Which levers are right for me? A quick guide. - Page 2 - ZX6R Forum
 17Likes
post #16 of 34 Old 02-19-2016, 05:35 PM
commiehunter's Avatar
I Ride: ZX6R 636
All the levers are identical. The adapter is the part that mates the 'generic lever' to a brand/year specific clutch housing or master cylinder.
commiehunter is offline
post #17 of 34 Old 02-19-2016, 06:01 PM Thread Starter
Originally Posted by Arkbird View Post
What are the brake lever adapters for the brake and clutch lever? It says for example the clutch lever adapter is on back order. I'm guessing it's a needed part to install the levers properly?
Correct. Levers are made of 3 main components: The adapter (the part that is specific to each motorcycle, the adjuster, and the lever itself. The adjusters and levers are universal.
If you are referring to my site, then yes, right now the ZX6R clutch adapters are out of stock. You fine people here have ordered more than I was expecting and it caught me by surprise. I have my stock order from the machinist already in the works so I should have them back in stock in about 10 days.
PainfullySlo is offline
post #18 of 34 Old 02-19-2016, 06:54 PM
Vladius's Avatar
I Ride: '14 ZX6R ABS
Are your levers anodized? If so, how long does it last? Also, have you seen those 3d levers with the texture machined on them? If so, do you think it could be done on your levers?
ALSO, lol, what tolerances are you holding on the bushing area as far as diameter and thickness?
Vladius is offline
post #19 of 34 Old 02-19-2016, 07:19 PM
Arkbird's Avatar
Good to know. I think I'll be ordering some levers from you soon then.
Arkbird is offline
post #20 of 34 Old 02-19-2016, 07:37 PM
Turtleface's Avatar
I Ride: '07 ZX6R
Same here. I've got a tiny bonus coming my way from work, and figure I should spend it on something I'll use everyday.
Turtleface is offline
post #21 of 34 Old 02-20-2016, 05:02 AM Thread Starter
Yes my levers are all anodized. As for how long it lasts; as long as any quality anodizing? I am really not an expert on coatings however I have had the same levers on my bike for 6 years now and they still look brand new. Some colors fade faster than others, and I did have a bad batch from my coater at one point about 4 years ago but I simply replaced all of them. Generally speaking I would put my levers against any of the other big names in terms of the quality of anodizing.
I have seen those 3D levers and no, I have no intention of doing that with mine. To be honest, since the coating is slick and the definition is not deep I sincerely doubt that it does much for grip. That, and it is ugly as sin :-p It simply looks like they missed an operation when machining and decided to leave it that way.
I have my 'premium' line in the works and one of the things that I am messing with is a grippier surface but that is still several months away at the earliest.
Tolerances are written to .010 but I have yet to see one over .005. Machines are hyper-accurate these days.
Turtleface likes this.
post #22 of 34 Old 03-27-2016, 09:26 AM
I Ride: 2014 White ZX6R
PainfullySlo do you have an ETA on your premium line of levers?
2014 White ZX6R
pbdude200 is offline
post #23 of 34 Old 03-27-2016, 07:47 PM
Vladius's Avatar
Well I can say the 3D doesn't necessarily do anything for grip as far as I can tell, maybe a little, but I have to say, I own some, and the 3D effect actually looks pretty good. It's obvious that it is a purposeful addition in production, not a byproduct of some production failure.
Anyways, could you elaborate somewhat on how you hope to accomplish a "grippier" surface on the levers in your premium line? Are those tolerances in english or metric? And are those for both the feature's positioning and diameters?
Vladius is offline
post #24 of 34 Old 03-28-2016, 04:03 AM
BrandonZX6r's Avatar
I Ride: 06 ZX6r 636
Hello Painfullyslo,
Green adjusters came in, soon to be on bike. Thanks for the time and trouble. I do appreciate the extra time you took to look the red adjusters. I was a little bummed but when the Green ones cam in , totally changed my mind, love them. With the customers service you provide I have no doubt you and MSM will be around for a while a Long While!! I will be looking for a pair of boots in the next month or so.
BrandonZX6r is offline
post #25 of 34 Old 03-28-2016, 05:55 AM Thread Starter
Still in the R&D phase - working with prototypes now and determining some of the aesthetics. I wish that I could give you a hard and fast date but I simply can't at this time as there are too many variables. I would *hope* that it will be within the next 2-3 months but that could vary by a lot.
It has been my experience that all levers can offer less grip than I would like. My fingers slide around too easily on them, especially so in rain riding. The trick is finding the right level of texture to use to give what I am looking for. They do need to be able to move freely but just that little bit extra of feel when I want them to be firmly planted. I actually think we are pretty close to nailing that down.
I am certain that those 3d levers were intended to look that way, I simply stated that to me it looks as if it is unfinished. If you have ever seen machining done (and I am guessing you have by the fact that you are asking so many pointed questions. Makes me wonder why you want to know) it looks like a rough pass before you make a finish cut and it was left that way.
Those tolerances are in English, so thousandths of an inch. Ten thousandths is a pretty standard tolerance for non-critical part when providing a slip fit but again, none of these that I have QC inspected have ever gotten anywhere near that sloppy.
Originally Posted by BrandonZX6r View Post
Hello Painfullyslo,
Glad that you are liking them bud. I am still bummed that I couldn't find you some really bright red adjusters. If I ever get around to making a run of them I will be sure to send you a pair.
As for the boots, awesome! let me know and I will do what I can do to help.
post #26 of 34 Old 03-28-2016, 07:07 AM
Vladius's Avatar
So you're working on developing a texturing as a means of adding grip? I was curious because I thought maybe you were attempting to utilize a secondary material.
I work as quality engineer at an automotive facility (primarily casting and machining aluminum engine components) so that's where the pointy-ness of my questions comes from, lol. I'm just a big fan of high quality, that's why I'm asking about the tolerancing.
We machine some bore diameters with total tolerances of 0.013 mm (0.0005 in) and surface locations with +/-0.025 mm (+/- 0.001 in) but they are critical features of the part, whereas the pivot point of the lever and the like are not so much.
Vladius is offline
post #27 of 34 Old 03-28-2016, 07:27 AM
Alright thanks. I'll probably wait until those are released before I order some of your levers
2014 White ZX6R
post #28 of 34 Old 04-26-2016, 08:34 PM
THUG's Avatar
dAMN BRO AWESOME WRITE UP I WAS WONDERING ALL OF THE ABOVE AS I WANT TO REPLACE MY STOCK ONES FOR THE FIRST TIME .....
PainfullySlo likes this.
JAMES 1:12
THUG is offline
post #29 of 34 Old 04-27-2016, 08:18 AM Thread Starter
gLAD THAT i COULD HELP YOU, tHUG!
THUG likes this.
post #30 of 34 Old 04-27-2016, 09:08 AM
NitrusReigns's Avatar
Nice guide dude! You should put links to your products in as examples tho
THUG and kawijay like this.
NitrusReigns is offline
Name Brand Levers JTzx6r Mechanical and Technical 34 01-30-2016 04:48 PM
quick question about lever's kakuja The ZX6R 11 05-04-2015 07:42 AM
2013 zx6r short levers & long levers txfakuma The ZX6R 36 01-07-2015 03:25 PM
FS: Brand new 05/06 zx6r levers. N1njaR1d4h Classifieds 0 11-05-2014 11:23 PM
08 shorty levers from moto777 Innexes111 Mechanical and Technical 20 03-10-2014 06:04 PM
