Brake fluid - ZX6R Forum
  • 1 Post By tmccan
post #1 of 10 Old 02-19-2009, 02:06 PM Thread Starter
ZX636's Avatar
I Ride: 2003 ZX636
Brake fluid
Could anyone tell me how i can change the brake fluid on my 03 zx-6r it needs new fluid bad but i dont know how to change it any info. would help and be greatly appreciated thanx for the input everyone!!
-Dr. FX integrated tail light
-fender eliminator kit-flush mount signals
-D&D exhaust
-Double Bubble Windscreen
-K&N Air filter
-solo seat cowl-grips-frame sliders
-Michelin Pilot Power 2ct font and rear
-Vortex sprockets -1/+2 TYC Chain 520
-Speedo Healer V4
ZX636 is offline
post #2 of 10 Old 02-19-2009, 04:10 PM
antzx6r's Avatar
I Ride: zx6r 07
you tude it mate
drop acid not bombs
2 wheels 1 track mind
me on youtude....under the name of tattootiadog.. bike cam on my zx6r 07 in the isle of man 2009
antzx6r is offline
post #3 of 10 Old 02-19-2009, 05:57 PM
Nightmare's Avatar
I Ride: 2007 zx6r
Brakes are not too bad man. If you need to add fluid you got a leak, that fluid doesnt burn or anything. Your brakes still work good? IF so here I'll give ya a walk through!
1.step one locate the nipple on the caliper, and then get the cap off of the master cyl resivor.
2.lift cap and a little fluid, over cap with pressure, open nipple slightly and squeeze the lever slowly to get out air. Once the fluid starts coming out slowly turn the nipple back to tight them your ready to go. Tighten the resivor cap and your good to go. Watch with brake fluid, it screws paint up.
3. repeat process until fluid is in between the recommended tick mark lines in the window on the resivor.
4. Also, if your fluid is dark, just change it all. It should look like extra clean motor-oil! Clearish gold
2007 zx6r-14oz Manic Salamander Bar Ends-T-Rex Frame Sliders-OES ind. front axle sliders and swing arm spools-Puig smoked windscreen-PcIII usb custom map-Two Brothers CF slip-on-K&N air filter-GPR black V4 damper-SS Galfer front/rear braided brake lines-Pazzo levers (longs)-5150 concepts rearsetrisers-Matte Blacked out driver and passenger pegs, and Bar ends.-Electro Pods Full Under Body Kit (green)-Lawst Caws frame plug-Xenon light kit-Relocated rear brake res-CF heal guards-BikeLitez fender elim-Smoked front signals-kleenair mod-jumper mod
Nightmare is offline
post #4 of 10 Old 02-19-2009, 09:21 PM
OMalley912's Avatar
I Ride: Life needs more green lights
mighty-vac, yep I'm lazy.
OMalley912 is offline
post #5 of 10 Old 02-19-2009, 09:47 PM
ZoomSplat's Avatar
I flush 'em backwards. both at work, and on the bike. Go get yourself two of the big plastic syringes and about a foot of hose. you can pick 'em up at most hardware stores. I'm talking about the big plastic ones, not the ones you use to shoot your black tar heroine, get those for free from the needle exchange program at your local rehab or hospital.
Put a couple inches of hose on the end of each syringe. One will become you're "fresh clean new syringe" and one will be a dirty and infected syringe (keep this one out of your arm...).
Suck all the fluid out of the reservoir with one syringe, and put it into a disposable container.
Suck new fluid into syringe 2, and attach to the bleeder.
Crack the bleeder, and slowly but firmly push the fluid through the caliper, and you'll see the dirty, old fluid move into the reservoir.
Close the bleeder screw.
Repeat until reservoir is filled to the proper level with new, clean fluid.
This accomplishes a few things: Number one, people tend to forget about the reservoir when bleeding, and end up sucking air into the system when they're trying to get the air out, this prevents that all together. Number two, you're pushing all the nasty garbage up and out, instead of down and through every single piece of rubber that it could potentially destroy. Number three, you can do it by yourself, it gets kind of tricky to bleed your left caliper while squeezing the brake lever on the bike when you're all alone. doing it this way means your girlfriend can stay on the couch watching Real (spoiled) house wives of wherever, instead of bitching about having to get up and come outside for three minutes.
ZoomSplat is offline
post #6 of 10 Old 02-20-2009, 10:12 AM Thread Starter
ZX636's Avatar
I Ride: 2003 ZX636
thanks for the info. everyone they all sound like good ideas i will definatly know wat to do now n prolly do it today again thanx
-D&D exhaust
-K&N Air filter
-Speedo Healer V4
ZX636 is offline
post #7 of 10 Old 02-20-2009, 02:18 PM
Mentok's Avatar
Whoa, that's awesome ZoomSplat
Mentok is offline
post #8 of 10 Old 02-20-2009, 05:02 PM
I Ride: 04 636
yeh thats a awesome tip zoom
It's better to burn out than fadeaway.....
yahoo is offline
post #9 of 10 Old 02-21-2009, 03:25 AM
AZ Ninja's Avatar
I Ride: 08 Zx6R
i am going to have to keep this in mind when i go flush my brakes here soon.
AZ Ninja is offline
post #10 of 10 Old 01-31-2013, 05:58 PM
tmccan's Avatar
I Ride: '12 Z1000. Helz yea!
Bump for an awesome tip
tmccan is offline
2000 zx6r brake fluid
2007 kawasaki zx6r brake fluid tube
2007 ninja zx6r do you need the rubber bellow in the brake fluid box?
add break fluid 2006 ninja zx-6r
brake fluid kawasaki 6rr
changing front brake fluid zx6r 09-12
flushing break fluid on my zx636r
how much brake fluid how much is a kawasaki ninja
how much brake fluid zx6r
kawasaki zx6r brke fluid change
zx-6r brake fluid and hose
zx6r brake fluid
rear brake fluid how to... Rjones1041 Mechanical and Technical 3 10-14-2011 11:50 AM
Brake fluid tricks DaniZixxer Mechanical and Technical 14 04-29-2011 08:27 AM
brake fluid DocOverkill Mechanical and Technical 15 03-24-2011 03:29 PM
(How To) Front Brake Pad Replacement ZoomSplat Guides 14 07-02-2009 07:31 AM
