CCT - ZX6R Forum
post #1 of 11 Old 12-18-2008, 12:35 PM Thread Starter
chovy636's Avatar
I Ride: 2013 636
CCT
can someone explain how to replace it and if you have picks or step by step thats greatly appreciated. thanks in advance
The man who is smiling when something went wrong is the man who found someone else to blame.
chovy636 is offline
post #2 of 11 Old 12-18-2008, 12:36 PM Thread Starter
chovy636's Avatar
I Ride: 2013 636
and i was going to get the ape manual tensioner?
chovy636 is offline
post #3 of 11 Old 12-18-2008, 02:19 PM
mityaz's Avatar
replacement is really easy. take the tank off.to have better access to it you might want to take the throttle bodies off. the cct will be almost directly under the throttle bodies (alittle ways down) on the rear, right side of the engine. there's gona be two little bolts - top and bottom - you need to take these off and the cct comes out. the middle big bolt is for adjustment of cct (no need to unscrew this). once the two little bolts are out you can pull the cct out and replace.
you can see what im talking about in the pic (its the little oval thing on the top right) (its pulled out).
this informations is for my bike (01 6r) but im sure is has to be similar (if not the same) for your bike
mityaz is offline
post #4 of 11 Old 12-18-2008, 02:52 PM Thread Starter
chovy636's Avatar
I Ride: 2013 636
thanks man i appreciate it
chovy636 is offline
post #5 of 11 Old 12-18-2008, 03:39 PM
Steve_TLS's Avatar
I Ride: GSXR1000K3
When re-installing / fitting a new one, you will have to remove the bolt in the middle. It's in the manual page 5-14.
(I don't want to seem like an arse, but if you're asking how to swap a stocker, how are you going to adjust a manual one properly?)
Steve
"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
N6Z Forums Staff - Resident Antipodean
Questions about the Forums? Click Here
Help Support Ninja6Zone: Subscribe
-TLzone- -Ninja6zone- -RSVzone.com- -TuonoZone.com-
-My TLS pages- -My GSXR pages- -My Dyno pages- -My Blog-
Steve_TLS is offline
post #6 of 11 Old 12-18-2008, 04:58 PM Thread Starter
chovy636's Avatar
I Ride: 2013 636
i've just been reading how to do it.....im not mechanically stupid just new to bikes.....you get a car motor i can swap motors in a couple hours.....gotta learn somehow....
chovy636 is offline
post #7 of 11 Old 12-18-2008, 04:58 PM Thread Starter
chovy636's Avatar
I Ride: 2013 636
what goes into adjusting the manual one? i read that you just screw in till you feel pressure start biek let it warm up with hand on bolt (so's not to back out) then adjust slowly till hear no tinging.....is that right
chovy636 is offline
post #8 of 11 Old 12-19-2008, 06:37 AM
Steve_TLS's Avatar
I Ride: GSXR1000K3
I don't know I always have relied on the spring in the auto adjusters to do the job properly for me.
Steve
post #9 of 11 Old 12-19-2008, 11:59 AM Thread Starter
chovy636's Avatar
I Ride: 2013 636
lol alright i bet i can figure it out but thanks to all for the help its greatly appreciated
chovy636 is offline
post #10 of 11 Old 12-19-2008, 04:22 PM
mityaz's Avatar
just for clearification purposes, what year cct is a manual and which is auto? is my 01 an automatic? because if it is, why would you need a bolt in the middle to adjust it? it has to be manual, right?
mityaz is offline
post #11 of 11 Old 12-19-2008, 04:30 PM Thread Starter
chovy636's Avatar
I Ride: 2013 636
uh the manual one i am buying is ape.....not sure honestly if yours is auto or manual is the bolt and nut exposed when you look at yours?
chovy636 is offline
APE manual cct tommyszx6rr The ZX6R 44 06-23-2014 08:33 AM
FIXED :) CCT noise Kazoo6942 The ZX6R 7 12-03-2011 10:56 AM
cct reset now wont run when warm JDMKon Mechanical and Technical 2 10-22-2011 10:02 AM
09-11' manual CCT adjustment Dcook0 Mechanical and Technical 6 10-04-2011 12:15 PM
CCT n coolant help ChiZx6r Mechanical and Technical 32 09-25-2011 01:13 PM
