how to install a Manual Cam Chain Tensioner zx6r 07 - ZX6R Forum
post #1 of 14 Old 02-10-2009, 10:37 AM Thread Starter
jstunna's Avatar
I Ride: zx6r 2007 / F4i 2002
My bike when I fire it up it makes a noise then when get warms it goes away telling me its the chain tensioner should I use a new stock oem cam chain tensioner or a Manuel cam chain tensioner ?
please help or do I need to take do dealer to do it ? or can i do it my self
jstunna is offline
post #2 of 14 Old 02-12-2009, 07:47 AM
ZX636's Avatar
I Ride: 2003 ZX636
if it is a ticking noise dont worry bout it its a kawi thing almost all of them do it nothin to worry bout!!!
-Dr. FX integrated tail light
-fender eliminator kit-flush mount signals
-D&D exhaust
-Double Bubble Windscreen
-K&N Air filter
-solo seat cowl-grips-frame sliders
-Michelin Pilot Power 2ct font and rear
-Vortex sprockets -1/+2 TYC Chain 520
-Speedo Healer V4
ZX636 is offline
post #3 of 14 Old 02-12-2009, 08:29 AM
I'm special - like a short bus
50outlaw's Avatar
I Ride: 03 636
that is the valve train.... kawi's are notorious for it... just ignore it
50outlaw is offline
post #4 of 14 Old 02-13-2009, 05:21 PM Thread Starter
jstunna's Avatar
what is that ? and is the cause ?
jstunna is offline
post #5 of 14 Old 02-13-2009, 10:39 PM
Nightmare's Avatar
I Ride: 2007 zx6r
You do not need a manual tensioner. And that type of addition you either better have done it before or learn how to. Or have professional do it. Heres how you do it if you feel lucky.take the side fairings off and lift up the gas tank. you must then most likely take the exhaust header off. There are two engine bolts that go through the main frame to mount the engine (the bolts that hold frame sliders on).Now you can tilt to engine down if you loosen the bolts in the back of the engine that mount it. You will have to do some searching to in them. Make sure your key is out of the ignition so you make sure noone accidently turns the motor over while your working. Take off any wires etc on the valve cover and pull them off. (some people wont do this but I highly recommend). Now that the valve cover is off you can see you cams, valvestems and cam chain! You;ll notice it is under tension. you can now loosen the cam chain tensioner on the side. Some people might tell you to find TDC (top dead center). You do not need to. Just 100 percent make sure you just keep enough tension on the chain and do not bump anything that could cause the engine to move out of timing. So now that the tensioner is out bolts your new on the the right torque specs, make sure gaskets are on, most likely copper gasket or something. Take the center bolt on the tension and tighten to the right specs. Not to tight, not to loose that super important! Now you got it together. Not take the side plastic bolts out to be able to turn the crank with a rachet, and be able to see in the top hole to find tdc. match up the tick marks correctly with tdc and cam tick marks. A service manual will be able to tell you exactly what degree everyhting should be at (timing wise). If you dont bump the eningine and make it skip a tooth theres no need, But I always check so you can make sure yo do not damage the engine. I might have a servie manual the kawasaki one on a pdf. format. I will check for you. Now some bike you do not have to let the engine pivot down to take the valve cover off. I have done amny engine, all are different.
And besides that I would not sweat it, kawasaki always have had outrageously loud valve trains! And most likely always will! I ahve a mojave 250 atv for 5 years that was the onl;y thing that I ever had to really fix, valve seats needed to be cut, new valves, cams etc.
2007 zx6r-14oz Manic Salamander Bar Ends-T-Rex Frame Sliders-OES ind. front axle sliders and swing arm spools-Puig smoked windscreen-PcIII usb custom map-Two Brothers CF slip-on-K&N air filter-GPR black V4 damper-SS Galfer front/rear braided brake lines-Pazzo levers (longs)-5150 concepts rearsetrisers-Matte Blacked out driver and passenger pegs, and Bar ends.-Electro Pods Full Under Body Kit (green)-Lawst Caws frame plug-Xenon light kit-Relocated rear brake res-CF heal guards-BikeLitez fender elim-Smoked front signals-kleenair mod-jumper mod
Nightmare is offline
post #6 of 14 Old 02-13-2009, 11:12 PM Thread Starter
jstunna's Avatar
i been doing a lot of reading a came across this so i been wondering ?
Sounds like the CCT or cam chain tensioner. It goes away when warm because everything expands and takes up the slack. Replace the stock cct with a manual one. kawasaki make a manual but i cant say i like em very much i would go with an APE manual tensioner i'll try to find there site and most bike shops carry them. There really easy to do just remove the old tensioner hold down bolts and remove it, then install the manual one full loose until you have the mounting bolts tight. then use your thumb and index finger as tight as you can go with those two fingers set the locking nut and bam race ready lol. If you have a whinning noise under exceleration your to tight but with that method you should be dead on with no tick or slop in the chain. Some people say you can have a cam gear spin when taking the old tensioner out. Thats your call i have done several on bikes and cars aswell and thats never happened to me.
jstunna is offline
post #7 of 14 Old 02-14-2009, 05:23 AM
Mentok's Avatar
I wouldn't worry, as long as you don't cane the motor cold (as with any engine) it'll be fine.
All Kawis are rattly, if the noise is bothering you then the quickest and cheapest fix is a decent pair of earplugs.
Mentok is offline
post #8 of 14 Old 02-14-2009, 10:19 AM Thread Starter
jstunna's Avatar
yup i understand that its not that loud its just noticeable
jstunna is offline
post #9 of 14 Old 02-16-2009, 01:00 PM Thread Starter
jstunna's Avatar
is this true ?
jstunna is offline
post #10 of 14 Old 04-14-2012, 01:03 PM
i have a 00 zx6r. and it has a noticable rattle and tick warm or cold. i can notice it more on the timing chain side of bike, could this be the cct. or am i in big trouble.i just use this as back and forth to work, but noise is annoying me. please let me know if any one could help. thank you
00zx6rnewbie is offline
post #11 of 14 Old 04-14-2012, 01:17 PM
trackdayhero's Avatar
Not sure about the 00 but on the 07/08 it is very easy to install:
Infamous Kawi Tick
trackdayhero is offline
post #12 of 14 Old 04-23-2015, 06:24 PM
john 636's Avatar
2005 kawasaki ninja zx636
How to adjust the cam chain on a 2005 kawasaki ninja zx636?? I have pic of the cct but don't no how to post. Thanks
john 636 is offline
post #13 of 14 Old 03-29-2016, 04:44 AM
I Ride: 07 zx6r
Hey so im getting the manual tensioner in the mail tomorrow. Going to make a video of the sounds before, install, and sound after. From youtube videos ive watched and herd mine sounds exactly the same as everyone else. The things only got 2500 miles on it. 07 zx6. The noise was always there but seemed to get louder as time went on. As for install im going to follow ape instructions. Kawi m manuals shows how to take automatic tensioner out and in. No valve cover or top dead center needed to take it out or put it back in. So apes instructions make perfect sense to me? Ive also seen it done this way on our bikes as well as a cbr and a r1. Actualy with the r1 he did find tdc and rotated the engine while tightening the adjusting nut on the manual tensioner then once it made contact with the cam he backed it off a quarter turn.....sound gone. Both installs done to apes instructions and both got rid of the sound? Both bikes still running strong. So i guess we will see!
bnugs is offline
post #14 of 14 Old 03-29-2016, 09:23 AM
MegaTechPC's Avatar
Would love to see a vid of your install if you make one!
2013 ZX-6R Pearl Flat Stardust White / Black
2006 ZX-10R Gloss Ebony Black / Black (Sold)
2005 CBR600RR Platinum Silver / Black (Sold)
1993 CBR600F2 Red / White / Blue (Sold)
MegaTechPC is offline
05 zx6r manual cam chain tensioner
07 zx6r cam chain tensioner
2007 zx6r cam chain tensioner
2007 zx6r cam tensioner
2007 zx6r installation cct
2009 zx6r cam chain tensioner
ape cam chain tensioner zx6r
how do i replace my cam chain tensioner on my 06 zx6r
how to install manual cam chain tensioner zx6r
manual cam chain tensioner adjustment 2005 kawasaki 636
Can a 95 zx6r cam chain tensioner be used for 98-02 zx6r? idriftnaked Mechanical and Technical 0 05-20-2011 01:44 AM
manual cam chain tensioner ZoomSplat Mechanical and Technical 97 05-06-2011 06:41 AM
