Brembo master cylinder fit 2003 bh1 - ZX6R Forum
post #1 of 3 Old 12-11-2016, 11:25 AM Thread Starter
Rusty600's Avatar
I Ride: 2009 zx6r / 2003 636b1h
Hey everyone,
Hoping someone can advise me with this. So I have bought a brembo master cylinder for my (bike 2003 bh1). - this look to a bit of pain in parts to fit...it's all a bit snug on the handlebar.
The bike is used mostly on the road with the odd bit of track action when the sun shines..offering up the new part does highlight a few questions..with the original switchgear in place and having removed the old master cylinder there doesn't seem to be enough space to bolt on the master cylinder to the handlebar without there being a gap of a few mm between the 2 sections cos it's not seated properly, and I don't wanna pull the threads when tightening without both parts on the handle bar correctly..any thoughts on this?
The throttle cables route under the handle bar and the brake lines will do to with the new cylinder is there enough room for both..
..and finally with the new cylinder sort of in place..how do you mount the fluid reservoir as there's no room for the 10mm bolt that holds it in place..
Thanks for any help fired in my direction!
Rusty600 is offline
post #2 of 3 Old 12-12-2016, 12:41 PM
scoot33's Avatar
I Ride: zx6 j2
rusty600 do you mean by what you are saying that its not sitting in the lugs/holes in clipon as you want to make it fit ?
zx6r j2 mods done ,,
scoot33 is offline
post #3 of 3 Old 12-12-2016, 12:44 PM
scoot33's Avatar
I Ride: zx6 j2
with the brake pot ,i too have a b1h top yoke on my j2,i used the mounting bracket from the pot and drilled a hole on the yoke and bolted it in there if that makes sense,i will sort pic if you need it
scoot33 is offline
Brembo 19X20 Brake Master Cylinder $210.00 Shipped tgold Classifieds 12 11-16-2015 03:23 PM
Galespeed Master Cylinder psomersall Mechanical and Technical 3 10-16-2015 04:24 PM
FS: 05/06 Brembo 19x20 master cylinder Snazzy Classifieds 8 02-21-2014 06:21 PM
Does it matter which way is up on master cylinder? InfamousXTC Mechanical and Technical 5 10-10-2013 05:52 PM
Brembo master.!! bod Mechanical and Technical 13 08-18-2013 09:41 AM
