Lowering the front on 2013 zx6r - ZX6R Forum
 11Likes
post #1 of 32 Old 02-06-2016, 06:10 PM Thread Starter
I Ride: 2013 636
There was a older thread on here stating due to the forks tapering you could only lower the front end by 4mm....has anyone found a way to lower the front by 40mm? I found this picture online and it looks like the front end is dropped more than a inch...and I'm wondering how he was able to do it...
m0sdvs is offline
post #2 of 32 Old 02-06-2016, 08:47 PM
MegaTechPC's Avatar
I think that's just camera angle making it look lowered. The bottom of the fork leg aligns right at the top of the reflector which is exactly where mine is at stock height...
2013 ZX-6R Pearl Flat Stardust White / Black
2006 ZX-10R Gloss Ebony Black / Black (Sold)
2005 CBR600RR Platinum Silver / Black (Sold)
1993 CBR600F2 Red / White / Blue (Sold)
MegaTechPC is offline
post #3 of 32 Old 02-06-2016, 09:56 PM Thread Starter
I Ride: 2013 636
Ok I didn't even notice that.....did you notice around his clip ons the forks are seems to be raised a little?
m0sdvs is offline
post #4 of 32 Old 02-07-2016, 04:03 AM
The more pertinent question, is why would you want to lower the front?
post #5 of 32 Old 02-07-2016, 06:04 AM Thread Starter
I Ride: 2013 636
I had my back lowered with lowering links a year ago at the dealership...but they didn't lower the front to match it...I now want the front to match the back.
m0sdvs is offline
post #6 of 32 Old 02-07-2016, 06:11 AM
smokey11's Avatar
I don't know what nonsense Mega is talking about bottom fork leg... Stevie Wonder could see that bike in the pic is obviously lowered look at how much of the fork leg is thru the triple....
rychsmail, PainfullySlo and jd41 like this.
smokey11 is offline
post #7 of 32 Old 02-07-2016, 07:14 AM
Newyork's Avatar
That bike is lowered for sure. The forks are like 2 inches above the triple.
Newyork is offline
post #8 of 32 Old 02-07-2016, 07:18 AM
Understandable..... If you cannot raise the fork legs in the triples to return the chassis to the chassis to the correct angle, it may be simpler to raise the back to the OEM position and learn to adjust to that.
If (and I am no expert on your year forks) you cannot raise the legs in the clamps, then you could potentially use shorter springs in the cartridges to lower the front. That would result in less travel available in the forks, so the ride would have to be harsher to avoid bottoming out the forks -- that would probably mean stiffer springs than what you have now.
Not a route I would suggest.... best to learn to ride the bike the way it was set up to be.
Having started out stealing rides on both of my older brothers' bicycles, then on their dirt bikes, I spent the first 10+ years riding only being able to dab one foot on the ground. Trust me, you get used to it over time.
post #9 of 32 Old 02-07-2016, 08:27 AM
MotoCT's Avatar
I Ride: 2009 monster energy zx6r
Unless you know exactly how much to lower it in front to match the rear I would have a reputable suspension shop setup the bike's geometry instead of guessing. It doesn't take much to throw off the geometry and adversely effect the handling. You can check the taper of the forks yourself if you can get a set of calipers under the clip ons to measure the fork tube and see where it begins to taper. But yeah, that bike pictured is lowered over an inch in front with the amount of fork tube that is exposed. I'd be afraid to get impaled by one of those tubes.
PowerGroove, PainfullySlo and teri like this.
Omrra Novice #748
MotoCT is offline
post #10 of 32 Old 02-07-2016, 09:06 AM
I Ride: '12 zx6r track bike
Raise the forks too much in the triples and you may find that the front wheel hits the radiator when under hard braking. Not sure, but you need to verify before you do a header.
post #11 of 32 Old 02-07-2016, 09:42 AM Thread Starter
I Ride: 2013 636
Thanks everyone for the response and tip. Will call and check with a suspension expert...if i'm going to get it done I will make sure I'll get it done right.
m0sdvs is offline
post #12 of 32 Old 02-07-2016, 10:30 AM
ZXROM's Avatar
ZXROM is offline
post #13 of 32 Old 02-07-2016, 10:47 AM
Hey, don't laugh ... I've had it happen on my Ducati!
post #14 of 32 Old 02-07-2016, 11:02 AM
teri's Avatar
I Ride: zx636, MT07
I've just double checked mine. I had mine professionally set up. I have the rear lowered by 40mm and the front by 20mm.
Tbh the one in the picture looks a little excessive and its appears to be more for looks than practicality. I'm wondering if he used a longer fork leg to achieve that look
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Lust Racing 40mm lowering kit, T-rex adjustable side stand, Carbon Akrapovic silencer, Carbon fibre heat shield, K&N air filter, Probolt Fairing and Screen bolts, Probolt front brake reservoir cap and clip, Probolt fuel filler cap bolts, Probolt dust caps, Powerbronze carbon fibre heel plates, Powerbronze dark tint double bubble, R&G engine covers, R&G tail sliders, R&G tank sliders, R&G bobbins, T-Rex frame sliders, Lightech bar ends (gold trimmed). carbon fibre yoke protector,carbon fibre fuel filler cap cover, rear seat cowl, Oxford heated grips.
teri is offline
post #15 of 32 Old 02-10-2016, 09:23 AM
I Ride: 2013 ZX-636-R
are you doing this front drop for LOOKS or are you doing it cuz your short?
cuz this will make the steering angle alot steeper and will be harder to steer.
but if going straight is your thing and you wont be doing any hardcore knee scrapes and you dont mind the handling being worse, then go for it (front lowering starts at 3:49)
https://www.youtube.com/watch?v=zbnIiW-nBOs
KCLARK is offline
03-08 zx6r front axel / front wheel spacers zx racer Classifieds 12 07-20-2016 09:12 AM
G1-2 hugger fit j1-2 salami Mechanical and Technical 2 06-21-2016 01:36 PM
My friend totaled my 2013 Zx6r:( Joestradamus Motorcycle Talk 112 02-03-2015 02:30 PM
FS: 2013 ZX6R Front Wheel MillerTime Classifieds 0 09-30-2014 07:46 PM
FS: 2013 ZX6R Front Brake Rotor MillerTime Classifieds 0 08-14-2014 07:48 PM
