Speedometer - ZX6R Forum
post #1 of 6 Old 11-11-2008, 05:06 PM Thread Starter
Kerry's Avatar
I Ride: 05 636
Speedometer
Where on an 05 ninja 636 is the speed read from? I want to change my front sproket to a smaller but really dont want my speedometer reading incorrectly.
Screaming past harlelys
Kerry is offline
post #2 of 6 Old 11-11-2008, 05:27 PM
Millertime69's Avatar
I Ride: 04 636
I've got an 04' and there is a cable that attaches to the front sprocket cover. i was told that is where it gets its speed reading. I changed front and rear sprockets(-1, +2) and it threw the speedo way off. put the factory size back on and and its still a little off. At 60 the speedo says 70.
Millertime69 is offline
post #3 of 6 Old 11-11-2008, 05:45 PM
Quarkz's Avatar
It reads on the rear wheel. Like Miller said, it's from the speedo sensor in the sprocket cover housing. Doesn't matter where your speedo reads from, changing a sprocket will always throw it off.
Originally Posted by crashtd View Post
oh and Quarkz got a puppy. PM me to get in on the pool for how much time passes before she eats it.
Quarkz is offline
post #4 of 6 Old 11-11-2008, 11:23 PM
Scabbs's Avatar
I Ride: 03 ZX6RR
unless its from the front tire.
funny thing is, i just changed my front sprocket and pinched the speedo sensor wires.
didnt think anything of it cause i just soldered it back together.
but it didnt work.
it doesnt run off volts, its with Herts.
so if you get bare wire or damage it at all, NEW SPEED SENSOR.
85 bucks
Scabbs is offline
post #5 of 6 Old 11-12-2008, 11:44 AM
mharrison's Avatar
A speedo healer would fix your problems with the speedo being off. It will also make the odometer accurate as well.
mharrison is offline
post #6 of 6 Old 11-12-2008, 06:44 PM
Deckx's Avatar
check out sprocketcenter.com , they have a chart that you can work out new speeds.
I went down one in the front and I think it reads about 8 kms faster at 100.
Deckx is offline
02 ninja zx6r speedo off
07 zx6 speed sensor cover swap
2006 zx6r 636 speedometer
2008 kawasaki zx6r speedometer
2009 zx6r speedo swap
2011 zx6r sprockets speedo off
636 speedometer wrong speed
does 04 zx6r odometer work off front wheel?
how to adjust the speedometer on 06 636
how to change speedometer cable on 2002 zx6r
how to test 01 kawasaki zx6 speed sensor
zx6 sprocket sensor does what
GPS speedometer rolledoats Mechanical and Technical 10 11-20-2011 03:55 PM
2002 zx6 speedometer and headlight gone out. xoutkast09 Mechanical and Technical 0 05-26-2011 02:52 PM
Help broken speedometer!! Buchanan Mechanical and Technical 2 02-09-2011 04:24 AM
Speedometer Help soppeln11 The ZX6R 6 05-11-2009 07:27 PM
Speedometer Error twerth The ZX6R 18 01-24-2009 06:29 AM
