Clicking when pressing brakes? - ZX6R Forum
 10Likes
  • 2 Post By jd41
  • 1 Post By RedAndBlack
  • 2 Post By scoot33
  • 2 Post By Theomz90
  • 2 Post By RedAndBlack
  • 1 Post By scoot33
post #1 of 13 Old 12-28-2016, 05:59 PM Thread Starter
Theomz90's Avatar
I Ride: 2007 ninja zx6r
Hey everyone,
So I just changed the front take pads on my 2007 zx6r, and now when I press front brakes quickly, it makes a bit of clicking noise, especially when I let go of the brake... any ideas? Thanks!
Also, is it maybe just normal?
Theomz90 is offline
post #2 of 13 Old 12-28-2016, 06:16 PM
Check to see if you have the anti rattle clips placed correctly?
post #3 of 13 Old 12-28-2016, 10:22 PM
Coming from the master cylinder? Is it the brake switch releasing? Does it do it when bikes not in motion? The brake switch is spring loaded and makes a click on my bike. I have aftermarket master though, can't remember if it did that with OEM master cylinder.
RedAndBlack is offline
post #4 of 13 Old 12-28-2016, 10:22 PM Thread Starter
Theomz90's Avatar
It only does it when the bike is moving
Theomz90 is offline
post #5 of 13 Old 12-28-2016, 11:39 PM
Gawernator's Avatar
The brake lever is supposed to click, there is a tab switch near the master cylinder that clicks when you pull on the lever to activate the brake light
Gawernator is offline
post #6 of 13 Old 12-28-2016, 11:40 PM Thread Starter
Theomz90's Avatar
Ok, that's what I was thinking too... I think because I just changed the brakes I'm hypersensitive to noises and stuff because I'm nervous i might've done something wrong.... now I know the lever clicks, but this clicking seems to be coming from around the brakes itself, and mostly when I let go of the lever
Theomz90 is offline
post #7 of 13 Old 12-29-2016, 12:04 AM
I Ride: 2014 Kawasaki ZX-6R
My brakes click too. Normal unless you installed something wrong, but most likely normal.
Gawernator and Theomz90 like this.
Martillo y Mantequilla #99
post #8 of 13 Old 12-29-2016, 09:35 AM
But only when the bikes in motion? You don't reproduce it when the bike is still and pull on the brake lever right?
You should not be getting clicking down from the brakepads/rotor area. A SLIGHT, metal-sounding rubbing sound might be acceptable (semi-floating rotors) but not an actual "click" or at least what I imagine in my mind what a click is.
If I were you I would throw the bike on a front stand and see if you can more accurately pinpoint the click. Even post us a video so we can hear it. Consider taking your brake calipers off and turning the wheel and see if it still clicks (that would pinpoint if its the brakes vs something else like the wheel bearings)
And if you don't have a front stand, I would consider pulling everything off, inspect for any abnormal areas of wear, and re-installing everything. Can't be more than 15-30 minutes of your time for peace in mind.
Theomz90 likes this.
post #9 of 13 Old 12-29-2016, 09:36 AM
Gawernator's Avatar
Take a video
post #10 of 13 Old 12-29-2016, 01:26 PM
scoot33's Avatar
I Ride: zx6 j2
the clicking could be the brake pad floating up and down slightly causing it to tap the cradle it sits in,
RedAndBlack and Theomz90 like this.
zx6r j2 mods done ,,
scoot33 is offline
post #11 of 13 Old 12-29-2016, 01:27 PM Thread Starter
Theomz90's Avatar
This is exactly what it is.
Update: I took it to the mechanic and they said it's normal, and they showed it to me on another bike... thanks again boys!
scoot33 and Gawernator like this.
Theomz90 is offline
post #12 of 13 Old 12-30-2016, 10:32 AM
Nice! Thanks for reporting back! Good catch scoot!
scoot33 and Theomz90 like this.
post #13 of 13 Old 12-30-2016, 12:45 PM
scoot33's Avatar
I Ride: zx6 j2
glad you sorted it ,i had it on mine before it drove me fkn mad then i found it lol
scoot33 is offline
Front brakes super tight after bleeding awelter Mechanical and Technical 5 06-06-2016 03:54 PM
no front or rear brakes 08 zx6r nrg Mechanical and Technical 4 01-06-2015 03:42 PM
05/06 Front Brakes to 07-12 Ebster1085 Mechanical and Technical 1 09-24-2014 08:55 AM
Braking in a turn explained. Hamsack Motorcycle Talk 49 08-10-2014 10:44 AM
A nice read on lean angle braking from ninjette.org. hellonearth Motorcycle Talk 22 04-15-2014 03:11 PM
