AIRBRUSHED..
bod is offline
post #4 of 13 Old 05-12-2015, 08:17 PM Thread Starter
I Ride: 06 Kawi 636
Thank You Ilean2much, and bod for the answers... I think Ill look into getting some zx14 brakes then... Cool seeing the pic too bod, looks nice especially with the brake lines...Which lines are those? Hel?
DannyLab is offline
post #5 of 13 Old 09-06-2015, 09:09 AM
bod
bod's Avatar
Yep hel lines matey
KAWI ZX6R 06 636
bod is offline
post #6 of 13 Old 09-06-2015, 09:37 AM
ZedExMuse's Avatar
[QUOTE=bod;1021704]yep 2010 nissin calipers from a zzr1400 will fit straight on matey, got them on mine as well. excellent upgrade..
DannyLab, et al: pay special attention to the spacers bod has on the caliper bolts. I have Brake Tech Axis 320mm rotors (up 10mm from my OEM 310mm). With this setup I use Kyle Racing spacers, you'll be in a would of hurt if you go up a size if using w/bigger calipers.
And the other obvious note is to use braided lines and have the whole system purged of air.
ZedExMuse is offline
post #7 of 13 Old 09-06-2015, 09:39 AM
bod
bod's Avatar
The zzr1400 calipers go straight on with standard 300 mm calipers ive got spacers on as got 310mm discs
KAWI ZX6R 06 636
bod is offline
post #8 of 13 Old 03-06-2016, 01:43 PM
Will 2014 zzr1400 callipers fit 2005 zx6r?
Ash9 is offline
post #9 of 13 Old 05-29-2016, 07:38 PM
trikpat's Avatar
I Ride: 2005 ZX-6R
Are the levers stock for the 2013 zx10 or your bike? Also, are the 2013 a direct fit for a 2005 636?
trikpat is offline
post #10 of 13 Old 03-15-2017, 02:04 PM
bod
bod's Avatar
Off the zzr1400 calipers are the nissins same as mine yes they'll go straight onto a 2005 zx6r....
Sent from my HTC One M9 using Tapatalk
KAWI ZX6R 06 636
bod is offline
post #11 of 13 Old 03-15-2017, 02:05 PM
bod
bod's Avatar
Originally Posted by bod View Post
iff the zzr1400 calipers are the nissins same as mine yes they'll go straight onto a 2005 zx6r....
KAWI ZX6R 06 636
bod is offline
post #12 of 13 Old 03-15-2017, 04:18 PM
I've got the nissins and brembo master. One finger OMG braking.
post #13 of 13 Old 03-16-2017, 11:38 AM
bod
bod's Avatar
Same ere...nissins , Brembo master, and zx6r 2015 310mm discs....rbf600 brake fluid...stonking brakes..
KAWI ZX6R 06 636
bod is offline
05-06 brake master fix inc part list skidooboy Mechanical and Technical 16 06-30-2015 10:39 PM
Front brake brake light switch noobZX6Ryo Mechanical and Technical 10 02-03-2015 02:29 PM
How to: Install Stainless Steel Brake Lines Chaos Guides 18 04-02-2012 06:52 AM
