Stock exhaust with link pipe - Page 4 - ZX6R Forum
 25Likes
post #46 of 60 Old 02-13-2017, 10:26 PM
I Ride: 2014 Kawasaki ZX-6R
Link pipe installation was as easy as removing the can and prechamber then placing the link pipe and can back on. Torque the link pipe bolt to 25ft-lb, the clamps to 15ft-lb and the can mount nut to 15ft-lb. The black widow link pipe included a graphite gasket needed for install, stickers and a cool lanyard.
As for the sound. . . I'm glad to say that it was an improvement. It creates a minimally louder, growling tone. I couldn't get decent sound quality in video but like I said it sounds better than the stock tin rattle.
As I previously stated, the only reason I installed this is for access to the rear shock height adjustment but the added benefit of weight loss was noticeable
Link pipe available here: ZX6R ZX-6R 636 2013 2016 De Cat Cat Removal link pipe 2013 2014 2015 2016
ID:	55458   Click image for larger version
RJ2112, Sanctuary, markgbe and 2 others like this.
Martillo y Mantequilla #99
jd41 is online now
post #47 of 60 Old 02-14-2017, 08:28 AM
markgbe's Avatar
I Ride: 2013 zx-6r
Looks good! My only concern was that it would be too loud or reduce low end torque too much. I assume it's no where near the sound level of a slip on right? Any test rides to confirm the torque feeling?
2013 ZX-6R - Pearl Flat Stardust White
Puig windscreen
markgbe is offline
post #48 of 60 Old 02-14-2017, 08:49 AM
Butt-dyno didn't notice a difference in power.
It is a couple of decibels louder (when measured from phone, which is not accurate or calibrated), but not obnoxious. I would say it now sounds like the stock s1000rr exhaust which is loud for stock but not unpleasant.
markgbe likes this.
jd41 is online now
post #49 of 60 Old 02-14-2017, 03:11 PM
Easy access to the shock for adjustment
markgbe likes this.
jd41 is online now
post #50 of 60 Old 02-15-2017, 08:49 AM
markgbe's Avatar
I Ride: 2013 zx-6r
excellent. i will be ordering this soon. Thanks for the pics and things.
Puig windscreen
markgbe is offline
post #51 of 60 Old 02-15-2017, 10:52 AM Thread Starter
Sd636's Avatar
I Ride: 2016 636
Can anyone record video of the exhaust noise before and after of the link pipe
Sd636 is offline
post #52 of 60 Old 02-16-2017, 03:16 PM
Ah man, I just found one that IXIL makes one too and at a better price. 67.95$ with free shipping.
But I am pretty happy with the black widow link pipe
IXIL DECAT RACE PIPE KAWASAKI ZX-6 R (ZX600R) 2009-2013 - IXIL USA
jd41 is online now
post #53 of 60 Old 02-16-2017, 04:12 PM
I would do it but I haven't been able to get a good recording with my phone. I'll try again later.
It honestly does sound like the stock s1000rr exhaust with the link pipe on.
jd41 is online now
post #54 of 60 Old 02-16-2017, 04:23 PM Thread Starter
Sd636's Avatar
I Ride: 2016 636
http://www.youtube.com/watch?v=j21hExfFjYM
Would you say it's worth getting the link pipe with stock exhaust?
Sd636 is offline
post #55 of 60 Old 02-16-2017, 04:32 PM
Only if you want to get rid of the prechamber weight or not have to take the wheel off for access to the shock. Otherwise I would have left it on.
jd41 is online now
post #56 of 60 Old 02-25-2017, 01:24 PM
TemujinRain9's Avatar
Anyone know if the black widow link pipe will fit the Akrapovic can that the performance model comes with
I only ask as there is a £100 odd difference in price
"If someone tells me that it's wrong to hope, I'll tell them they're wrong every time." - Madoka Kaname
“When a man faces fear, his soul is tested. What he was born to seek... what he was born to achieve... his true nature will become clear.” - Shougo Makishima
"I wanted to be just like those heroes in the books... Someone who fought for what was right, and protected people who couldn't protect themselves!" - Ruby Rose
TemujinRain9 is online now
post #57 of 60 Old 02-26-2017, 11:35 AM
Andie0's Avatar
Yes it does I have it on my bike!!!
Andie0 is offline
post #58 of 60 Old 02-26-2017, 11:38 AM
Originally Posted by Andie0 View Post
Snip
You, sir are a scholar and a gentleman by responding so quickly.
just need to get the break in period (600miles not going above 4000rpms ugh) done before I change anything on her
post #59 of 60 Old 02-26-2017, 11:43 AM
Andie0's Avatar
I tryed to stay under but I thought I'd opt for a hard break in and went up to 6500rpm after about 10 miles. Once I'd done 500 I dropped oil and then went up to 9500rpm until 1000 miles. Worked alright and engine seems to be powerful and responsive. But if you stick to the Kawasaki way there's no drama as they no best. I just thought as I decided to run my old Toyota starlet in hard and my friend run his pretty much identical starlet in nicely and mine ended up with 12 more hp I'd try it with the bike. Inno there could be a billion variables that caused my extra power but I like to think it was the hard run in. Mine was actually running less hp than his previous to the forge builds.
Andie0 is offline
post #60 of 60 Old 03-01-2017, 08:25 AM
According to scorpion exhaust, the OEM prechamber and exhaust have measured 91.7 db @ 6750 rpm. I don't have an accurate Db reader but I'll try to get a reading with the link pipe . . or someone else can
jd41 is online now
My new exhaust - the JTI S4 Paul2357 The ZX6R 42 12-06-2016 01:31 PM
The JTI S4 Exhaust Paul2357 Mechanical and Technical 5 10-03-2016 03:32 PM
05 zx6r 636 exhaust stock pipe without catalytic converter DANIZX6R636 Mechanical and Technical 4 02-12-2015 01:03 PM
FS: Hotbodies MGP growler + pine box link pipe with heat shield brackets kawiDoh Classifieds 9 12-06-2013 07:30 PM
Akrapovic Link Pipe Heat Shield?! Jufresco New Users 2 09-15-2012 11:53 AM
