Strange starting problem in the canyons - Page 2 - ZX6R Forum
 13Likes
post #16 of 21 Old 11-12-2016, 05:35 PM
jel1990's Avatar
I Ride: 2013 ZX-6R
Glad the new ECU solved your problem man.
chomorro likes this.
jel1990 is offline
post #17 of 21 Old 05-17-2017, 01:24 AM
KillShftKawi's Avatar
I Ride: 2013 Matte Black Kawasaki ZX6R
Originally Posted by jel1990 View Post
I had an issue like that with my 2013. If the engine was hot, like 200+ degrees, the bike would not want to start. It was stupid having to rev my bike while pushing the starter when at the gas station or in the canyons. My bike is a cali model so I thought it might be the extra emissions stuff we have. Bypassed all that and still had the problem. Next I tried getting my ecu replaced by my local dealer, but they wanted way too much money. There was never an official recall, but some people had luck getting Kawasaki to replace the ecu for free under warranty, but I bought my bike used so I was SOL. I ended up buying a used cali model ecu on ebay, swapped it out and now the bike starts the first time, every time. If you pull your ecu the part number you probably have is 21175-0812 112100-9872. You want 21175-0812 112100-9874.
Edit: Forgot to mention I had the low idle, slow start when the bike was "cold" like you have. The ecu swap fixed that too.
Have you had any problems yet? Or has it completely fixed it?
My bike just started acting up after I put block off plates in. It died mid ride, in the middle of the rpm range. I pull over and it cranked but didnt turn over. It wouldn't even push start (Maybe I was just too weak). After about 20 to 30 minutes it started and it was fine. I rode it half a mile and it died again. Repeated the same process and it started. I rode it to my friend's house and checked to make sure I did the block off plates right and I also put in new spark plugs. Rode about 10 minutes, died again, waited 20, started, rode 10 minutes, died, started after 5 minutes, rode 5 minutes, died, started after 1 minute.
I noticed it had the same ecu number as your bad one. So I might just buy the Good ecu number you found
KillShftKawi is offline
post #18 of 21 Old 05-17-2017, 05:02 AM
I think the dealer will change it out under warranty.
post #19 of 21 Old 05-18-2017, 12:25 AM
I actually just put the smog stuff back in my bike and it hasn't died randomly yet. I read somewhere that for fuel I ejected bikes you have to reset the way by unplugging the battery for a few. I might try that and see if it works once I put the plates back in.
post #20 of 21 Old 05-22-2017, 04:15 PM
jel1990's Avatar
I Ride: 2013 ZX-6R
Hey, no I haven't had any issues since I swapped my ECU. Hope you figure things out.
jel1990 is offline
post #21 of 21 Old 05-22-2017, 04:18 PM Thread Starter
I Ride: 2013 636
I have an extra ecu for sale if you want to buy it and send it off to get flashed to solve the problem and also get the benefits of the custom flash. That way there is no down time. Just pm me if your interested
Sent from my SM-N910V using Tapatalk
2013 Black ZX6R w/ABS
2011 Triumph Street Triple R (SOLD)
chomorro is offline
zx6r starting problem. kryptek1017 Mechanical and Technical 7 10-16-2016 09:40 AM
95'-97' zx6r after oil maintenance PROBLEM pressure davidko Mechanical and Technical 8 05-02-2015 10:54 AM
ZX6R J1 2000 starting problem - help please Demongroover The ZX6R 1 03-10-2015 11:16 AM
07 zx6r help! problem starting madkaw6 07 New Users 14 12-02-2014 05:34 AM
f3 starting problem help please biff1972 Mechanical and Technical 1 10-01-2013 04:27 PM
